LookingBusy Neutral Newbie September 26, 2012 Share September 26, 2012 Was parking just now in an open-air carpark and reversing butt in and i somehow underestimated the distance between my exhaust pipe and the parking concrete kerb behind. Needless to say, the exhaust hit the kerb and it was quite loud the sound which i could even hear from inside the car. Any damage that i may have done to the poor exhaust? (other than it could be probably be out of shape or position a little bit if there's even such a thing?) ↡ Advertisement Link to post Share on other sites More sharing options...
Detach8 5th Gear September 26, 2012 Share September 26, 2012 Not really exhaust is made of strong cast iron and shouldn't even dent much if you hit it gently Link to post Share on other sites More sharing options...
macrosszero Turbocharged September 26, 2012 Share September 26, 2012 And it is usually hung from rubber hangers so that it can shift a bit. Otherwise your car vibrates a lot from the resonance. The rubber dampens it, I suppose no harm done. Link to post Share on other sites More sharing options...
Rainbatt 1st Gear September 27, 2012 Share September 27, 2012 Me hit a few times too. Like no problem cause go service car, they no tell me anything wrong. Link to post Share on other sites More sharing options...
Tohdj Neutral Newbie September 27, 2012 Share September 27, 2012 Not really exhaust is made of strong cast iron and shouldn't even dent much if you hit it gently its not cast iron. Link to post Share on other sites More sharing options...
Quantum 5th Gear September 27, 2012 Share September 27, 2012 its not cast iron. it's made of stainless steel ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
Exhaust Welding job, MAN, Jeep Chee or Fong Kim
LTA Check - catalytic converter/exhaust
Anyone letting go HKS exhaust or FUJI with cert(ZC21)
NEA to lower vehicle noise levels from 2023
How to clear kitchen choked floor piping?
Aftermarket turbo charge pipe
