Sofarsogood Clutched November 26, 2012 Share November 26, 2012 Hello all,Does anyone have issue with getting a fix on their GPS signal? My windscreen has Llumar solar film installed, and I can hardly get a GPS signal fixed, even after driving around for some time. Is the solar film the culprit, or the curvature of the windscreen? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Blackyv Turbocharged November 26, 2012 Share November 26, 2012 Hello all, Does anyone have issue with getting a fix on their GPS signal? My windscreen has Llumar solar film installed, and I can hardly get a GPS signal fixed, even after driving around for some time. Is the solar film the culprit, or the curvature of the windscreen? What gps unit u have ?... Link to post Share on other sites More sharing options...
Sofarsogood Clutched November 26, 2012 Author Share November 26, 2012 I bought a Marbella uNav. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged November 26, 2012 Share November 26, 2012 It's the solar film. My previous Garmin 1350 works on existing no brand film. When I changed rp Vkool film, it can't lock on. I thought it spoilt bec its a 4-5 year old set so I gave the old 1350 to a friend to try on his car that uses a no brand film, n the GPS works again. I got another Garmin 2450 to try and it works. I guess the film does interfere w GPS, but the new GPS with faster more sensitive chips does help Link to post Share on other sites More sharing options...
Watwheels Supersonic November 26, 2012 Share November 26, 2012 (edited) Does your surrounding have tall buildings? Usually solar films won't have a problem with GPS signal. If you are trying find your way in Shenton way where there are many skyscrapers around your GPS signal will most likely be blocked. Or have you been driving in a tunnel or underground carpark? Try to get your car to stop in an open area but dun block other road users lah. Restart your GPS device. Edited November 26, 2012 by Watwheels Link to post Share on other sites More sharing options...
Cymagnus Clutched November 26, 2012 Share November 26, 2012 Definitely it's the solar film. If you do not mind wires here and there, can install external gps antenna. Used to own one (Holux AR-10). 1 Link to post Share on other sites More sharing options...
Sofarsogood Clutched November 26, 2012 Author Share November 26, 2012 Does your surrounding have tall buildings? Usually solar films won't have a problem with GPS signal. If you are trying find your way in Shenton way where there are many skyscrapers around your GPS signal will most likely be blocked. Or have you been driving in a tunnel or underground carpark? Try to get your car to stop in an open area but dun block other road users lah. Restart your GPS device. I drove around a fair bit but the status still showed Not Fixed. I thought it was the weather yesterday but it was clear skies this morning on the Ecp. Link to post Share on other sites More sharing options...
Axela525 4th Gear November 26, 2012 Share November 26, 2012 I drove around a fair bit but the status still showed Not Fixed. I thought it was the weather yesterday but it was clear skies this morning on the Ecp. Metallic solar film is the culprit....mine last time V cool also cannot lock.... 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic November 26, 2012 Share November 26, 2012 (edited) I drove around a fair bit but the status still showed Not Fixed. I thought it was the weather yesterday but it was clear skies this morning on the Ecp. You gotto understand how such device work. It's more difficult to get a signal lock when on the move especially if your device is of an older model. That's why I suggest you get your car to park in an open area to get a signal fixed first. If it still fails to get a fix dan connect to a charger and reboot the device. Edited November 26, 2012 by Watwheels Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 26, 2012 Share November 26, 2012 I bought a Marbella uNav. My marbela 5" slim also tracking not so good. My previous Shinco much much better. Link to post Share on other sites More sharing options...
Dscheng 3rd Gear November 26, 2012 Share November 26, 2012 I on vcool film and no problem on my garmin old model GPS. 1 Link to post Share on other sites More sharing options...
Deckbuild 6th Gear November 26, 2012 Share November 26, 2012 What I suggest is, turn it on if it comes with internal battery, get the satellite fixed first, than place it on the dash board, then comment whether the GPS signal is affected or not. Link to post Share on other sites More sharing options...
Axela525 4th Gear November 26, 2012 Share November 26, 2012 I on vcool film and no problem on my garmin old model GPS. Depends on which v cool...the premium quality got more metallic.... Link to post Share on other sites More sharing options...
Inlinefour Twincharged November 26, 2012 Share November 26, 2012 Depends on which v cool...the premium quality got more metallic.... Yes Metallic film might block GPS, ERP or mobile phone signal... Some installer will cut a hole on the windscreen film for better reception... 1 Link to post Share on other sites More sharing options...
Scml1961 Neutral Newbie June 21, 2013 Share June 21, 2013 Does anyone know where to retrofit Audi OEM GPS system into Audi car? Not what most of the local installers are using which are Galactio maps. I had tried to retrofit a GPS into my Audi MMI system and the GPS didn't work well. The local installer was using made in China GPS receiver which had problems locking onto the satellitte plus the Galactio map is not crisp and sharp like the stock map (think its a Google map) on Audi Ultra models. As a result, I rejected the GPS. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Rare Annular Solar Eclipse on 26 Dec 11.30 am to 3.30 pm
Car immobiliser and GPS tracker recommend?
Solar film JB
Solar film JB
Is Standalone GPS obsoleting?
Solar panels on HDB roof.
Sun cable. Solar energy from australia
China startup makes large, flexible solar panels in industry first
