MadDog70 2nd Gear November 29, 2012 Share November 29, 2012 Just want to share my experience on general car maintenance (conti and jap/Korean cars might differ): For Every 10,000km - change engine oil 20,000km - change brake fluid 30,000km - change tyres 60,000km - coolant replacement 80,000km - change ATF and timing belt system Please add to the list. ↡ Advertisement Link to post Share on other sites More sharing options...
Porche 5th Gear November 29, 2012 Share November 29, 2012 every 40,000km change ATF then ok lah, want your gearbox up lorry Link to post Share on other sites More sharing options...
Blesak Neutral Newbie November 29, 2012 Share November 29, 2012 thanks for all the information guys http://www.haii.co http://www.doltuku.co Link to post Share on other sites More sharing options...
Dumb 4th Gear November 29, 2012 Share November 29, 2012 Just want to share my experience on general car maintenance (conti and jap/Korean cars might differ): For Every 10,000km - change engine oil 20,000km - change brake fluid 30,000km - change tyres 60,000km - coolant replacement 80,000km - change ATF and timing belt system Please add to the list. 80,001km - change car Link to post Share on other sites More sharing options...
MadDog70 2nd Gear November 30, 2012 Author Share November 30, 2012 UPDATE For Every 10,000km - change engine oil 20,000km - change brake fluid 30,000km - change tyres 40,000km - change Automatic Transmission Fluid (ATF) 60,000km - coolant replacement 80,000km - change timing belt system 5 years - change shock absorbers Link to post Share on other sites More sharing options...
Vextan 1st Gear November 30, 2012 Share November 30, 2012 (edited) Dude, honestly how many years of driving experience you have ? you sound very experienced i like to learn from you. Btw I am very sure you are Sabbie. Edited November 30, 2012 by Vextan Link to post Share on other sites More sharing options...
Jordanplus 1st Gear November 30, 2012 Share November 30, 2012 (edited) UPDATE For Every 10,000km - change engine oil 20,000km - change brake fluid 30,000km - change tyres, my last set last 50K km 40,000km - change Automatic Transmission Fluid (ATF) 60,000km - coolant replacement 80,000km - change timing belt system 5 years - change shock absorbers When to change spark plug, air filter, fuel filter, water pump, air-con filter, brake pad/shoe, clutch (M/T)? any more? Edited November 30, 2012 by Jordanplus Link to post Share on other sites More sharing options...
Houtanzhang Neutral Newbie November 30, 2012 Share November 30, 2012 (edited) What i did for my Honda: 1 Change Engine Oil every 10K KM 2. Change CVTF every 20k to 30K 3. Change Fuel filter for 100K KM 4. Change Spark Plug once around 30K(NGK), once at 8k (Brisk spar plug, looks a bit burned, dare not to use anymore), later will do the adjustment by myself. (Re-gap only) --(Denso now will check and see how first) 5. Change the Air-filter around 20k if not very dirty. (Cleaning or change at 10K, depends how dirty it is.) 6. Change tire once consider need to change 7. Change the brake pad once necessary--- Will wait for the sound... 8. Battery should be changed every two years-- (My current one is 2 year plus, still OK. Will change if any indication of failure like can not start smoothly) 9. Checked my brake fluid, most of the time no need to change... 10. Aircon, no plan yet... since it is working very well, then dun care about it since without aircon, car still can run...hehe! Edited November 30, 2012 by Houtanzhang ↡ Advertisement Link to post Share on other sites More sharing options...
Cars at Expo
Cars at Expo
COE Bidding - March 2024
Car repair and maintenance
Ho Hup Seng......Some good info for our Brudders
New car discount/price/promo
