Osiris 1st Gear February 11, 2013 Share February 11, 2013 Here's how I changed the standard Honda Car Alarm Fob as shown in the picture.Mine's a Stream. I think it's the same for Civic, Jazz, City.Tools/Stuff Needed1. 2.4mm Philip Screwdriver (from small screwdrivers sets commonly sold in home fix etc)2. Replacement Battery - Energizer CR 1616. 3V. ($2.55 ea from NTUC, see picture)3. Time <5mins to changeLeft to rightA. Key Fob cover w/key; B. Key Fob cover; C. Electronics console battery holder ; D. console with buttons.E. top - screw; F. bottom - batterySteps.1. Unscrew the screw securing the fob (E)2. Pry open the Fob in two with a 5 cent coin using the indent (A + B)3. Take out the electronic console (C+D)4. Carefully pry open the 2 clasps holding the electronics console together. Taking care not to dislodge the rubber lining5. Use a small flat screw driver to gently pry out the battery (original was Panasonic)6. Replace the CR1616 with the new one with the positive end ( + ) facing down. Push it till click.7. Close the console by securing the 2 clasps.8. Test lock/unlock buttons and see if the LED light is lit. You can test to lock unlock your car if it's in range, it will work if properly done.9. Place console in the fob cover with key10. Close Cover11. Screw the 2 cover togetherAdditional steps, you may wish to clean the inside of the key cover. (I use photographic cleaning equipment - air spray, brush and tissue. No liquids)This whole process shouldn't take more than 5 mins (no cleaning).Hope this helps. ↡ Advertisement Link to post Share on other sites More sharing options...
Givechance 1st Gear February 11, 2013 Share February 11, 2013 Thanks for the clear photo and descriptions. Can save many a trip to the agent for such a simple job. ↡ Advertisement Link to post Share on other sites More sharing options...
[Concept] Honda 0 Series EVs
Honda Vezel - Part 3
ODO Mileage Tampering
Enzo car mats
Enzo car mats
