Josephsatu 1st Gear February 26, 2013 Share February 26, 2013 I drove 8-9 year old datsuns b4 ty start e coe system n a 10 year old excel n a 19 year old corona cd coe car b4. Never had such bad luck. Even my frens last time drive old swift n corolla never had it. I guess if suay then wil kenna. But if starter never disengage u can hear e starter whining as u drive. Japs are more reliable or maybe your car previous owners have change it I used to drive a very famous conti car(COE), had to change out the starter motor and later when the gearbox got problems, I scrapped it ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 26, 2013 Share February 26, 2013 Japs are more reliable or maybe your car previous owners have change it I used to drive a very famous conti car(COE), had to change out the starter motor and later when the gearbox got problems, I scrapped it Older contis usually hv reliability issues. Even some newer contis still not as reliable as japs or koreans even. Main advantage of contis is e good handling. Link to post Share on other sites More sharing options...
Porsche916 Neutral Newbie March 12, 2013 Share March 12, 2013 You can try various salvage yards across your city for a good condition used one. If you don't get it there, you might want to try online used stores. Paying so much to re-con a starter motor is really absurd! You could get a replacement for lesser than that. Link to post Share on other sites More sharing options...
Samlai Neutral Newbie April 13, 2013 Share April 13, 2013 $200 - $300 to re co a starter? From what i know its to ex, i did mine at sin ming last year for my odyssey at around $90, it take around 2 hours to done the job.U can also get it recon in JB (shop name Hong Nam, bear to carefour at around RM 150 to Rm 200 depend on model. Pls help,Where exactly is the shop in sin ming you mentioned. Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear April 13, 2013 Share April 13, 2013 $200 - $300 to re co a starter? From what i know its to ex, i did mine at sin ming last year for my odyssey at around $90, it take around 2 hours to done the job.U can also get it recon in JB (shop name Hong Nam, bear to carefour at around RM 150 to Rm 200 depend on model. Just curious, any idea what they actually do to recond the motor ? Link to post Share on other sites More sharing options...
Josephsatu 1st Gear April 14, 2013 Share April 14, 2013 Just curious, any idea what they actually do to recond the motor ? Nothing much really Diodes, brushes and clean out rotor and stator coils maybe spray some electrical paint to prevent moisture Labour is the real culprit Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 14, 2013 Share April 14, 2013 (edited) Besides all these, the auto mech will have to use a growler to check the armature for internal short or grounding.If in perfect conditions , the armature commutator will have to be machined to remove all the wear marks. After this process the commutator grooves will have to be clean to prevent short circuit. Etc etc , so a 100% rebuilt is not so simple Edited April 14, 2013 by Yeobh Link to post Share on other sites More sharing options...
Luckcent 4th Gear August 13, 2014 Share August 13, 2014 Besides all these, the auto mech will have to use a growler to check the armature for internal short or grounding.If in perfect conditions , the armature commutator will have to be machined to remove all the wear marks. After this process the commutator grooves will have to be clean to prevent short circuit. Etc etc , so a 100% rebuilt is not so simple Excuse me for bringing up this thread, my car starter motor's cranking is loud. Is it faulty ? 1 Link to post Share on other sites More sharing options...
Baal Supersonic September 10, 2014 Share September 10, 2014 (edited) There is a solenoid that engages e starter motor gear to e flywheel when u turn e key n it crank. If e gear does not disengage fm e flywheel when u release e key e starter keeps turning while u drive n it wil burn out. U sud hear a whining sound if this happens while u r driving. Get e solenoid checked in case its faulty. Ive been driving many years n never had to fix e starter motor b4. It sud not spoil in normal use. Also cranking a hard to start engine fr too long can burn out e motor. My car could be having starter prob. When I googled ....ehow ......point 4 seems familiar =================================================== Listen for grinding and freewheeling. A grinding noise indicates that the starter's drive gear isn't disengaging from the flywheel's gear teeth, or isn't engaging the flywheel completely. Along with or separate from grinding, you may hear a whirring after starting that sounds something like an electric motor or jet engine. The starter's drive gear has a freewheeler in it that keeps your engine from over-running the starter motor and driving it like a generator. The whirring you hear is the sound of the gear failing to disengage, which may indicate a bad return spring or solenoid. Read more : http://www.ehow.com/how_4845780_spot-symptoms-of-bad-starter.html ==================================================== - i hear a low whirring when driving. Notice its not about engine rpm but rather the faster ther car, the more obvious the whirring. Its obvious from 50kmh......while cruising slowly at 1k rpm to a stop. Maybe the whirring still occurs at higher rpm just that the louder engine muffles the sound out - Also after driving for say 20km over 1 hr, if i off the engine and only start it next morning after 10hrs, seems fine. However, if i off the engine after covering the same distance/time & try to start again after 10 mins, can feel some struggle or maybe as per how ehow calls it 'chugging'. - Today in the afternoon, while warming the car while finishing a ciggy, can hear low whirring sound from what sounds like originating from the front left area of the engine bay. You think most likely is the starter motor? Any idea for Getz 1.4, whats the price for a recon set Vs a brand new? Thanks. PS : as per what u mentioned, I do hear a high pitch whining sound when I apply throttle. This started months ago. Then from a few weeks back, the low whirring.....sigh ================================================ Hi @KB27 understand u drove a Getz previously, do u have any advice/insights reg the above? Thanks. Edited September 10, 2014 by Baal 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic September 10, 2014 Share September 10, 2014 My car could be having starter prob. When I googled ....ehow ......point 4 seems familiar =================================================== Listen for grinding and freewheeling. A grinding noise indicates that the starter's drive gear isn't disengaging from the flywheel's gear teeth, or isn't engaging the flywheel completely. Along with or separate from grinding, you may hear a whirring after starting that sounds something like an electric motor or jet engine. The starter's drive gear has a freewheeler in it that keeps your engine from over-running the starter motor and driving it like a generator. The whirring you hear is the sound of the gear failing to disengage, which may indicate a bad return spring or solenoid. Read more : http://www.ehow.com/how_4845780_spot-symptoms-of-bad-starter.html ==================================================== - i hear a low whirring when driving. Notice its not about engine rpm but rather the faster ther car, the more obvious the whirring. Its obvious from 50kmh......while cruising slowly at 1k rpm to a stop. Maybe the whirring still occurs at higher rpm just that the louder engine muffles the sound out - Also after driving for say 20km over 1 hr, if i off the engine and only start it next morning after 10hrs, seems fine. However, if i off the engine after covering the same distance/time & try to start again after 10 mins, can feel some struggle or maybe as per how ehow calls it 'chugging'. - Today in the afternoon, while warming the car while finishing a ciggy, can hear low whirring sound from what sounds like originating from the front left area of the engine bay. You think most likely is the starter motor? Any idea for Getz 1.4, whats the price for a recon set Vs a brand new? Thanks. PS : as per what u mentioned, I do hear a high pitch whining sound when I apply throttle. This started months ago. Then from a few weeks back, the low whirring.....sigh ================================================ Hi @KB27 understand u drove a Getz previously, do u have any advice/insights reg the above? Thanks. From what I understand, if you have a wong-wong-wong sound and it increases and decreases with speed, it's a wheel bearing problem. 1 Link to post Share on other sites More sharing options...
Baal Supersonic September 10, 2014 Share September 10, 2014 From what I understand, if you have a wong-wong-wong sound and it increases and decreases with speed, it's a wheel bearing problem. Ok, thanks bro. Hopefully thats the case. 1.5 yrs to go. Hopefully, can swee swee pull thru. Just dont want to end up 1 day cannot start, gotta take urgent leave, call the tow services....etc. 3 Link to post Share on other sites More sharing options...
Alphas 2nd Gear November 15, 2014 Share November 15, 2014 My starter motor working for 10 years since day one, never once had problem, If you need to recondition the motor, then the quality must be pretty lousy and you ought to change to another brand of starter motor. Link to post Share on other sites More sharing options...
Wdchua Neutral Newbie October 24, 2016 Share October 24, 2016 South East Battery Service Pte Ltd Office: 12N Enterprise Road, Singapore 627693 Office:+65 6466 0155 | Fax: +65 6467 0884 Website: www.seglobal.com.sg They provide repair services for starters, alternators, aircon repair etc at reasonable price. Link to post Share on other sites More sharing options...
Sapl86 Neutral Newbie October 25, 2016 Share October 25, 2016 Hi, YOu may go to JB car workshop and it would be cheaper. Link to post Share on other sites More sharing options...
Zxcvb Turbocharged January 12, 2017 Share January 12, 2017 My car has a grinding sound during the cranking start of the engine. No problem starting. If bring to workshop, will they change the starter motor or flywheel or both? Link to post Share on other sites More sharing options...
Newcar 1st Gear February 24, 2017 Share February 24, 2017 My car has a grinding sound during the cranking start of the engine. No problem starting. If bring to workshop, will they change the starter motor or flywheel or both?Info sharing,hopes can solves your issues.Do Try below shop, they re condition/service my car starter motor years back. De Sheng Trading Address: 711 Geylang Rd #01-03 Oriental Venture Bldg City of Central Region Categories: Car Electric Repairs, Companies & Businesses ↡ Advertisement Link to post Share on other sites More sharing options...
Envy motor director Ng Yu Zhi in hot soup
DIY W212 side mirror actuator replacement
Survey: Which is the best (claims) Motor Insurance company
Huge fire at Yong Sing Motor Works
70mai vs BASEUS Car Jump Starter
Lithium jump starter
Motorist without helmet
Borneo motor cut sales staff comm
