What is advantage of Steel Belted Tyre?
Quantum
noticed that some tyre's side wall labelled "Steel Belted Tubeless Radial" some labelled "Tubeless Radial" only without "Steel Belted", [;)]
can anyone enlighten what it means?
Thanks
This kind of thing can ask Google leh. Faster and more detailed explanation.
thanks
but seems nobody care of this issue while purchese new tyres, iis it important?
Thanks
Now ALL radial tyres comes with steel belts,it is understood for many years already,so Mfg don't bother to label it.
Edited by ER-3682
NOT but most radial tyre is steel belted
i dont understand what made you said mfg dont bother to label it
I can see all them label steel belted
steel belted tyre hard and bump compare to others
steel belted makes the tyre more durable and stronger to certain degree of impact.
But the problem is how good the steel belted is constructed and bonded into tyre is the Technology.
Some time we could see some rubber pc lying along expressway , poor quality tyre more prompt to this kind of tyre separation.
Thanks
I think all decent tire r steel belted. Helps prevent punctures.
More ex tires might use kevlar instead.
I tot those rubber lying on road came fm truck tires. Ty still renew a thick layer of rubber n re-thread e tire. Much cheaper than buying a new tire. Some wil dislodge if not glued on properly.
Cheeper options fr those big truck tires cos a new tire is very ex.
you are correct , some from truck some from passenger car too.
A good rethread tyre will be just like a brand new tyre.
but due to business competition , you know what i meant
only steel belted tyre can be rethread, right?
next time change steel belted tyre have to check carefully, in case got rethread tyre [cool]
Those truck tires re-thread over n over mostly fm msia.
SG i dun think ty re-thread car tires anymore.
Very old technology n sporeans all rich never re-thread. Just buy new. Worst case buy 2nd hand tires.
I beg to disagree.
Kelvar or polymide nylon materials can also be found in some models.
It will have effects on carcass weight and responsiveness.
all tyre can be rethreaded, dont worry that would never happen here .
you will never go wrong with premium brand tyre.
