Fennmax Clutched February 23, 2013 Share February 23, 2013 My car dvr suction keeps loosening. I had place double sided tape to reinforced. Car has window tint. Still loosen. Any tips? ↡ Advertisement Link to post Share on other sites More sharing options...
Simplecar 4th Gear February 23, 2013 Share February 23, 2013 My car dvr suction keeps loosening. I had place double sided tape to reinforced. Car has window tint. Still loosen. Any tips? Please note that any stronger solutions would stick permanently and any attempt to remove it would spoil the tint. Are you prepared for that? Link to post Share on other sites More sharing options...
Kangadrool Supersonic February 23, 2013 Share February 23, 2013 My car dvr suction keeps loosening. I had place double sided tape to reinforced. Car has window tint. Still loosen. Any tips? Put some water or saliva on the suction cup and it will stick. Link to post Share on other sites More sharing options...
Rubbishman 1st Gear February 23, 2013 Share February 23, 2013 Actually dun use double sided tape better. Just clean the surface thoroughly and add some water. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear February 23, 2013 Share February 23, 2013 My car dvr suction keeps loosening. I had place double sided tape to reinforced. Car has window tint. Still loosen. Any tips? 1- wait for a hot day with your car out in the sun. 2- clean both surfaces then dry them. 3- moisten the suction cup and attach. 4- wait till the car and windscreen cools then attach dvr. Link to post Share on other sites More sharing options...
Poper 2nd Gear February 23, 2013 Share February 23, 2013 Soak in hot water. Link to post Share on other sites More sharing options...
Jtb 6th Gear February 23, 2013 Share February 23, 2013 My car dvr suction keeps loosening. I had place double sided tape to reinforced. Car has window tint. Still loosen. Any tips? Use this mount ram Link to post Share on other sites More sharing options...
FocusWagon 1st Gear February 24, 2013 Share February 24, 2013 Actually dun use double sided tape better. Just clean the surface thoroughly and add some water. After a while it will still drop leh, quite a long while lah, week plus. Link to post Share on other sites More sharing options...
Rubbishman 1st Gear February 24, 2013 Share February 24, 2013 After a while it will still drop leh, quite a long while lah, week plus. I think you should get a bigger suction. Maybe your is too small. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged February 24, 2013 Share February 24, 2013 Likely a broken suction.. the plastic part that u press to create the vacuum at be broken that's why its slowly loosens over time. Go SIM Lim or online buy.. in SLS maybe $10+-$20.. online is around US$3-8 inclusive of shipping but takes weeks to arrive Link to post Share on other sites More sharing options...
RadX Moderator February 24, 2013 Share February 24, 2013 Call porker or 20g.... Claimed to be the best suckers around Link to post Share on other sites More sharing options...
Dafansu Turbocharged February 24, 2013 Share February 24, 2013 I use 3M tape Link to post Share on other sites More sharing options...
Fennmax Clutched February 24, 2013 Author Share February 24, 2013 I even remove the battery to lower the weight lol. Will try hot water for the sucker. Dry, wait for hot day, spray water Put saliva on sucker. Stick on window. Pray hard. Link to post Share on other sites More sharing options...
Wormvirus 1st Gear February 24, 2013 Share February 24, 2013 the rubber sucker is bad just white glue it to some better sucker Link to post Share on other sites More sharing options...
Fennmax Clutched February 24, 2013 Author Share February 24, 2013 (edited) Thank you. Edited February 24, 2013 by Fennmax Link to post Share on other sites More sharing options...
Latio2005A Turbocharged February 24, 2013 Share February 24, 2013 Thank you. Go buy 3M double-sided tape (red in color, but the inside is transparent.) The tape was also used to hold the ERP device in the car. It is strong, yet removable (i think). Link to post Share on other sites More sharing options...
Majordan 2nd Gear February 24, 2013 Share February 24, 2013 soak in hot (boiling) water before use. that will loosen up the rubber when in use, put a bit of water Link to post Share on other sites More sharing options...
Pisces69 6th Gear February 25, 2013 Share February 25, 2013 My car dvr suction keeps loosening. I had place double sided tape to reinforced. Car has window tint. Still loosen. Any tips? I also got tint. I just make sure both surfaces r clean then put a little water n stick. My gps mount i stick wh gps attached can still stay stuck fr a few months b4 it drops off. Make sure both surfaces r smooth to hv a good suction. Any nicks or tears n it wun stick well. ↡ Advertisement Link to post Share on other sites More sharing options...
LV stores in Chicago and San Francisco mugged
How to make BOV LOUDER THAN BEFORE!!!!!
Soya Bean Milk Recipes - Make at home easy.
What u do if your wife doesn't want to make out with u?
Dashboard holders for phones and GPS
Mistakes SG drivers make when dealing with dangerous drivers
Weird World Indeed - Circumcision Suction Ritual
Nowadays.. journalists cannot make it.
