Cook123 Supercharged March 22, 2013 Share March 22, 2013 (edited) any experts can advise me on this vsc and check engine light which came on after driving in todays heavy downpour. i drive a 2004/5 model rx300 bmr i disconnected the battery source and this seems gone. anyone can advise me on any further action to take? can someone help me to erase the double post? Edited March 22, 2013 by Cook123 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 22, 2013 Share March 22, 2013 Water ingress to ECU. Link to post Share on other sites More sharing options...
Watwheels Supersonic March 22, 2013 Share March 22, 2013 Somehow the VSC(traction control) sensor is linked to the CEL. So if one of them got detect a fault both will light up. I dunno why. But CEL lights up means it has detected a fault. What fault, you will have to use a OBD II scanner to find out. If you dun have one you may approach a workshop to have it checked out. Link to post Share on other sites More sharing options...
Josephsatu 1st Gear March 23, 2013 Share March 23, 2013 any experts can advise me on this vsc and check engine light which came on after driving in todays heavy downpour. i drive a 2004/5 model rx300 bmr i disconnected the battery source and this seems gone. anyone can advise me on any further action to take? can someone help me to erase the double post? Have it check, never disregard the check light Heavy downpour = water ingress 1 Link to post Share on other sites More sharing options...
Cook123 Supercharged March 23, 2013 Author Share March 23, 2013 thanks guys. i gather that likely is warer ingress to ecu. so far driven 20km today no problems. keep my fingers crossed! Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 23, 2013 Share March 23, 2013 thanks guys. i gather that likely is warer ingress to ecu. so far driven 20km today no problems. keep my fingers crossed! If possible, sun it in the open carpark. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 23, 2013 Share March 23, 2013 thanks guys. i gather that likely is warer ingress to ecu. so far driven 20km today no problems. keep my fingers crossed! Very hard fr water to enter ecu. Maybe water in vsc sensor on each wheel. If u drive n it heat up n water dry up it sud go back to normal but if it kenna heavy rain or flood again....it wil trigger warning light again. U sud get ws to chk n change sensor or if u can diy wh silicon to seal e leak. Link to post Share on other sites More sharing options...
Algergohce Clutched March 26, 2013 Share March 26, 2013 I am driving a 2006 GS300 and had this problem for a few times already. If you search some of the online LEXUS forums, the cause may vary from as simple as a loose fuel filler cap to a loose air hose in the engine compartment. The effects are not great, but you lose the VSC and also the slope autohold functions when the warning lights are on. For me, I simply disconnected the battery for a while to reset the failure codes and it was okay afterwards. Try to check your fuel filler cap for proper security whenever you refuel. Alger 1 Link to post Share on other sites More sharing options...
5936 1st Gear March 26, 2013 Share March 26, 2013 Agree, water not possible to enter VSC ECU. It's located inside cabin area and it's sealed. 1 Link to post Share on other sites More sharing options...
5936 1st Gear March 26, 2013 Share March 26, 2013 Agree, water not possible to enter VSC ECU. It's located inside cabin area and it's sealed. ↡ Advertisement Link to post Share on other sites More sharing options...
KIA K3 Owners check-in!
Do officials still check the 3/4 tank rule at causeway?
Quad Light Bulb Size
Recommendations for light kitchen carpentry and sink works
SCHNELL Engine Oil 5W40
