Ungtiong 2nd Gear April 1, 2013 Share April 1, 2013 I have this problem.......when i drive my car in the morning or after parking for a long time, when i accelerate hard, the car will jerk a few times (4-5 times) at around 5000 rpm...this will ALWAYS happens once in the trip and after that in the same trip, no matter how hard i accelerate, i can never repeat the jerking. When the car is jerking (or engine hesitating) the speedo will jump around. What seems to be the problem that will only happened once per trip.....after that the car drives fine. If i never accelerate hard, the car is also fine. Spark plugs changed, air filter clean, mass airflow sensor cleaned, engine oil changed..... ↡ Advertisement Link to post Share on other sites More sharing options...
Cook123 Supercharged April 1, 2013 Share April 1, 2013 if spark plug problem, will be cheap to solve. Link to post Share on other sites More sharing options...
Elmo 4th Gear April 1, 2013 Share April 1, 2013 Without knowing your car model and mods I can only guess it is a fueling issue. 5K rpm is almost redline for some cars but since you say it only happens once per trip could mean the first time you whack till 5K rpm, your fuel pump couldn't keep up. Link to post Share on other sites More sharing options...
Torquemonster 1st Gear April 1, 2013 Share April 1, 2013 Without knowing your car model and mods I can only guess it is a fueling issue. 5K rpm is almost redline for some cars but since you say it only happens once per trip could mean the first time you whack till 5K rpm, your fuel pump couldn't keep up. That is what i am thinking as well. Not enough fuel supply. Could be crappy fuel pump, clogged up fuel filter, water in the fuel line(highly unlikely since it only happens every trip). Link to post Share on other sites More sharing options...
Divpan Neutral Newbie April 2, 2013 Share April 2, 2013 hows the battery doing? Is it time to change? Recently met with some batteries issue and my car jerks when idle at traffic lights, and the car seems to face strong "pull-backs" when I reduce speed, before coming to a stop... Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 2, 2013 Share April 2, 2013 Have you changed your fuel filter yet? Something to do with delivery of fuel perhaps? Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear April 2, 2013 Share April 2, 2013 Do u rev up to 5k rpm every morning? What happens if 2 or 3k rpm? Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 2, 2013 Share April 2, 2013 In the morning, ambient temp is not very warm so fuel inside the system don't vaporise so there is no air bubbles in the system. Even the top header ( fuel system pressure ) pressure is low you still can start the car due to cooler temp. Once you start driving, heat built up and that have strong influence on the fuel system causing the fuel to vaporise resulting in bubbles formation, due to the weak pump pressure the bubbles will continue to remains in the system. Once you shut down the engine, the fuel starts to absorb more heat -thereby creating more bubbles and that greatly reduce the fuel hydraulic pressure in the system. The next starting will be a problem and if the engine starts -driving and acceleration will be very rough due to the presence of bubbles in the fuel system. Consclusion - go for a fuel pressure test and the chance yr fuel pump needs to be replaced. Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 2, 2013 Share April 2, 2013 I have this problem.......when i drive my car in the morning or after parking for a long time, when i accelerate hard, the car will jerk a few times (4-5 times) at around 5000 rpm...this will ALWAYS happens once in the trip and after that in the same trip, no matter how hard i accelerate, i can never repeat the jerking. When the car is jerking (or engine hesitating) the speedo will jump around. What seems to be the problem that will only happened once per trip.....after that the car drives fine. If i never accelerate hard, the car is also fine. Spark plugs changed, air filter clean, mass airflow sensor cleaned, engine oil changed..... Maybe e auto choke faulty. Mix too lean when cold. Link to post Share on other sites More sharing options...
Rustyz 5th Gear April 2, 2013 Share April 2, 2013 what car? seem like throttle hay wire Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear April 2, 2013 Share April 2, 2013 I have this problem.......when i drive my car in the morning or after parking for a long time, when i accelerate hard, the car will jerk a few times (4-5 times) at around 5000 rpm...this will ALWAYS happens once in the trip and after that in the same trip, no matter how hard i accelerate, i can never repeat the jerking. When the car is jerking (or engine hesitating) the speedo will jump around. What seems to be the problem that will only happened once per trip.....after that the car drives fine. If i never accelerate hard, the car is also fine. Spark plugs changed, air filter clean, mass airflow sensor cleaned, engine oil changed..... My cousin have the same problem on his Optra, he get it fix last saturday at katc. Problem solve after changing the ignition coil , ignition cable. Now the ride is very smooth and powerful.Hope it will help u on that. Link to post Share on other sites More sharing options...
Sly Neutral Newbie April 7, 2013 Share April 7, 2013 Hi I have similar problem with my ford focus 1.6L not solve yet, auto shops advised me to change the 02 sensors and the ignition coil .......well how do i get in touch with katc. Link to post Share on other sites More sharing options...
Wishxsr 2nd Gear April 7, 2013 Share April 7, 2013 Hi I have similar problem with my ford focus 1.6L not solve yet, auto shops advised me to change the 02 sensors and the ignition coil .......well how do i get in touch with katc. U can call the boss Raymond @ 97775200, the workshop located at lor 8 toa payoh, forgotten the unit number. Link to post Share on other sites More sharing options...
Bensonawyong Neutral Newbie April 24, 2013 Share April 24, 2013 You get the jitters from the moving off from stationery part or after u had smoothly moved off? ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
