Aerosmith 2nd Gear April 3, 2013 Share April 3, 2013 a loud grinding noise from the front right of the car occurs only during wet weather. on dry weather, there is absolutely no such sound no matter how i whack the car. but 5 mins into a rain, this noise comes out, when it is loud, it is quite alarming because you might think the car is breaking down any moment. it is not making noise continuously, it on off on off during the journey. i notice it will get louder when i raise rpm, when i release throttle, it subsides. anyone had before, the car is legacy gt 2.5 auto ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Twincharged April 3, 2013 Share April 3, 2013 Maybe Water got in the belts.?? Link to post Share on other sites More sharing options...
Zhngmycar 1st Gear April 3, 2013 Share April 3, 2013 should be the belt.. a sharp "Queking" sound when u add abit of pressure only last for few secs? should be common bro.. Link to post Share on other sites More sharing options...
Aerosmith 2nd Gear April 3, 2013 Author Share April 3, 2013 should be the belt.. a sharp "Queking" sound when u add abit of pressure only last for few secs? should be common bro.. nope, the sound is metal on metal grinding, and last as long as i rev rpm the sound was not present in the past. the sound came on the first time it rained after i did a gearbox rebuilt with sports clutch. but the gearbox can be ruled out because normal dry weather no problems even with hard whacking. I also tuned the car after that and tuner said gearbox was in perfect condition. Link to post Share on other sites More sharing options...
Zakkwylde 5th Gear April 3, 2013 Share April 3, 2013 Try checking your undercarriage cover or wheel fender. Maybe the connecting pin is missing thus cause the flapping sound when goes over puddle during rainy days. I too had the same issue and had it resolve. Link to post Share on other sites More sharing options...
Kiadaw 6th Gear April 3, 2013 Share April 3, 2013 Whats the difference between raining & wet weather? Link to post Share on other sites More sharing options...
Jtis 4th Gear April 3, 2013 Share April 3, 2013 I had something very similar the last time during raining weather, on my previous car. Ended up it was the midpipe of my aftermarket exhaust system that was knocking on my chassis when the underside got wet and warped slightly. If yours is a legacy, check the exhaust piping (up-pipe?) to see it has any scruff marks. Think there is exhaust piping running around there? Link to post Share on other sites More sharing options...
Aerosmith 2nd Gear April 3, 2013 Author Share April 3, 2013 Try checking your undercarriage cover or wheel fender. Maybe the connecting pin is missing thus cause the flapping sound when goes over puddle during rainy days. I too had the same issue and had it resolve. ok, i will do it at workshop asap Link to post Share on other sites More sharing options...
Aerosmith 2nd Gear April 3, 2013 Author Share April 3, 2013 I had something very similar the last time during raining weather, on my previous car. Ended up it was the midpipe of my aftermarket exhaust system that was knocking on my chassis when the underside got wet and warped slightly. If yours is a legacy, check the exhaust piping (up-pipe?) to see it has any scruff marks. Think there is exhaust piping running around there? sounds plausible, since it occurs during wet, maybe the metal contract with the cold water and vibrate more. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 3, 2013 Share April 3, 2013 It got to do with yr brake disc and pad. Link to post Share on other sites More sharing options...
Aerosmith 2nd Gear April 3, 2013 Author Share April 3, 2013 It got to do with yr brake disc and pad. then it should happen when dry too right? but it might be possible, cause i forgotten to change pads once, and it worn off and slightly scarred the rotor, now it is with brand new pads. but the noise occur only wet and only when i accelerate, not brake Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 3, 2013 Share April 3, 2013 When yr mech replace the pads, chance he may have not push the the caliper pistons far back enough. The clearance between the disc and pad is far from min. When water get into the gap there, it creat a"hydraulic resistance" to the wheel rotations 1 Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 4, 2013 Share April 4, 2013 (edited) sorry error Edited April 4, 2013 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 4, 2013 Share April 4, 2013 (edited) Sorry error Edited April 4, 2013 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 4, 2013 Share April 4, 2013 Link to post Share on other sites More sharing options...
KaKiLang 4th Gear April 4, 2013 Share April 4, 2013 (edited) I had something very similar the last time during raining weather, on my previous car. Ended up it was the midpipe of my aftermarket exhaust system that was knocking on my chassis when the underside got wet and warped slightly. If yours is a legacy, check the exhaust piping (up-pipe?) to see it has any scruff marks. Think there is exhaust piping running around there? Same noise during wet weather, found out its my midpipe dented, got it rectified 80rm 2wks ago, ride as quiet b4. Edited April 4, 2013 by KaKiLang Link to post Share on other sites More sharing options...
Aerosmith 2nd Gear April 4, 2013 Author Share April 4, 2013 Same noise during wet weather, found out its my midpipe dented, got it rectified 80rm 2wks ago, ride as quiet b4. i going to check now ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Heavy and rain proof curtains/blinder recommendations?
Intermittent rattling noise, car in ICU
When anything happens…CHANGE CAR!
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
