Jtb 6th Gear April 12, 2013 Share April 12, 2013 does anyone knows why this blue LED lighted & off again? Just trying to find what is this indicator for......... ↡ Advertisement Link to post Share on other sites More sharing options...
Shift_lock 1st Gear April 12, 2013 Share April 12, 2013 What car is this? Civic? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 12, 2013 Share April 12, 2013 bluetooth? usually bluetooth is blue color light. try to find your owners manual to see lo. probably could be a mic. Link to post Share on other sites More sharing options...
Jtb 6th Gear April 12, 2013 Author Share April 12, 2013 What car is this? Civic? yes Link to post Share on other sites More sharing options...
Jtb 6th Gear April 12, 2013 Author Share April 12, 2013 bluetooth? usually bluetooth is blue color light. try to find your owners manual to see lo. probably could be a mic. car no bluetooth future Link to post Share on other sites More sharing options...
LoverofCar 6th Gear April 12, 2013 Share April 12, 2013 (edited) I also see this light in my car..but it is green in color ..not blue..I'm curious too...I confirm this is not bluetooth system light......not sure whether this is related to the self dimming rear mirror in the car...........hope someone can answer this. Edited April 12, 2013 by LoverofCar Link to post Share on other sites More sharing options...
Jtb 6th Gear April 12, 2013 Author Share April 12, 2013 I also see this light in my car..but it is green in color ..not blue..I'm curious too...I confirm this is not bluetooth system light......not sure whether this is related to the self dimming rear mirror in the car...........hope someone can answer this. CourtesyLight just found this... Link to post Share on other sites More sharing options...
LoverofCar 6th Gear April 12, 2013 Share April 12, 2013 CourtesyLight just found this... You attached the full manual in the link>? What exactly is a courtesy light? Link to post Share on other sites More sharing options...
Jtb 6th Gear April 12, 2013 Author Share April 12, 2013 You attached the full manual in the link>? What exactly is a courtesy light? parking light on this led will appear. brightness can be controlled on the instr panel ON(II) Link to post Share on other sites More sharing options...
LoverofCar 6th Gear April 12, 2013 Share April 12, 2013 parking light on this led will appear. brightness can be controlled on the instr panel ON(II) huh? what is parking light ? so what is this LED light indicating? Link to post Share on other sites More sharing options...
Jtb 6th Gear April 12, 2013 Author Share April 12, 2013 huh? what is parking light ? so what is this LED light indicating? I am yet to find out myself too. I do not know just to alert the parking light is on!!! snapshot Link to post Share on other sites More sharing options...
Deckbuild 6th Gear April 12, 2013 Share April 12, 2013 parking light on this led will appear. brightness can be controlled on the instr panel ON(II) Sounds like ambient lighting, available in higher end car. Link to post Share on other sites More sharing options...
Jittery Neutral Newbie April 12, 2013 Share April 12, 2013 I am yet to find out myself too. I do not know just to alert the parking light is on!!! snapshot you change gear to P, the light comes on to help you see in the dark la.. so that can see the on/off engine button or your keys etc. Link to post Share on other sites More sharing options...
LoverofCar 6th Gear April 12, 2013 Share April 12, 2013 you change gear to P, the light comes on to help you see in the dark la.. so that can see the on/off engine button or your keys etc. really? I go test on my car...report back later.. Link to post Share on other sites More sharing options...
Jtb 6th Gear April 13, 2013 Author Share April 13, 2013 you change gear to P, the light comes on to help you see in the dark la.. so that can see the on/off engine button or your keys etc. tested Led lighted at P when headlight is on. too dim of anything.an indication light is on Link to post Share on other sites More sharing options...
Rustyz 5th Gear April 13, 2013 Share April 13, 2013 tested Led lighted at P when headlight is on. too dim of anything.an indication light is on rev the engine a bit does it help?(At P gear) Link to post Share on other sites More sharing options...
Jtb 6th Gear April 14, 2013 Author Share April 14, 2013 rev the engine a bit does it help?(At P gear) no effect, still glow at a normal intensity Link to post Share on other sites More sharing options...
Rustyz 5th Gear April 14, 2013 Share April 14, 2013 no effect, still glow at a normal intensity sorry I misunderstood ur question. that light nissan teana also have as the car theme light is orange so is the light. if I remember correctly it is for passengers to read map like that. as it may affect the driver vision if ob the cabin light. teana switches on as I switchmy headlight on. ↡ Advertisement Link to post Share on other sites More sharing options...
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Quad Light Bulb Size
E-ink tablet for reading and note taking
Recommendations for light kitchen carpentry and sink works
NTUC Fairprice Supermarket opened 24HRS above Buangkok MRT Station
P2096 Check engine light
