Babyt 4th Gear April 20, 2013 Share April 20, 2013 the waterpipes at home is making loud constant 'duuuu' noise when we turn on tap, flush toilet, use washing machine. it sounds like as if its going to vibrate and burst. ended up we cannot turn on the water volume too fast n too much to avoid the sound. what can I do? sld I call town council or HDB or PUB? Will adjusting water valve works? ↡ Advertisement Link to post Share on other sites More sharing options...
Mcf777 Turbocharged April 21, 2013 Share April 21, 2013 maybe 1 of the area of the pipe needs to put 1 extra clip. check which area that is not hold tight by the clip. Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear April 21, 2013 Share April 21, 2013 have this problem too... this only happen when certain tapes are open fully... (esp those pipe that have multiple tape along the same pipe) Link to post Share on other sites More sharing options...
Pisces69 6th Gear April 21, 2013 Share April 21, 2013 the waterpipes at home is making loud constant 'duuuu' noise when we turn on tap, flush toilet, use washing machine. it sounds like as if its going to vibrate and burst. ended up we cannot turn on the water volume too fast n too much to avoid the sound. what can I do? sld I call town council or HDB or PUB? Will adjusting water valve works? Sounds like air lock. Try on all yr taps full fr awhile to flush out e air trapped inside n see how. Link to post Share on other sites More sharing options...
Somewhat1975 6th Gear April 21, 2013 Share April 21, 2013 It happened in my house before. The problem was solved after changing a leaking tap Link to post Share on other sites More sharing options...
Tiger21 Clutched April 21, 2013 Share April 21, 2013 Try this Check your main inlet valve. Make sure it is fully opened. Happened to my place before. Link to post Share on other sites More sharing options...
Psuche Neutral Newbie April 21, 2013 Share April 21, 2013 Sounds like air lock. Try on all yr taps full fr awhile to flush out e air trapped inside n see how. +1. Incoming water supply' pressure could be too high. If so, reduce the opening at the control valve. Do the same thing to isolating valves at each supply point should also helps. Link to post Share on other sites More sharing options...
Gitanic 6th Gear April 21, 2013 Share April 21, 2013 my neighbor worse....use a grinder everyday that sounds like a driller in high speed Link to post Share on other sites More sharing options...
Neost 6th Gear April 21, 2013 Share April 21, 2013 It is called water hammer effect. Studied before in uni. But can't remembered what's the theory behind. You may google water hammer effect Link to post Share on other sites More sharing options...
Raymondism Twincharged April 21, 2013 Share April 21, 2013 the waterpipes at home is making loud constant 'duuuu' noise when we turn on tap, flush toilet, use washing machine. it sounds like as if its going to vibrate and burst. ended up we cannot turn on the water volume too fast n too much to avoid the sound. what can I do? sld I call town council or HDB or PUB? Will adjusting water valve works? call your plumber they will know wat to do Link to post Share on other sites More sharing options...
Angcheek Hypersonic April 21, 2013 Share April 21, 2013 I think its the resonance effect of the pipe and the water flow frequency. You can try reducing or increasing the water flow at the main level control 3 Link to post Share on other sites More sharing options...
Asher 1st Gear April 21, 2013 Share April 21, 2013 I thought water pipe noises are the cause of the marble falling noises in HDB. Anyway, for your issue, it depends on which part of the pipe that is causing the noise. HDB sometimes will say the issue if caused by upstairs. Quite leychey. Suggest you source around for any friends who knows plumping or piping. Link to post Share on other sites More sharing options...
Jtay 1st Gear April 21, 2013 Share April 21, 2013 the waterpipes at home is making loud constant 'duuuu' noise when we turn on tap, flush toilet, use washing machine. it sounds like as if its going to vibrate and burst. ended up we cannot turn on the water volume too fast n too much to avoid the sound. what can I do? sld I call town council or HDB or PUB? Will adjusting water valve works? I suggest you call your own plumber to investigate. Could be caused by faulty fittings. Dont think it's under the purview of PUB nor town council. Link to post Share on other sites More sharing options...
Fitvip Supersonic April 21, 2013 Share April 21, 2013 I had the same problem before. I adjusted the main valve and each control valve, especially the valve to the cistern. High pressure causes very loud noise! Link to post Share on other sites More sharing options...
Nlatio Turbocharged April 21, 2013 Share April 21, 2013 It happened in my house before. The problem was solved after changing a leaking tap Yap, that the usual cause of it.... happen to mine also..... leaking tap.... once change, sound gone... that is $$$ spend, problem solved... Link to post Share on other sites More sharing options...
Angcheek Hypersonic April 21, 2013 Share April 21, 2013 The reason for the adjust of the water pressure is to avoid the resonance. So if main water control is set to high , inner water control have to set lower. or vise verse. This is to basically trying to avoid the resonance freq betw the water flow and the pipe. Of course this is assuming there is no other problem eg leaking or some connecting pipe are loose.etc. Another possiblility is that you have some area where pipe holders are too far apart . This is what I experiences. If doesnt help , then got to get the expert Mario :-) 4 Link to post Share on other sites More sharing options...
Babyt 4th Gear April 21, 2013 Author Share April 21, 2013 and to ease the loud constant sound, the only way is to turn on the tap to let the water flow when the sound is created from flushing toilet. when the washing machine is drawing water from pipe, the toilet tap will leak water by itself and u have to turn off it and the sound will disappear. Link to post Share on other sites More sharing options...
Kongbapao Neutral Newbie April 21, 2013 Share April 21, 2013 Same problem + leaking. Called a plumber last week and he said it is due to the taps' internal structure. Changed the taps and all problems gone. ↡ Advertisement Link to post Share on other sites More sharing options...
Intermittent rattling noise, car in ICU
The Singapore divide accdg to this!
