MyCarForum Logo
Search
Magnifying glass
  • 1
  • Search this thread
  • Reply to this topic
16 replies to this topic | 0 praises
#1
Posted 05 May 2013 - 07:39 PM
Siewss
  • THREAD STARTER
  • Siewss
    5th Gear
    Author Image
    1,245
My front suspension arm bushings are worn and I've been advised by the AD to change the who suspension arm assembly which cost a total of $800+.
I believe I should be able to change out the bushings instead but I'm not sure if there are workshops who can do this. Any advice?
#2
Posted 14 May 2013 - 11:34 AM
Shunsuke1984
  • Premium member
    Shunsuke1984
    Author Image
    17
Hi, I'm just got my 5 yr-old axio and during 70km servicing, the workshop i went to also told me the whole front lower control arm must change due to worn out bushing, but because they cannot get the bushing, the only choice is to change the whole arm. Costs about $550 (include labor). However, I KIV the parts change because I don't feel any problems when turning or tyres loose issues. So I went to get a second opinion and found out my bushing still looks good. You should get a second opinion from another workshop or from a mechanic friend..
#3
Posted 14 May 2013 - 11:59 AM
Xefera
  • Premium member
    Xefera
    Supercharged
    Author Image
    5,093
find another trustworthy workshop to diagnose the problem.
#4
Posted 14 May 2013 - 01:05 PM
Meanmachine
  • Premium member
    Meanmachine
    6th Gear
    Author Image
    4,152
my E class merc engine mount changed by my mechanic only charged me $80/ labour,
mounting bought fm stockist less than 200/ U tell me B/B car cost higher ? dun be a carrot bro !
Disclaimer: Some content may not be accepted by all as we are not trained counseller / adviser, we seek your tolerant. My advice is based on experiences / exposure/s committed to give an honest & direct answer, no profanity & accusation to be taken of any kind, in an event that it misfired, it should be taken as a pinch of salt. Thank you !
#5
Posted 14 May 2013 - 03:30 PM
VinceBr
  • VinceBr
    Author Image
    3
If you are looking for something affordable, You may try out used car parts services in your vicinity. I have been doing the same for my cars and get a lot of savings by doing the same. There is this portal from where I frequently shop for used stuff online automotix.net/usedautoparts.html I always get the original OE parts with a year's warranty delivered at no extra cost. Check them out, they will be quite useful.
#6
Posted 14 May 2013 - 07:00 PM
Simpleonly
  • Premium member
    Simpleonly
    5th Gear
    Author Image
    2,346
what car you driving?
I'm driving Trajet buy the bush from Spore stockist it cost only $20-30 per bush.
Bring to JB WS they charges RM25 per bush, machine press menthod.
cheers
#7
Posted 14 May 2013 - 07:06 PM
Surferguy1978
  • Surferguy1978
    3rd Gear
    Author Image
    360
i also ask a AD and outside workshop on the pricing for suspension arm bushing and seems like both of them also advise to replace the whole control arm... no longer sell the bushing as a standalone.
#8
Posted 14 May 2013 - 08:05 PM
Othello
  • Premium member
    Othello
    2Fast2Furious
    Author Image
    23,807
ask the stockist. not the workshop. To them, of course change whole arm easier, less work to do
New to iHerb? Use coupon code MCG340 for up to $10.00 off your first order.
http://www.iherb.com?rcode=mcg340
#9
Posted 14 May 2013 - 08:07 PM
Othello
  • Premium member
    Othello
    2Fast2Furious
    Author Image
    23,807
should be share same parts as normal MZ6 right?
#10
Posted 14 May 2013 - 09:52 PM
Siewss
  • THREAD STARTER
  • Siewss
    5th Gear
    Author Image
    1,245
Mine's really worn. I can hear metal surfaces grinding together everytime I take a sharp right hook. I was informed by the AD service advisor 2 services ago but decided to put off the suspension arm replacement till I find a more cost efficient solution.
#11
Posted 14 May 2013 - 10:08 PM
Siewss
  • THREAD STARTER
  • Siewss
    5th Gear
    Author Image
    1,245
I'll probably do that. I've been pushing it off because of other priorities. It's equally important that I don't end up replacing many more item than I bargain for from a simple diagnosis.
#12
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    39,986
If I'm not wrong a lot of car suspension arms have the rubber moulded to the metal. In other words you have to replace the entire arm upper or lower.
Car makers want to make money out from parts. They will make it such that you cannot buy aftermarket bushing and replace them. Aftermarket company make money, car maker loose money. Hence they pour molten rubber into the bushing area to make it not replaceable.
Night King
#13
Posted 14 May 2013 - 10:10 PM
Siewss
  • THREAD STARTER
  • Siewss
    5th Gear
    Author Image
    1,245
I'm afraid my car's rather rare, so searching for used parts will pose a real challenge. However, I appreciate your sharing, and will try searching at the sites you recommended.
#14
Posted 14 May 2013 - 10:12 PM
Siewss
  • THREAD STARTER
  • Siewss
    5th Gear
    Author Image
    1,245
Yes, it's quite rare.
Today, replacing the bushing is akin to repair, but most workshop prefer to replace. Easier, faster and definitely higher margin.
#15
Posted 14 May 2013 - 10:15 PM
Siewss
  • THREAD STARTER
  • Siewss
    5th Gear
    Author Image
    1,245
Actually I'm not sure, but mine's all wheel drive and I suspect the suspension arm's set up and geometry are different, and I think the setting's not very pliant.
#16
Posted 15 May 2013 - 02:32 PM
Shunsuke1984
  • Premium member
    Shunsuke1984
    Author Image
    17
Hi VinceBR,
Many thanks for the website. So you shipped the parts from US to Singapore? How much extra shipping cost do you pay?
#17
Posted 10 September 2016 - 05:05 PM
Darkwinter
  • Darkwinter
    Author Image
    1
Don't be a carrot.. you can youtube and understand where and how a control arm bushing works and can be easily replaced...
For conti cars all 4 bushing replaced only cost ard 300 SGD... including labour...
I alway trust servotronic (mr Philip) to get these maintenance part done properly...
  • 1
Dynamics Mechanic Pte Ltd
Quick Reply
