Samwng 1st Gear May 22, 2013 Share May 22, 2013 I'm eying on Toyo C1S. Anyone currently running on this tyre ? How is the performance in wet and wear out rate (_/5 - '5 is the max') Thanks.. ↡ Advertisement Link to post Share on other sites More sharing options...
Ellie111 Neutral Newbie May 25, 2013 Share May 25, 2013 do you need turbo? Link to post Share on other sites More sharing options...
Moadia 1st Gear May 25, 2013 Share May 25, 2013 Try the Toyo T1R if u have a bit more budget.. its better in terms of grip for both dry and wet road and tread wear is pretty good.. Link to post Share on other sites More sharing options...
Kayaloti 2nd Gear May 27, 2013 Share May 27, 2013 (edited) I'm on C1S now, definitely will go for T1R next time. Pro - only less noise. Con - Wear rate extremely fast. - Wet grip, good but not too confidence if go beyond 100km/h - Dry grip, not as good as T1R but will hold. I'm driving 1.6L AWD manual. Previously on my T1R. Pro - Wet grip excellent. - Dry grip excellent, though side wall a bit soft but it would still hold pretty firmly on the ground. Con - Noise level goes higher as your millage hit 20K. Edited May 27, 2013 by Kayaloti Link to post Share on other sites More sharing options...
Tarzan666 2nd Gear May 27, 2013 Share May 27, 2013 using toyo C1S...previously on federal evo 595.. obviously much better...used for few months...noise lower, grip wet & dry better... for the price i got cant complain much.. Link to post Share on other sites More sharing options...
VellfireS 4th Gear May 27, 2013 Share May 27, 2013 using toyo C1S...previously on federal evo 595.. obviously much better...used for few months...noise lower, grip wet & dry better... for the price i got cant complain much.. next PSS la.. Link to post Share on other sites More sharing options...
Strudel- 1st Gear May 27, 2013 Share May 27, 2013 next PSS la.. Link to post Share on other sites More sharing options...
Lydiachristopher 3rd Gear May 27, 2013 Share May 27, 2013 Using on Camry 18" C1S already 15000km, grip was medium on wet and dry , just a normal tyre without any outstanding performance. Road noise was louder than PS3. Link to post Share on other sites More sharing options...
Ungtiong 2nd Gear May 28, 2013 Share May 28, 2013 EU label rating is crap but its quiet http://www.toyotires.eu/tire/pattern/proxes-c1s PS3 is at least better in wet weather http://www.michelin.co.uk/tyres/michelin-p...tab-tyres-sizes Link to post Share on other sites More sharing options...
Monkill May 31, 2013 Share May 31, 2013 PS3 is noisy on dry but awesome wet grip. Depend on your needs i guess. Link to post Share on other sites More sharing options...
Ccwjames Neutral Newbie June 4, 2013 Share June 4, 2013 May I know the price for this C1S? Link to post Share on other sites More sharing options...
Zniper 2nd Gear June 4, 2013 Share June 4, 2013 on T1R now... but outer wear quite fast even middle still got depth... but it's a gd tire for both dry and wet... will still be changing back same when it is due for change... Link to post Share on other sites More sharing options...
Bandie Neutral Newbie June 4, 2013 Share June 4, 2013 Have c1s on my rear odyssey, kanasai aquaplane at 120, bouncy as fcuk ard corners. Last pair was Eagle F1 Aym.... peanuts n monkeys man! One world of diff Link to post Share on other sites More sharing options...
VellfireS 4th Gear June 4, 2013 Share June 4, 2013 on T1R now... but outer wear quite fast even middle still got depth... but it's a gd tire for both dry and wet... will still be changing back same when it is due for change... T1R more "premium" than C1S right? Link to post Share on other sites More sharing options...
LeeBeng_Tyre Neutral Newbie June 5, 2013 Share June 5, 2013 May I know the price for this C1S? hi what size you are looking for? Link to post Share on other sites More sharing options...
Yowrol Neutral Newbie June 8, 2013 Share June 8, 2013 i suppose t1r is more sporty ??? c1s i think for more comfort then sporty Link to post Share on other sites More sharing options...
Divpan Neutral Newbie June 26, 2013 Share June 26, 2013 Was at ALTC, and changed to the T1R...195/50/15...paid $95 per tyre (net). I think the price looks ok...DOM: Q4 2012 Link to post Share on other sites More sharing options...
Samwng 1st Gear July 6, 2013 Author Share July 6, 2013 Change my target to GT Radial_HPY - 225/55/17. pls contribute your value -FR here.. wet : _ / 5 dry : _ / 5 Comfy : _ /5 Changing end of July'13 before head north -perak. ↡ Advertisement Link to post Share on other sites More sharing options...
New Ford Mondeo
New Ford Mondeo
TOYO PROXES T1R
TOYO PROXES T1R
Parking against traffic flow...beware
Toyo tyres made in Japan
Toyo Proxes CF2
Toyo Proxes CF2
TOYO C1S
TOYO C1S
Facelift Mazda 6
Facelift Mazda 6
Which shop sells TOYO tyres and don't damage rims
