Pisces69 6th Gear June 14, 2013 Share June 14, 2013 alot of workshops during servicing they will just change your engine oil, clean air filter and check brake pads, dont understand why they cannot check other stuff like tensity of belts, check lights and tyre pressure....put so much 16 point check Many trainee mechs dun know how to chk all these stuff. All ty learn is here is where u drain oil....fill oil....spark plugs n air filter. Anything else n ty need 15-20 mins to search fr these things. Ask them to chk ty lagi blur dun know how. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 14, 2013 Share June 14, 2013 I notice it alot of times too, is it wiring problem? Don't the owner care? Cos if its hid bulbs n ty chk wh agent how much to change.....ty decide can still drive wh 1 light only. Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 14, 2013 Share June 14, 2013 Botak tyres with carcass showing is 3 demerit points + fine. If tire already can see carcass........ its a deadly weapon waiting to kill somebody. Tire sud change even b4 any threadwear indicator(TWI) is reached. Usually 1-2mm b4 is good enough. Also uneven wear u sud change tire. Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 14, 2013 Share June 14, 2013 Haha I guess the SMS channel is just for show. Anyway I was expecting them to send reminder letter only. How can they just summon based on someone else's feedback? But there was none. SG gharmen do many things fr show only. Ty say we hv this n we hv that but most pple never use service so many pple say. ...Wah gharmen so good.... Got this got that. But actually got nothing. Hahaha. Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 14, 2013 Share June 14, 2013 Good advise. Came across a few liow. Most times, tell them headlights not on, they just turn on the small lights and that is it! Really Bo yee eh bian. Fix car at ws very expensive hor. Must save bulbs...battery n alternator. Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear June 14, 2013 Share June 14, 2013 Yawnzz so any one saw lta tp last nite??? Link to post Share on other sites More sharing options...
Orbit78 1st Gear June 15, 2013 Share June 15, 2013 Encounter 1 white Hyundai Avante on CTE with all brake lights not working. Lucky there was a safe distance if not I will have bang into it when it brake hard on highway without brake lights !!! Link to post Share on other sites More sharing options...
Sg2303 2nd Gear June 15, 2013 Author Share June 15, 2013 Encounter 1 white Hyundai Avante on CTE with all brake lights not working. Lucky there was a safe distance if not I will have bang into it when it brake hard on highway without brake lights !!! This is super dangerous! :angry: C'mon everyone. Today before you move out, please check if your brake lights are functioning! Link to post Share on other sites More sharing options...
Meanmachine 6th Gear June 15, 2013 Share June 15, 2013 Most of the time, I have to tell the mechanics what is wrong and what to change. Agreed, we sent for regular servicing, expecting them to do the necessary 12/ 24/33 points check, they never did, Why so ! Simply most take it for granted that since owner are expected to tell mechanic them what is wrong with the car-make do with the folowings, as some owner intend to sell after another 1-2 mths ( awaiting new car arrival. ) By topping up means extra cost to them, some mechanic try too hard by saying your pump oil leak, gasket loose or broken, brake pad abut 40% left, and bold tyre almost gone . . . some are true, some r not. In short, thy try hard, but most owner ' bo chup ' attitude, thinking mechanic trying to fleece us, going forward, thy do tell us anymore. Link to post Share on other sites More sharing options...
Tiger1 6th Gear June 15, 2013 Share June 15, 2013 Sometime the drivers might not even know la. how to check brake light working or not unless u get someone to see for you right? Plus, certain car model quite prone to rear light failure. I have changed 4 times rear left brake light on my wife's swift. Link to post Share on other sites More sharing options...
Sg2303 2nd Gear June 15, 2013 Author Share June 15, 2013 Sometime the drivers might not even know la. how to check brake light working or not unless u get someone to see for you right? Plus, certain car model quite prone to rear light failure. I have changed 4 times rear left brake light on my wife's swift. First post: 1) When reverse-parked in front of a wall, off your lights and observe the wall behind. Switch on your headlights and check your side mirrors. The 2 corners of your car rear should have red light casted on the wall. To check your brake lights, switch off your headlights. Step on the brake and check the side mirrors to see there is red light casted on the wall. 2) When stopped in front of buses (and some big lorries/truck), check your rearview mirror and look at the reflection of your car rear on the windscreen of the bus behind. You can see if your brake lights are working. Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 15, 2013 Share June 15, 2013 First post: 1) When reverse-parked in front of a wall, off your lights and observe the wall behind. Switch on your headlights and check your side mirrors. The 2 corners of your car rear should have red light casted on the wall. To check your brake lights, switch off your headlights. Step on the brake and check the side mirrors to see there is red light casted on the wall. 2) When stopped in front of buses (and some big lorries/truck), check your rearview mirror and look at the reflection of your car rear on the windscreen of the bus behind. You can see if your brake lights are working. Yeah, that's how I discovered one of my brake bulb is blown. Use big bus/truck as "mirror". Link to post Share on other sites More sharing options...
Ihave3Ballz 2nd Gear June 16, 2013 Share June 16, 2013 Yeah, that's how I discovered one of my brake bulb is blown. Use big bus/truck as "mirror". There are many opportunities given to discover your any of light failures. Even left/right signal. It's really some people are just to lazy or blur or"simply fck care attitude". Link to post Share on other sites More sharing options...
Cluboxed 1st Gear June 16, 2013 Share June 16, 2013 some drivers cannot remember to on their headlights at night too... Link to post Share on other sites More sharing options...
Shift_lock 1st Gear June 16, 2013 Share June 16, 2013 some drivers cannot remember to on their headlights at night too... That happened to me before because for my car the instrument panel is always lit whether or not the headlights are on. Driving an altis btw. Link to post Share on other sites More sharing options...
Cluboxed 1st Gear June 16, 2013 Share June 16, 2013 i know of the Altis optitron meter...and a lot of cars nowadays come with this feature as in without activating headlamps, the instrument meters are light up anyway with ignition...but i hope all drivers will still remember to switch on their headlamps before driving off.. Link to post Share on other sites More sharing options...
Penknife 5th Gear June 16, 2013 Share June 16, 2013 well i tink i got to agree on you with this. this makes me wonder if the drivers remember they need to switch on their headlights during 7pm to 7am. Link to post Share on other sites More sharing options...
Celicar Turbocharged June 17, 2013 Share June 17, 2013 Many bikes guilty of blown tail lights. How much can changing bulb cost? If get into accident then definitely not worth it. Really cannot understand. Haiz. ↡ Advertisement Link to post Share on other sites More sharing options...
W212 owners, please check-in
Traffic junction without traffic lights
Electrician lobang?
Electrician lobang?
Grab feature pairing women drivers with women passengers
Christmas lightup 2022!
Singapore Reckless Drivers Part XIV
