Ahgong Supercharged June 15, 2013 Share June 15, 2013 I am wondering if there is a lot of difference if changing the height of the side wall will affect the speedo or the performance of the car? any gurus to advise? ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 15, 2013 Share June 15, 2013 Do a search first before asking question like this. Link to post Share on other sites More sharing options...
Ahgong Supercharged June 15, 2013 Author Share June 15, 2013 Do a search first before asking question like this. Any keyword hint? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear June 15, 2013 Share June 15, 2013 Any keyword hint? Try googling tyre size calculator. It should help. Link to post Share on other sites More sharing options...
Ahgong Supercharged June 16, 2013 Author Share June 16, 2013 Try googling tyre size calculator. It should help. Yah hor! Ok ok. I go check! Link to post Share on other sites More sharing options...
Ahgong Supercharged June 22, 2013 Author Share June 22, 2013 Try googling tyre size calculator. It should help. ok... i have done some homework. as my rims are not original, i am not sure if the speedo and the wheels are actually calibrated. how do i tell if the speed i see on my speedo is the same as the speed that i am actually traveling at? Where can i go to check? Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 23, 2013 Share June 23, 2013 I am wondering if there is a lot of difference if changing the height of the side wall will affect the speedo or the performance of the car? any gurus to advise? sure change, if worry don't change and if changed also don't worry Link to post Share on other sites More sharing options...
BlueOldMan 1st Gear June 23, 2013 Share June 23, 2013 Ohhhhh haze clear Liao leh Link to post Share on other sites More sharing options...
Throttle2 Supersonic June 23, 2013 Share June 23, 2013 I am wondering if there is a lot of difference if changing the height of the side wall will affect the speedo or the performance of the car? any gurus to advise? Not enough difference to be bothered lah. Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged June 23, 2013 Share June 23, 2013 I am wondering if there is a lot of difference if changing the height of the side wall will affect the speedo or the performance of the car? any gurus to advise? U can go carbibles .com for answer.. ↡ Advertisement Link to post Share on other sites More sharing options...
ATF oil change
ATF oil change
Change Disc Rotors
Change Disc Rotors
Would you help to change another car's tyre in another country?
Do I need to change tire ?
