BoneStock 5th Gear June 25, 2013 Share June 25, 2013 Hi folks, I just bought a small car recently and it came with Falken ZE322. These are relatively new with date code Dec 2011 and thread is still very thick. When pumping air, I noticed that the rubber on the tyre valves for all 4 tyres have cracked. So I plan to change out all four tyres ASAP. Need advice from bros here as I am not familiar with 14" tyres. This size seems to be very rare and there are not many choices available. btw, my ride's size is 185 60/R14 Went to check out SgCarstore and found the following tyres 1) Goodyear Assurance 2) Goodyear Duraplus 3) Nexen CP672 4) Pirelli P6 5) Dunlop EC201 6) Kumho Solus KH17 My last 3 sets of tyres are Hankook V8RS and K415, and Kumho KU37. I don't need sporty tyres, just reasonable grip on dry and wet will do. Something similar to K415 standard... Budget below 100 per tyre. Avoid MIC if possible. Thanks very much! ↡ Advertisement Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 25, 2013 Author Share June 25, 2013 forgot to mention....I usually avoid Falken and Yoko Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 25, 2013 Share June 25, 2013 If you worry about cracking GY is out. Read the thread on GY side walls cracking. I always liked Pirelli from what I have seen on their calendars. Never tried their tyres before. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 25, 2013 Share June 25, 2013 Bridgestone tyres are good. AR10 and MY02 got yr size. Should be within yr budget, ask a few tyre shop. Try Kim Hoe at Autobay, Sally pricing very competitive. www.bridgestone.com.sg Link to post Share on other sites More sharing options...
TVT Supercharged June 25, 2013 Share June 25, 2013 forgot to mention....I usually avoid Falken and Yoko Why no Falken and Yokohama leh? Do you mind Malaysian made GY tyres? Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 25, 2013 Author Share June 25, 2013 If you worry about cracking GY is out. Read the thread on GY side walls cracking. I always liked Pirelli from what I have seen on their calendars. Never tried their tyres before. I see. I will take note of that We are driving same ride IIRC. Mind sharing what tyres you using? Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 25, 2013 Author Share June 25, 2013 Bridgestone tyres are good. AR10 and MY02 got yr size. Should be within yr budget, ask a few tyre shop. Try Kim Hoe at Autobay, Sally pricing very competitive. www.bridgestone.com.sg Thanks bro. This is good info, I will check it out My last set of Bridgestone was GR80, before their rapidly rising prices Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 25, 2013 Author Share June 25, 2013 Why no Falken and Yokohama leh? Do you mind Malaysian made GY tyres? Read a lot on these 2 brands and have heard more -ve than +ve. I don't mind MY tyres but if they are prone to cracks then I better stay away Link to post Share on other sites More sharing options...
Jamesc Hypersonic June 25, 2013 Share June 25, 2013 I see. I will take note of that We are driving same ride IIRC. Mind sharing what tyres you using? I am using XM1 on 175/65/14. I find it a very good tyre with very low rates of wear. I think Mich is the company that discovered adding silica to rubber prolongs the life of the tyre and reduces friction. Link to post Share on other sites More sharing options...
SimplyTWL 1st Gear June 25, 2013 Share June 25, 2013 If you worry about cracking GY is out. Read the thread on GY side walls cracking. I always liked Pirelli from what I have seen on their calendars. Never tried their tyres before. Think should avoid Pirelli, my cousin used it previously and commented that the tyre will turn into round or balloon shape after using for awhile. I think Bridgestone Turanza AR-10 should be quite decent. Used it before previously so i will recommend it. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 25, 2013 Share June 25, 2013 Ar-10 are good tyres. Can check out the price from different tyre shop. Good luck! Link to post Share on other sites More sharing options...
ChickenMob 6th Gear June 25, 2013 Share June 25, 2013 if possible try to upsize to 15" last time i also on 14" diffcult to find tyres. Link to post Share on other sites More sharing options...
TJX Turbocharged June 25, 2013 Share June 25, 2013 Tot u r referring to this Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 26, 2013 Author Share June 26, 2013 I am using XM1 on 175/65/14. I find it a very good tyre with very low rates of wear. I think Mich is the company that discovered adding silica to rubber prolongs the life of the tyre and reduces friction. I see. Again, this is very good info. When I switched from Bridgestone to Hankook previously it was also because Hankooks have silica in their tyres as well. Thanks Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 26, 2013 Author Share June 26, 2013 Think should avoid Pirelli, my cousin used it previously and commented that the tyre will turn into round or balloon shape after using for awhile. I think Bridgestone Turanza AR-10 should be quite decent. Used it before previously so i will recommend it. wow didn't know that. Always thought Pirelli is a premium brand. yes, I will be checking out AR10. Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 26, 2013 Author Share June 26, 2013 Ar-10 are good tyres. Can check out the price from different tyre shop. Good luck! thanks bro. I will do that Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 26, 2013 Author Share June 26, 2013 if possible try to upsize to 15" last time i also on 14" diffcult to find tyres. oic. If my ride is newer, I may consider upsizing the rims. But since it only has a few years left, I will stick to 14s and keep the cost low. Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 26, 2013 Author Share June 26, 2013 Tot u r referring to this referring to what? ↡ Advertisement Link to post Share on other sites More sharing options...
Small little tiny bug on walls & ceiling
