  • Search this thread
  • Reply to this topic
50 replies to this topic | 32 praises
#1
Posted 28 June 2013 - 09:18 PM
Tourdefrance
  • THREAD STARTER
  • Tourdefrance
    2nd Gear
    Author Image
    172
Hi all, need your advice on a dangerous situation which I had encountered twice.
My office car park has steep and curving ramps. On two occasions, while I was driving the upward ramp, the car in front of me stopped. When my car moved off from a standstill while on the upward slope, it could not move and the rear wheels kept spinning so much that smoke appeared and there was thick rubber smell. I had to resolve the problem by reversing and moving up again. Fortunately no car was behind my car.
I called my regular mechanic and asked whether it was due to tyre problem and he said it may not be the case because I had changed tyres a year ago. He said the ramp surface may be too smooth or as it was a curve, one of the wheels was not in contact with the road. However, I have never seen other cars having the same problem in the same car park.
My car is rear wheel drive and I had tried to engage low gear whenever I went up slope in the car park after the first incident but it happened again.
Do you think I should change a new set of tyres with better grip?
I search online and read that when negotiating an upward slope after a standstill, a better way is to drive up gently instead of gunning it up as sending too much power to the wheels will cause tyre losing traction.
Other suggested reducing tyre air pressure for better grip.
Any constructive advice is most welcome. Thank you.
#2
Posted 28 June 2013 - 09:22 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    70,691
Whats your tyre made first of all?
Hardened tyre has very or little grip on epoxy painted floor.
QUOTE
do to others what you want others to do to you......
#3
Posted 28 June 2013 - 09:26 PM
Soya
  • Soya
    2Fast2Furious
    Author Image
    28,529
that would sound like a plausible reason. u driving a manual? ur car has traction control?
#4
Posted 28 June 2013 - 09:33 PM
Kiadaw
  • Kiadaw
    Author Image
    9,741
Until you find a solution, one of the thing you can do is to wait for the car in front is fully up & a distance, before you drive up. I personally do not like to stop on a slope.
#5
Posted 28 June 2013 - 09:40 PM
Tourdefrance
  • THREAD STARTER
  • Tourdefrance
    2nd Gear
    Author Image
    172
Hi Hamburger,
My tyres are Goodyear Eagle F1 Asymmetric 2.
#6
Posted 28 June 2013 - 09:54 PM
Tourdefrance
  • THREAD STARTER
  • Tourdefrance
    2nd Gear
    Author Image
    172
Hi Soya,
It is an auto and no traction control
#7
Posted 28 June 2013 - 09:57 PM
Tourdefrance
  • THREAD STARTER
  • Tourdefrance
    2nd Gear
    Author Image
    172
I also hate to stop on a slope. But at times there are "traffic jam" on a slope and I am quite worried now...
#8
Posted 28 June 2013 - 10:10 PM
Ahgong
  • Premium member
    Ahgong
    Author Image
    8,129
for instance like that, doesn't matter you drive auto or manual.
use the handbrake to stop the car from rolling back. release the foot brake and step on the gas till you feel the car "moving" forward, then let go of the handbrake.
it will take a little practice. but once you master it, no problem.
for auto, if you lazy to use handbrake, then you must master holding the brake pedal with your left foot for the same procedure listed above.
#9
Posted 28 June 2013 - 10:18 PM
Cznoob
  • Premium member
    Cznoob
    3rd Gear
    Author Image
    324
Try to just lightly rest your foot on the throttle just enough for the car to hold and simply move on when the road is clear. Dont need to use brake pedal.
#10
Posted 28 June 2013 - 10:19 PM
Tourdefrance
  • THREAD STARTER
  • Tourdefrance
    2nd Gear
    Author Image
    172
Thanks Ahgong,
From the two horrible experience, the more I stepped on it, the more the wheel spin and more smoke and noise. The car just did not move an inch whether forward or backward. I solved the problem by reversed slightly and move on. But I don't think what I did is safe if there are cars behind.
#11
Posted 28 June 2013 - 10:22 PM
Ahgong
  • Premium member
    Ahgong
    Author Image
    8,129
Thanks Ahgong,
like i said, make the handbrake your best friend.
otherwise, master the brake pedal with your left foot.
I have been in similar situations that you described a few times. Mostly at NEX and at the MSCP opp bugis junction.
Works for both manual and auto cars. I drive mostly rentals that time, so tried on both manual and auto and it works.
Driving a manual now. also using the same methods.
most important is dun kan cheong. once you panick, your hand and leg will lose coordination.
Edited by Ahgong, 28 June 2013 - 10:23 PM.
#12
Posted 28 June 2013 - 10:40 PM
Yslim79
  • Premium member
    Yslim79
    4th Gear
    Author Image
    723
Erm, handbrake / foot brake / foot brake helps in preventing roll back on slope.
From TS description, his car is stuck n can't move at all until he engage Reverse.
Could it be the hill assist faulty ? Jz a guess ...
#13
Posted 28 June 2013 - 10:48 PM
Pisces69
  • Premium member
    Pisces69
    2Fast2Furious
    Author Image
    55,390
Hi Soya,
Very simple. Learn to do left foot braking.
Use yr left foot to control e brake n slowly release while slowly increasing yr right foot on accelerator.
Guaranteed smooth starts on even the steepest slopes.
If u drive a manual is harder cos then u wil need to learn heel n toe which is a bit harder to learn n do properly.
Berncsp76 praised this
#14
Posted 28 June 2013 - 11:05 PM
Nemo6089
  • Nemo6089
    4th Gear
    Author Image
    997
Engage low gear and try to softly press the accelerator, should not have this wheel spinning effect.
We spin the wheels only when we do hard pick acceleration.
At low moving off speed should not blame the tires unless your tire are really bald.
#15
Posted 28 June 2013 - 11:06 PM
Nullifi3d
  • Premium member
    Nullifi3d
    6th Gear
    Author Image
    3,295
Winter driving techniques - Dip the clutch:
Should you find the car sliding on a slippery or icy surface, dipping the clutch helps to give you more control over the car. This move cancels all power to the accelerator.
May help?
Deux Ex Machina
#16
Posted 28 June 2013 - 11:16 PM
Ahgong
  • Premium member
    Ahgong
    Author Image
    8,129
May help?
what do you mean by Dip the Clutch?
as in half clutch? That is only good if you are driving manual.
TS is driving auto, the left-foot brake pedal or the handbrake technique are the only choices liow.
#17
Posted 29 June 2013 - 11:02 AM
Tourdefrance
  • THREAD STARTER
  • Tourdefrance
    2nd Gear
    Author Image
    172
Thank you all for the advice.
The general consensus appears to be that in the situation where we have to stop on a steep slope and the car cannot move on despite stepping gas, do the foot brake/gas method - Apply foot brake and slowly release and at the same, gently and gradually step on the gas. Correct me if I am wrong.
#18
Posted 29 June 2013 - 11:21 AM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    70,691
I still think its the rubber compound that has hardened. Thats why GY is never my choice of tyres.
QUOTE
#19
Posted 29 June 2013 - 11:51 AM
Fuelsaver
  • Premium member
    Fuelsaver
    Author Image
    7,820
same situation years back - company pickup wheel spinned as moving up causeway pt cp exit ramp. agree on reduce tire pressure. next big thing would be to feedback to cp mgt but doubt anything be done due to cost.
perhaps this is where FF cars have advantage. so change to FF?
FS
#20
Posted 29 June 2013 - 12:34 PM
Caravan
  • Caravan
    5th Gear
    Author Image
    2,471
Manual transmission is actually easier in this case to modulate the throttle, as you can balance the right foot with the release of the clutch.
For auto trans, you need to pull you handbrake to prevent the car from backwards (if necessary, depending on the steepness of the slope), and most importantly, modulate your throttle input. You need to gently squeeze the gas pedal, and if you feel that the tyres is slipping, release the gas pedal and gently squeeze again. Doing this repeatedly should get you moving without too much wheel spin.
Back to General Car Discussion  ·  Cars Top Reply to this topic
SgCarMart Quotz
Quick Reply
Tags: advice needed and 3 more...
