Install bose system
Rexxxer
Hi guys,
Do you know who Can help to install speaker to feature wall.should i call carpenter or techician?
as i bought my system oversea so do not know if local consultant will help
Which model?
You will only need a carpenter if you want the speakers to be as invisible as possible. A carpenter will need to build around your speakers to make them blend in.
Otherwise, whether your speakers are powered or passive, the connections are straightforward. Even my grandma can connect up speakers.
But without building around them, you have to find ways of running the cables so that they're not messy, like using trunking or running them behind your existing furniture...etc.
I think carpenter. First of all, speaker no need special wiring. Just wires connected to the int amp. You need the carpenter to cater the design to adapt to the speaker. Just know the specs and dimension and how it should be mounted.
