Drive 1st Gear July 22, 2013 Share July 22, 2013 (edited) Hi Any idea where can I get those black hoses (9-15mm internal diameter) and plugs that can withstand heat in engine bay? Tried those regular plastic ones from hardware shops but cannot stand the heat. Any shops that specialise in hoses and plugs? Tks Edited July 22, 2013 by Drive ↡ Advertisement Link to post Share on other sites More sharing options...
Ooosh 1st Gear July 22, 2013 Share July 22, 2013 (edited) Can try those hardware shops near sungei/rochor road. Or you can go to auto supplies shop at veerasamy rd.. If you wan those that can withstand heat, go for silicon hose...that you might have to buy online cheaper Edited July 22, 2013 by Ooosh Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 22, 2013 Share July 22, 2013 It all depend on on the applications, there are many types of hose and tubes for the engine bay and undercarriage. Link to post Share on other sites More sharing options...
Drive 1st Gear July 26, 2013 Author Share July 26, 2013 Tks, any specific shops? Link to post Share on other sites More sharing options...
Spin37gy Neutral Newbie July 26, 2013 Share July 26, 2013 Hose doctor...they got all lengths and on site service as well.. Link to post Share on other sites More sharing options...
Drive 1st Gear May 11, 2017 Author Share May 11, 2017 Still looking. Now looking for those heat resistant corrugated (flexible) hoses similar to this: Link to post Share on other sites More sharing options...
SpeedyJIM Clutched May 11, 2017 Share May 11, 2017 Use GATES fuel injection hose. I know of a particular hose 225psi but quite expensive I bought 7.62M for like $120 Link to post Share on other sites More sharing options...
Drive 1st Gear May 12, 2017 Author Share May 12, 2017 Use GATES fuel injection hose. I know of a particular hose 225psi but quite expensive I bought 7.62M for like $120 Hi Where to get this? Link to post Share on other sites More sharing options...
Watwheels Supersonic May 12, 2017 Share May 12, 2017 (edited) You can use fuel line hoses. You can get it from "Able Hydraulic & Industrial Supply". Google for address. I believe the pic of your hose is a PCV return hose. You can use any fuel type of flexible rubber hose. The shop above will have it. It will be able to withstand heat, oil, fuel vapours and it's reinforced to withstand pressure or vacuum. Edited May 12, 2017 by Watwheels Link to post Share on other sites More sharing options...
Kb27 Supersonic May 12, 2017 Share May 12, 2017 Depends on your application. Silicone hose may be what you need. It can withstand high temp and doesn't breakdown. However, if you're using it for vacuum, it needs to be thicker. My ws put a rubber plug on a hot coolant hose and it breaks down within a couple of months. I replaced it with silicone plug and it was still intact when I scrapped the van. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 12, 2017 Share May 12, 2017 Depends on your application. Silicone hose may be what you need. It can withstand high temp and doesn't breakdown. However, if you're using it for vacuum, it needs to be thicker. My ws put a rubber plug on a hot coolant hose and it breaks down within a couple of months. I replaced it with silicone plug and it was still intact when I scrapped the van. Silicone hose is not suitable for oil or fuel vapours. Air and water still ok. The hose TS posted is a PCV return hose. The contents are not just hot air but also hot engine oil and fuel vapours. Link to post Share on other sites More sharing options...
SpeedyJIM Clutched May 12, 2017 Share May 12, 2017 Hi Where to get this? I get thru this stockist ah teo.. his no 91394756 ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
