Kwoni 1st Gear December 16, 2016 Share December 16, 2016 you can use the paddle shifters for sure. i used to use it quite often but got lazy after a while. what i explained was in layman terms for what i felt was different with the chip and in the diff settings the official website describes the modifications differently, which may or may not be achievable by just us using the paddle shifters. "RSchip is an additional control unit, which modifies the engine's factory settings responsible for fuel injections and ignition timing advance in order to maximize power and torque" Yup torque may increase a bit if the air fuel ratio is adjusted at whichever rpm in the programme. Ignition timing only improve response of your engine but not the power. So your car will appear responsive and faster pickup but acceleration wise still about the same. All thes eare also limited by your engine's peak performance so there is still a max in what you can do, unless u totally map out the data log in the ecu. ↡ Advertisement Link to post Share on other sites More sharing options...
Kelby 2nd Gear December 16, 2016 Share December 16, 2016 Which aftermarket is semi? Or legalised for K3? For sure super sprint k3 cannot install. C&c took 10 mins from taking over my car and back out to change engine oil. First thing they do is unpluck your in car camera. So i assumed they drove into service bay,jack up, drain old EO, pump and pour new EO, jack down and drive out but it was left parked outside blocking their shuttle bus lane and he came asking the owner to shift the car then realized my car was already done. The service center was packed to the max during sending in. I waited for 40mins for nothing. Express service done in 10 mins but collect 50 mins later and nobody knew if my car was serviced at all. Kinda lousy service by them.10 min that is fast where are all the point checks? Link to post Share on other sites More sharing options...
Stooky 6th Gear December 16, 2016 Share December 16, 2016 (edited) Very nice K3! Owner mod till so chio. With BBK,19" rims, quad exhaust and bodykit https://www.facebook.com/htyre.sg/photos/a.1305150699507118.1073742218.146948645327335/1305150772840444/?type=3&theater Edited December 16, 2016 by Stooky Link to post Share on other sites More sharing options...
Hhondafit 1st Gear December 16, 2016 Share December 16, 2016 By right is illegal, by left is legal cause it is hidden and still using the same muffler. Only thing is inside is different from stock. Honestly, if one is worried about warranty and legality...then one should just stay with stock standard and just live with it. I did b4 previously and fail inspection thus asking for legal pipes. I am not really concern with warranty issue. Gd dayI didDo u know the led dimension that was fitted on the map light Link to post Share on other sites More sharing options...
limzanat Neutral Newbie December 16, 2016 Share December 16, 2016 Yup torque may increase a bit if the air fuel ratio is adjusted at whichever rpm in the programme. Ignition timing only improve response of your engine but not the power. So your car will appear responsive and faster pickup but acceleration wise still about the same. All thes eare also limited by your engine's peak performance so there is still a max in what you can do, unless u totally map out the data log in the ecu.So worth it to try ? Link to post Share on other sites More sharing options...
BullsEye 1st Gear December 16, 2016 Share December 16, 2016 (edited) Just to share my LED makeover since I got my pre-FL K3 in Jan 2016. Share some poison. Interior LED. Full Phlilps LED, Festoon 30mm (6000K). Philips 1 LED is enough to make your night into day light, they are really bright. Trust me. Slightly more expensive, but totally worth it. Phlilps LED, Festoon 30mm: 2 Front Reading Lights and 1 Centre Cabin light. See how bright it gets. Phlilps LED, Festoon 30mm: Mirror lights for both side LED lights for leg room: Philips LED T10 (4300K): License Plate Osram HID 6000K: Pure white and bright, with nice cut off light without blinding oncoming traffic I support Philips and Osram products as they are really worth the money. Thank you for viewing! Edited December 16, 2016 by BullsEye 2 Link to post Share on other sites More sharing options...
ricleosg 4th Gear December 16, 2016 Share December 16, 2016 So worth it to try ? to me it's worth it as whilst it's probably not possible to increase maximum power to the 1.6L NA engine by much, i feel the RSchip brings on the power earlier and more efficiently then the stock ECU settings, and that makes a very noticeable difference in your day to day driving in Singapore. Link to post Share on other sites More sharing options...
limzanat Neutral Newbie December 16, 2016 Share December 16, 2016 to me it's worth it as whilst it's probably not possible to increase maximum power to the 1.6L NA engine by much, i feel the RSchip brings on the power earlier and more efficiently then the stock ECU settings, and that makes a very noticeable difference in your day to day driving in Singapore.So does it void the warrentty ? Link to post Share on other sites More sharing options...
ricleosg 4th Gear December 16, 2016 Share December 16, 2016 So does it void the warrentty ? nope. plug n play obd2. just remove if you need servicing when something is wrong? Link to post Share on other sites More sharing options...
Multi 3rd Gear December 16, 2016 Share December 16, 2016 I did b4 previously and fail inspection thus asking for legal pipes. I am not really concern with warranty issue. Gd day Do u know the led dimension that was fitted on the map light Bro, don't get angry leh...I'm not refering to you lah. Link to post Share on other sites More sharing options...
Kelby 2nd Gear December 16, 2016 Share December 16, 2016 Just to share my LED makeover since I got my pre-FL K3 in Jan 2016. Share some poison. Interior LED. Full Phlilps LED, Festoon 30mm (6000K). Philips 1 LED is enough to make your night into day light, they are really bright. Trust me. Slightly more expensive, but totally worth it. Photo 16-12-16, 8 30 36 PM.jpg Phlilps LED, Festoon 30mm: 2 Front Reading Lights and 1 Centre Cabin light. See how bright it gets. Photo 16-12-16, 8 31 46 PM.jpg Photo 16-12-16, 8 34 55 PM.jpg Phlilps LED, Festoon 30mm: Mirror lights for both side Photo 16-12-16, 8 32 42 PM.jpg LED lights for leg room: Photo 16-12-16, 8 34 17 PM.jpg Photo 16-12-16, 8 31 58 PM.jpg Philips LED T10 (4300K): License Plate Photo 16-12-16, 8 40 28 PM.jpg Osram HID 6000K: Photo 16-12-16, 8 41 10 PM.jpg Pure white and bright, with nice cut off light without blinding oncoming traffic Photo 16-12-16, 8 40 38 PM.jpg I support Philips and Osram products as they are really worth the money. Thank you for viewing! Where to buy this? Plug and play? Link to post Share on other sites More sharing options...
Hhondafit 1st Gear December 16, 2016 Share December 16, 2016 Just to share my LED makeover since I got my pre-FL K3 in Jan 2016. Share some poison. Interior LED. Full Phlilps LED, Festoon 30mm (6000K). Philips 1 LED is enough to make your night into day light, they are really bright. Trust me. Slightly more expensive, but totally worth it. Photo 16-12-16, 8 30 36 PM.jpg Phlilps LED, Festoon 30mm: 2 Front Reading Lights and 1 Centre Cabin light. See how bright it gets. Photo 16-12-16, 8 31 46 PM.jpg Photo 16-12-16, 8 34 55 PM.jpg Phlilps LED, Festoon 30mm: Mirror lights for both side Photo 16-12-16, 8 32 42 PM.jpg LED lights for leg room: Photo 16-12-16, 8 34 17 PM.jpg Photo 16-12-16, 8 31 58 PM.jpg Philips LED T10 (4300K): License Plate Photo 16-12-16, 8 40 28 PM.jpg Osram HID 6000K: Photo 16-12-16, 8 41 10 PM.jpg Pure white and bright, with nice cut off light without blinding oncoming traffic Photo 16-12-16, 8 40 38 PM.jpg I support Philips and Osram products as they are really worth the money. Thank you for viewing! Really bright. Cost abt 13bucks each b4 shipping Bro, don't get angry leh...I'm not refering to you lah. Ok ok. Not angry la. Chill. Haha Link to post Share on other sites More sharing options...
Hhondafit 1st Gear December 16, 2016 Share December 16, 2016 Just to share my LED makeover since I got my pre-FL K3 in Jan 2016. Share some poison. Interior LED. Full Phlilps LED, Festoon 30mm (6000K). Philips 1 LED is enough to make your night into day light, they are really bright. Trust me. Slightly more expensive, but totally worth it. Photo 16-12-16, 8 30 36 PM.jpg Phlilps LED, Festoon 30mm: 2 Front Reading Lights and 1 Centre Cabin light. See how bright it gets. Photo 16-12-16, 8 31 46 PM.jpg Photo 16-12-16, 8 34 55 PM.jpg Phlilps LED, Festoon 30mm: Mirror lights for both side Photo 16-12-16, 8 32 42 PM.jpg LED lights for leg room: Photo 16-12-16, 8 34 17 PM.jpg Photo 16-12-16, 8 31 58 PM.jpg Philips LED T10 (4300K): License Plate Photo 16-12-16, 8 40 28 PM.jpg Osram HID 6000K: Photo 16-12-16, 8 41 10 PM.jpg Pure white and bright, with nice cut off light without blinding oncoming traffic Photo 16-12-16, 8 40 38 PM.jpg I support Philips and Osram products as they are really worth the money. Thank you for viewing! Bro, where did u buy the philip bulb from and price? Thanks Link to post Share on other sites More sharing options...
Whattheheck 2nd Gear December 17, 2016 Share December 17, 2016 Lol. Can download and make into a mini paper Kia K3 model sia. car-template-kia.pdf car-template-kia.pdf 1 Link to post Share on other sites More sharing options...
scizorsim 3rd Gear December 17, 2016 Share December 17, 2016 My preFL side mirrors dont close when locking the car now? Is there a setting or something is off :/ Link to post Share on other sites More sharing options...
BullsEye 1st Gear December 17, 2016 Share December 17, 2016 My preFL side mirrors dont close when locking the car now? Is there a setting or something is off :/Did you put the switch to Auto? Only auto then will close when locking car 1 Link to post Share on other sites More sharing options...
ricleosg 4th Gear December 17, 2016 Share December 17, 2016 Did you put the switch to Auto? Only auto then will close when locking carThats my guess too. Bull's eye! 1 Link to post Share on other sites More sharing options...
BullsEye 1st Gear December 17, 2016 Share December 17, 2016 Bro, where did u buy the philip bulb from and price? ThanksI got my bulbs from PowerBulbs.com. Free shipping from UK. Cheaper than most shops in Singapore. ↡ Advertisement Link to post Share on other sites More sharing options...
RE :Jaguar Owners Servicing
Kia EV9 Concept
Kia EV9 Concept
Kia Stonic
Kia Stonic
W212 owners, please check-in
