Joemit7850 1st Gear July 29, 2013 Share July 29, 2013 Hi I just change my Amazon battery less than 10 month ago from AA, however, yesterday the batt is weak and I could not start and get AA mechanical to come down and check, he managed to jumpstart and check, his reason was the car electronic fault and not the battery, the car electronic eg: Sound system, light, video camera etc are drawing current from the battery even through the car engine is off. I try to drive the car for at least 30min after he jumpstart to charge the battery. This morning my car could not start again, I am now waiting for AA to come and jumpstart again, Can someone advise , is it possible on what the AA mechanical have claim? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Lowrider 2nd Gear July 29, 2013 Share July 29, 2013 The AA mechanic could be right. You have something drawing current from the battery at all times. Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 29, 2013 Share July 29, 2013 Hi I just change my Amazon battery less than 10 month ago from AA, however, yesterday the batt is weak and I could not start and get AA mechanical to come down and check, he managed to jumpstart and check, his reason was the car electronic fault and not the battery, the car electronic eg: Sound system, light, video camera etc are drawing current from the battery even through the car engine is off. I try to drive the car for at least 30min after he jumpstart to charge the battery. This morning my car could not start again, I am now waiting for AA to come and jumpstart again, Can someone advise , is it possible on what the AA mechanical have claim? Thanks There will be parasitic power loss and there will some some electronic devices like immobiliser (if not, how is your remote able to unlock car?) that continue to draw small amount of current even when engine is off and doors locked. Always a good habit to physically off radio, aircon blower, pull out devices from 12V sockets........ Link to post Share on other sites More sharing options...
Lowrider 2nd Gear July 29, 2013 Share July 29, 2013 When you have a chance you might wanna buy a jumper cable so that you can jumpstart your car from anybody around your area... Link to post Share on other sites More sharing options...
Kb27 Supersonic July 29, 2013 Share July 29, 2013 Check for parasitic current drawn, after everything is switched off. It should not be more than 80 mA. If AA can't do check, you need to find workshop. Otherwise, the battery may have a fault of not retaining charge. Link to post Share on other sites More sharing options...
Joemit7850 1st Gear July 29, 2013 Author Share July 29, 2013 but I got this sound system since I bought this car 3 yrs ago and even all the electronic devices except the camera which I install about 2 yrs ago, all the while I do not have any problem with the battery only need to change every year , could it still be the problem thanks guys Link to post Share on other sites More sharing options...
Kurty Supercharged July 29, 2013 Share July 29, 2013 Somewhere in the ice, is depleting the battery.. Either you redo the wiring, change of ice, or just have a simple switch to totally cut off the power when you exit the car. Link to post Share on other sites More sharing options...
Jman888 Moderator July 29, 2013 Share July 29, 2013 Amazon battery? i also just had AA came to the rescue when my battery died last week, he jump start for me claim connection loose, then after he left i couldn't start again, the same guy came back and test again and confirm the battery was dead even though the 'reader' show healthy. my batter was about 2 years and i have no gadget in the car the stock sound system. The battery guy say nowadays some car battery only last less than 1 year. but I got this sound system since I bought this car 3 yrs ago and even all the electronic devices except the camera which I install about 2 yrs ago, all the while I do not have any problem with the battery only need to change every year , could it still be the problem thanks guys Link to post Share on other sites More sharing options...
Cheesepiekia 5th Gear July 29, 2013 Share July 29, 2013 Check your alternator, maybe it's not charging your battery. Link to post Share on other sites More sharing options...
Lowrider 2nd Gear July 29, 2013 Share July 29, 2013 Check your alternator, maybe it's not charging your battery. Warning light would be on if this is the case... Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 29, 2013 Share July 29, 2013 With engine ignition off, pull out the suspect acc fuse from the fuse box and plug in this fuse tester. If the current is still flowing, the display will show the amount of amp drawn. From here you can trace back to the acc and do wire connections isolation test.Chaces there is a slight short or live wire grounded. Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear July 29, 2013 Share July 29, 2013 I have bought this at SG $60. Very handy. Can also charge iphone 20x and laptop dun how many time. Best can jumpstart car. Autobac sell this at $198. Prove can jump start a car. Review mostly say can. http://item.taobao.com/item.htm?spm=a230r....;id=25368492243 Do not try on Subaru car. I have two friend that both driving Subaru car and once they jumpstart, their circuit board is burnt. So do jumpstart on Subaru car. (Hope that I was wrong). Back to ypur question. Usually ICE dun draw power when engine is off (unless your installer use the main battery power and not ACC power). Best to install a Capacitor and Raizin voltage stabilizer. Alarm and 24hr camera will draw power when car is off. I have install a mini voltmeter in the car and always monitor it before and during driving to see the voltage. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 29, 2013 Share July 29, 2013 Every car will draw some current away from the battery when its engine is not running. But the power drawn is very min..for stock accessories. Like your original hi fi...clock...ECU etc... But if you have a lot of accessories to your car like DVR etc...it can flatten the battery depending on how much amp the accessory is drawing. Check this...a friend who had his battery flat once every few weeks even when he change new battery was trace down to a faulty door switch...which kept his boot light on 24/7. That was why he had to change battery once every few months. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear July 29, 2013 Share July 29, 2013 IU unit with Cash card in will draw power. Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear July 29, 2013 Share July 29, 2013 (edited) My current setup in Vios 08 car running on 45mAH battery. 1. Pioneer DEH P80 Headunit (act as Active Processor). 2. Pioneer P8450BT DVD headunit. 3. 1 x Capacitor 4. 1 set of Focal KR2 speaker (tweeter + speaker) 5. 1 set of rear Pioneer speaker 6. Roadnavi GPS module (Papagao) to connect to my Pioneer P8450BT DVD headunit 7. DVBT module to Pioneer P8450BT DVD headunit 8. 1 x Focal 4.75 amp 9. 1 x Soundstream lil' Wondr 500W Monobloc 10. Soundstream 12' Woofer (Ported enclosure) 11. EasyCar 772A car alarm (keyless entry with push start system) 12. ITB 100HD in dash camera. 13. All door LED door pointer. 14. All Leg room LED 15. Reverse CCD + Front CCD camera with auto switch module connect to Pioneer P8450BT DVD headunit. 16. Rear mirror LCD screen (Not Use now) 17. Pivot Raizin voltage stabilzer 18. Mini voltmeter. All these when turn on ACC voltage is at 12.5V. When driving, my voltage is at 13.2V. What I have in my car that is totally conceal: 1 x 1l fire extinguisher. 1 x small First aid box. 1 x very small pack of electronic tire pump with repair sealant 1 x Jump start kit as seen above thread. All of the above installation is entirely hidden and cannot see at all, except for my DVD Head unit and speaker of cos. Edited July 29, 2013 by Gdspd08 Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 29, 2013 Share July 29, 2013 IU unit with Cash card in will draw power. YUP, will draw window smasher also. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 29, 2013 Share July 29, 2013 My current setup in Vios 08 car running on 45mAH battery. 1. Pioneer DEH P80 Headunit (act as Active Processor). 2. Pioneer P8450BT DVD headunit. 3. 1 x Capacitor 4. 1 set of Focal KR2 speaker (tweeter + speaker) 5. 1 set of rear Pioneer speaker 6. Roadnavi GPS module (Papagao) to connect to my Pioneer P8450BT DVD headunit 7. DVBT module to Pioneer P8450BT DVD headunit 8. 1 x Focal 4.75 amp 9. 1 x Soundstream lil' Wondr 500W Monobloc 10. Soundstream 12' Woofer (Ported enclosure) 11. EasyCar 772A car alarm (keyless entry with push start system) 12. ITB 100HD in dash camera. 13. All door LED door pointer. 14. All Leg room LED 15. Reverse CCD + Front CCD camera with auto switch module connect to Pioneer P8450BT DVD headunit. 16. Rear mirror LCD screen (Not Use now) 17. Pivot Raizin voltage stabilzer 18. Mini voltmeter. All these when turn on ACC voltage is at 12.5V. When driving, my voltage is at 13.2V. What I have in my car that is totally conceal: 1 x 1l fire extinguisher. 1 x small First aid box. 1 x very small pack of electronic tire pump with repair sealant 1 x Jump start kit as seen above thread. All of the above installation is entirely hidden and cannot see at all, except for my DVD Head unit and speaker of cos. LoL...no wonder your batt life is short. Even if you did not have this problem in the past but becoz of the heavy load, things like the alternator will deteriorate over time. Some ppl I know they told me after they dekit their car it is much livelier to drive. That's why I keep things stock in my car. Batt can last 2 years or more. If you search you will find many ppl batt is short lived and alternator up lorry and most likely they have all kinds of things setup in their car. Link to post Share on other sites More sharing options...
Columbian78 6th Gear July 29, 2013 Share July 29, 2013 Hi I just change my Amazon battery less than 10 month ago from AA, however, yesterday the batt is weak and I could not start and get AA mechanical to come down and check, he managed to jumpstart and check, his reason was the car electronic fault and not the battery, the car electronic eg: Sound system, light, video camera etc are drawing current from the battery even through the car engine is off. I try to drive the car for at least 30min after he jumpstart to charge the battery. This morning my car could not start again, I am now waiting for AA to come and jumpstart again, Can someone advise , is it possible on what the AA mechanical have claim? Thanks Was the video camera installed recently? Is the socket that the power cable is plugged into connected directly to the car battery. This means the camera is powered on even when you turn off the engine and leave the car. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Cars at Expo - Apr 2024
Battery Voltage up & down
My EV journey to the i4
