Carlolaborte Neutral Newbie August 29, 2016 Share August 29, 2016 Update on my issue: checked and confirmed is the clock spring issue(seems to b a common problem for sylphy). Replaced with a new 1, with labor costs $390Clock spring problem common for Nissan. My Qashqai also kena same problem 2mos ago. Streering wheel buttons works only at certain angles. But mine under warranty...TC replaced FOC. But it took 5mos to order the spare parts as they dont have stock here in SG. All imported from Japan...so prepare to wait long long... ↡ Advertisement Link to post Share on other sites More sharing options...
Hbng Neutral Newbie August 29, 2016 Share August 29, 2016 Hi Brudders, I am considering to buy a second hand Latio or Slyphy. I know its 2 very different cars but I would like to know what is the fuel consumption. I seem to get conflicting reviews on the net. Any advice? Link to post Share on other sites More sharing options...
ValentinoRyan 1st Gear August 30, 2016 Share August 30, 2016 Hi Brudders, I am considering to buy a second hand Latio or Slyphy. I know its 2 very different cars but I would like to know what is the fuel consumption. I seem to get conflicting reviews on the net. Any advice? Both cars are fuel efficient, just have to take note of CVT gearbox and have to be well maintained. Just test drive them and see how the gearbox shift it's gear by monitoring the RPM level. Link to post Share on other sites More sharing options...
Carlolaborte Neutral Newbie August 30, 2016 Share August 30, 2016 Hi Bros, i recently encountered a problem with my intelligent key system. Noticed this past few days that the car is not responding when i press the lock/unlock button on my ikey. The door also is not locking/unlocking when i press the button on yhe door handle even if the key is within range (1 foot away). What more is that when i enter the car, i cannot start the engine as the sensor does not detect the key inside the car. I thought it was the ikey battery at first, tried to change it but also the same. Also got the car battery checked on my recent servicing, still ok. The funny thing is that it only has this problem when I park my car at my house MSCP only!!! When i tried on other locations like open carpark, my child school carpark, office carpark and other MSCP, its ok? Im really quite puzzled. Could it be there is a signal problem at our place? Or is it the sensor problem or the key problem? Any bros experienced the same issue? Just to let you know, the key system is working fine during the past months on my house MSCP. It is only these few days that i started noticing this problem... Thanks bros! Link to post Share on other sites More sharing options...
Yymail22 2nd Gear August 30, 2016 Share August 30, 2016 Clock spring problem common for Nissan. My Qashqai also kena same problem 2mos ago. Streering wheel buttons works only at certain angles. But mine under warranty...TC replaced FOC. But it took 5mos to order the spare parts as they dont have stock here in SG. All imported from Japan...so prepare to wait long long... Link to post Share on other sites More sharing options...
Carlolaborte Neutral Newbie August 31, 2016 Share August 31, 2016 Hi Brudders, I am considering to buy a second hand Latio or Slyphy. I know its 2 very different cars but I would like to know what is the fuel consumption. I seem to get conflicting reviews on the net. Any advice?Hi bro, i drive latio before, quite decent FC. If light footed can reach up to 15km/ltr. Low maintainance as well. For sylphy, not quite sure, i heard the 1500cc version of sylphy laks power due to the large body. FC most likely to be on the high side.... Link to post Share on other sites More sharing options...
slfaichnie Neutral Newbie September 24, 2016 Share September 24, 2016 Good Afternoon, I am needing some urgent advice. I own a a 2004 Nissan Presage 2.5l (QR25de motor) Auto. Four weeks ago, I noticed it was running poorly. It has been running perfectly for the 3 years I owned it. it has 164k on the clock. I took it to the mechanics and they looked into what was the issue. They found that I had a blocked Catalytic Converter and took it out. There is no need to have one in for NZ. I brought the car home, and noticed that is was a little smokey, i rung and they said that it was ok, it was normal as it was burning stuff from the exhaust. I asked for it to go back, and have an oil change. I brought it home after the oil change, and they had passed comment that the oil was sludgy, and that was probably the cause of the blocked converter. I drove 600kms in the car, and noticed that the smoke had not lessened, and also that the oil that they had put in, had disappeared. I rung and asked if they did put oil in, and they said yes, it was Castrol Magnatech 10w40. My specs ask that we use 15w30 and they said that it wasn't going to make a difference. I topped up the oil, with the 15w40 that I had, and continued to drive it. It wouldn't go one morning, and I had to call an Auto sparky, who plugged in a computer, and found the error code for a CPS sensor. This was replaced, and he passed comment that the CPS sensor was sludgy again. After some research, I found that a PCV valve, plays a very important part, and that this being faulty can cause the oil to be sludgy. I took it back to the mechanic and asked for them to replace this part. They rung to say, that yes, the mechanic has taken the valve out and you are correct that this part needs to be replaced. They would order one in. at this stage around 1000kms had been done, and around 6 litres of oil had gone missing in the car - assumed burnt) Hopefully you have all kept up with me to here: Now, the mechanic rings yesterday and says, that they have replaced the PCV valve in the car but when the started the motor up, the oil came out through the dipstick tube, and the air house/filter. they wore quite a bit of it and said they think they found the missing oil. They also run a compression test and some stage, and it was even. slightly low, but it was even. They didn't give me the figures, (but research shows that I supposed to have a result of 9.5:1) and also they have put the bore scope down the pistons, and they seem to all look fine. They took off a cover, and rung to say, that they want to look into it further now, and look at valve guides, and valve seals, and we could be looking at a replacement head, (10hrs of labour) or an engine conversion (10hours and $2500). We asked them to stop work on the car till we get some more information. My biggest question is: That with the history that I have written above and the series of events, the PCV valve was the issue in the very first place. It should have been replaced immediately. It was probably the cause of the converter blocking and sludgy oil from the start. Now, my understanding is, that the PCV valve release pressure and the gas? that builds up, out of the crankcase. If this isn't working than that builds up. Wouldn't it be normal that with the installation of a new PCV valve, that the oil and pressure was released, and now that that has been done, give the engine a really good flush to remove as much sludge as possible, and change oil filter and put in clean fresh oil, and it shouldn't blow back again because the PCV will now work efficently? We have also replaced all spark plugs, and two coils in the last 3 weeks of this all going on? I just feel that we can't have done so much damage since we were on to it pretty fast, and that if we did what we suggested that the car may just run again. The mechanic hasn't done this, he wants to pull it apart to the head and look into further damage, cos his assumption is that that the oil has been pushed through the motor and already caused excessive damage, and he needs to investigate. I want him to put it back together, with a complete flush, new oil and see how it runs. It was a perfect car before 3/4 weeks ago, and never missed a beat - can we really have done that and technically blown up the engine in such a short space of time? I may be completely wrong and eat my hat if i do, but just feel that this is really excessive all of a sudden, and my total honest opinion is that they should be coping half the blame that they never picked up on the PCV valve to start with, from the blocked catalytic converter and never investigated into the sludgy oil. I basically told them to replace a part, that they didn't even consider. (I am quite pissy about that). My mechanic is no backstreet country hobo either, it goes to a Nissan Franchised mechanic where we pay over $100 per hour!!! Please leave any information that can help my situation, and whether you agree or disagree with my situation. I think i know my car, and read a lot about this motor, but I don' t feel i know enough to now tell the mechanic to put it back together, with a full service and drive it. I am needing a second opinion or advice on what to do next. (Mother of four children, living in the counrtyside dream, needing my family car very urgently) Link to post Share on other sites More sharing options...
Pocy Hypersonic September 24, 2016 Share September 24, 2016 Good Afternoon, I am needing some urgent advice. I own a a 2004 Nissan Presage 2.5l (QR25de motor) Auto. Four weeks ago, I noticed it was running poorly. It has been running perfectly for the 3 years I owned it. it has 164k on the clock. I took it to the mechanics and they looked into what was the issue. They found that I had a blocked Catalytic Converter and took it out. There is no need to have one in for NZ. I brought the car home, and noticed that is was a little smokey, i rung and they said that it was ok, it was normal as it was burning stuff from the exhaust. I asked for it to go back, and have an oil change. I brought it home after the oil change, and they had passed comment that the oil was sludgy, and that was probably the cause of the blocked converter. I drove 600kms in the car, and noticed that the smoke had not lessened, and also that the oil that they had put in, had disappeared. I rung and asked if they did put oil in, and they said yes, it was Castrol Magnatech 10w40. My specs ask that we use 15w30 and they said that it wasn't going to make a difference. I topped up the oil, with the 15w40 that I had, and continued to drive it. It wouldn't go one morning, and I had to call an Auto sparky, who plugged in a computer, and found the error code for a CPS sensor. This was replaced, and he passed comment that the CPS sensor was sludgy again. After some research, I found that a PCV valve, plays a very important part, and that this being faulty can cause the oil to be sludgy. I took it back to the mechanic and asked for them to replace this part. They rung to say, that yes, the mechanic has taken the valve out and you are correct that this part needs to be replaced. They would order one in. at this stage around 1000kms had been done, and around 6 litres of oil had gone missing in the car - assumed burnt) Hopefully you have all kept up with me to here: Now, the mechanic rings yesterday and says, that they have replaced the PCV valve in the car but when the started the motor up, the oil came out through the dipstick tube, and the air house/filter. they wore quite a bit of it and said they think they found the missing oil. They also run a compression test and some stage, and it was even. slightly low, but it was even. They didn't give me the figures, (but research shows that I supposed to have a result of 9.5:1) and also they have put the bore scope down the pistons, and they seem to all look fine. They took off a cover, and rung to say, that they want to look into it further now, and look at valve guides, and valve seals, and we could be looking at a replacement head, (10hrs of labour) or an engine conversion (10hours and $2500). We asked them to stop work on the car till we get some more information. My biggest question is: That with the history that I have written above and the series of events, the PCV valve was the issue in the very first place. It should have been replaced immediately. It was probably the cause of the converter blocking and sludgy oil from the start. Now, my understanding is, that the PCV valve release pressure and the gas? that builds up, out of the crankcase. If this isn't working than that builds up. Wouldn't it be normal that with the installation of a new PCV valve, that the oil and pressure was released, and now that that has been done, give the engine a really good flush to remove as much sludge as possible, and change oil filter and put in clean fresh oil, and it shouldn't blow back again because the PCV will now work efficently? We have also replaced all spark plugs, and two coils in the last 3 weeks of this all going on? I just feel that we can't have done so much damage since we were on to it pretty fast, and that if we did what we suggested that the car may just run again. The mechanic hasn't done this, he wants to pull it apart to the head and look into further damage, cos his assumption is that that the oil has been pushed through the motor and already caused excessive damage, and he needs to investigate. I want him to put it back together, with a complete flush, new oil and see how it runs. It was a perfect car before 3/4 weeks ago, and never missed a beat - can we really have done that and technically blown up the engine in such a short space of time? I may be completely wrong and eat my hat if i do, but just feel that this is really excessive all of a sudden, and my total honest opinion is that they should be coping half the blame that they never picked up on the PCV valve to start with, from the blocked catalytic converter and never investigated into the sludgy oil. I basically told them to replace a part, that they didn't even consider. (I am quite pissy about that). My mechanic is no backstreet country hobo either, it goes to a Nissan Franchised mechanic where we pay over $100 per hour!!! Please leave any information that can help my situation, and whether you agree or disagree with my situation. I think i know my car, and read a lot about this motor, but I don' t feel i know enough to now tell the mechanic to put it back together, with a full service and drive it. I am needing a second opinion or advice on what to do next. (Mother of four children, living in the counrtyside dream, needing my family car very urgently) Did you consider going back to Nissan TCM after all those unsuccessful attempts by outside experts? At least for an opinion from the AD. I doubt there is any such expert from a car forum. You may just got some past experiences which might not be exactly the same situation. Just my humble view. Link to post Share on other sites More sharing options...
qqsaw Clutched September 24, 2016 Share September 24, 2016 Clock spring problem common for Nissan. My Qashqai also kena same problem 2mos ago. Streering wheel buttons works only at certain angles. But mine under warranty...TC replaced FOC. But it took 5mos to order the spare parts as they dont have stock here in SG. All imported from Japan...so prepare to wait long long... ðHad same problem. My ws quoted me $280 to replace ( incl labour). So i went to youtube and saw video on how to replace clockspring. Then i bought original part from nissan part supplier ($190) and replaced it myself. I had to buy a couple of tools (total cost abt $30) and managed to change it myself. Not too difficult. Took me abt 2hrs but it was successful. Now my horn works and no blinking airbag light. Also felt very satisfied at my own effort. Youtube link : Link to post Share on other sites More sharing options...
zaidi4ever Neutral Newbie October 4, 2016 Share October 4, 2016 hello. purchased a nissan note 2016 model recently. any good places to buy window visors, fog lights and bodykits for it in singapore? Link to post Share on other sites More sharing options...
Rayoflight 5th Gear October 12, 2016 Share October 12, 2016 Did you consider going back to Nissan TCM after all those unsuccessful attempts by outside experts? At least for an opinion from the AD. I doubt there is any such expert from a car forum. You may just got some past experiences which might not be exactly the same situation. Just my humble view.Hello pls read.. she is from new zealand. Link to post Share on other sites More sharing options...
Socani Clutched October 13, 2016 Share October 13, 2016 hello. purchased a nissan note 2016 model recently. any good places to buy window visors, fog lights and bodykits for it in singapore? Do let me know if you have the source. Link to post Share on other sites More sharing options...
zaidi4ever Neutral Newbie October 14, 2016 Share October 14, 2016 Do let me know if you have the source. only got the original door visors at autoace so far. Link to post Share on other sites More sharing options...
Columbian78 6th Gear October 14, 2016 Share October 14, 2016 Any recommendation on workshop that specialise in nissan car mods. Not just normal servicing but able to tune nissan engines (not gtr type), and other performance and handling mods. There are alot of such good workshops active in facebook for brands like vag, bmw, subaru, etc but none for nissan. Link to post Share on other sites More sharing options...
Socani Clutched October 14, 2016 Share October 14, 2016 only got the original door visors at autoace so far. Please PM the location and pricing, thanks. Link to post Share on other sites More sharing options...
zaidi4ever Neutral Newbie October 14, 2016 Share October 14, 2016 Please PM the location and pricing, thanks.autoace for 90. still looking for it fog light. Link to post Share on other sites More sharing options...
Socani Clutched October 14, 2016 Share October 14, 2016 autoace for 90. still looking for it fog light.Did you manage to get hold of The tonneau cover? Link to post Share on other sites More sharing options...
PraiseDef 1st Gear October 15, 2016 Share October 15, 2016 Are splitters legal in Singapore? ↡ Advertisement Link to post Share on other sites More sharing options...
Any Hokkien Song Lovers here?
2021 3rd Generation Nissan Note (E13)
RE :Jaguar Owners Servicing
KIA K3 Owners check-in!
W212 owners, please check-in
Swift Owners
Swift Owners
