wonglilin Neutral Newbie January 8, 2014 Share January 8, 2014 You can see a physiotherapist for TMJ jaw problems ↡ Advertisement Link to post Share on other sites More sharing options...
Vicky_Wong Clutched February 12, 2014 Share February 12, 2014 I having been suffering from TMJ for like almost 10 years. It affects your neck, shoulder, your biting and eventually the shape of your face. After going to the NDC for 3 times over the last 10 years for X-ray, checkups, the result are always the same. They tell you nothing can be done, prescribed you with muscle relaxant and leave you hopelessly devasted! So i conclude going to the GPs or so-called specialists in the hospitals DONT WORK, so dont waste the time and money! I read about it, operation is not advisable unless have to cos it doesn't guarantee problem solved and may leave u with more problems later. My best advise, go for a trusted physio for alternative treatment. Not cheap about $160 per session. The therapist work on your facial muscles so that they wont be tighten. I find it effective and go only when i really need to. Other days, i will just massage and exercise the jaws myself. Its a long long battle. Link to post Share on other sites More sharing options...
Kurty Supercharged March 10, 2014 Share March 10, 2014 (edited) guys, i'm back again on this topic.. i think i suffer from serious TMJ.. my facial muscle , jaw hurts badly recently.. i went to see a dental yesterday, most of my molars are cracked.. i probably need crowning to be done too.. my hard acrylic mouth guard also worn out.. its seem not doing any more good to the teeth.. i had to stop my hyper jaw.. should i go hospital or dental clinic? can i use medisave? was told medisave is only for wisdom tooth extraction and surgery.. Edited March 10, 2014 by Kurty Link to post Share on other sites More sharing options...
Coltplussport Turbocharged March 10, 2014 Share March 10, 2014 guys, i'm back again on this topic.. i think i suffer from serious TMJ.. my facial muscle , jaw hurts badly recently.. i went to see a dental yesterday, most of my molars are cracked.. i probably need crowning to be done too.. my hard acrylic mouth guard also worn out.. its seem not doing any more good to the teeth.. i had to stop my hyper jaw.. should i go hospital or dental clinic? can i use medisave? was told medisave is only for wisdom tooth extraction and surgery.. Thought I suffered from tmj couple of weeks back after sore gum. Went for wisdom tooth extraction and the mouth could not open wide. 10 cm opening at first and it hurt badly. But day by day, the jaw widen slowly and now seems to recover fully already. Scary!!! Link to post Share on other sites More sharing options...
Kurty Supercharged March 10, 2014 Share March 10, 2014 tmj is no joke.. my facial muscle are hurting.. i guess i have to get a referral letter from polyclinic.. need to seek some medical treatment pertaining to it.. Link to post Share on other sites More sharing options...
Vicky_Wong Clutched March 10, 2014 Share March 10, 2014 (edited) You sound like you have a teeth grinding problem resulting in the crack molar. Doctors will always asked u, "have you been very stressed lately?" Anyway, it depends if you have a budget. Based on my experience, cheapest way, go to a polyclinic to get a referral letter to National Dental Center. They will do the check and xray to check your jaw bone structure. Unless, it is very serious, operation is not recommended. They will usually prescribe you with muscle relaxant, tell you to relax more and send you home. If you havent had your wisdom tooth removed, you can schedule an appointment with them. Only surgical stuff can be claim by medisave. If you are pretty sure, its a muscle thingy. You may want to consider going to a physio. The one i went to cost about $160 for a session. I can tell a difference on the first session. You can try to see if it works for you. Edited March 10, 2014 by Vicky_Wong Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged March 10, 2014 Share March 10, 2014 Was thinking whether I have TMJ too... Jaws can't open wide as before and sometimes can hear clicking(?)/"tock" noise which seems to come out from my jaws. Link to post Share on other sites More sharing options...
Coltplussport Turbocharged March 10, 2014 Share March 10, 2014 If you search tmj online, you most probably come across singapore dental specialists website stating that they specializes In tmj treatment. But their location at Mt E and gleneagle look kind of expensive. Link to post Share on other sites More sharing options...
TVT Supercharged March 10, 2014 Share March 10, 2014 Is this condition cause by smoking ? Link to post Share on other sites More sharing options...
tudorpapa 2nd Gear March 10, 2014 Share March 10, 2014 You can see a physiotherapist for TMJ jaw problems physiotherapist ??? Link to post Share on other sites More sharing options...
Kurty Supercharged March 11, 2014 Share March 11, 2014 You sound like you have a teeth grinding problem resulting in the crack molar. Doctors will always asked u, "have you been very stressed lately?" Anyway, it depends if you have a budget. Based on my experience, cheapest way, go to a polyclinic to get a referral letter to National Dental Center. They will do the check and xray to check your jaw bone structure. Unless, it is very serious, operation is not recommended. They will usually prescribe you with muscle relaxant, tell you to relax more and send you home. If you havent had your wisdom tooth removed, you can schedule an appointment with them. Only surgical stuff can be claim by medisave. If you are pretty sure, its a muscle thingy. You may want to consider going to a physio. The one i went to cost about $160 for a session. I can tell a difference on the first session. You can try to see if it works for you. yeah, thats correct.. its a couple of molars that were cracked.. i went to polyclinic yesterday but the doctor can't see me.. going again this thursday.. thanks for sharing, let me find out its my muscle or my jaw.. If you search tmj online, you most probably come across singapore dental specialists website stating that they specializes In tmj treatment. But their location at Mt E and gleneagle look kind of expensive. yes, very expensive... Is this condition cause by smoking ? ermm... hopefully its not.. i'm not surprised, smoking causes all sort of sickness and diseases. Link to post Share on other sites More sharing options...
Shs123 Neutral Newbie November 2, 2016 Share November 2, 2016 Hi all, may i know if ur tmj is solved? I developed a bad one due to braces and took them out after 6 months and i have no bites now. Anyway seen the specialist? Link to post Share on other sites More sharing options...
Leinad8919 Turbocharged November 3, 2016 Share November 3, 2016 Not sure about TMJ, my GF used to have temporary locked jaw after giving me BJ. My solution is change to one with a bigger mouth. Good luck and see a specialist if it is really troubling you. Link to post Share on other sites More sharing options...
Kurty Supercharged November 3, 2016 Share November 3, 2016 Hi all, may i know if ur tmj is solved? I developed a bad one due to braces and took them out after 6 months and i have no bites now. Anyway seen the specialist? hello, receive your pm. my TMJ, even after seeing the specialist. nothing seems to help. I don't want to go under the knife hence I will continue to wear mouth guard, probably till the end of my time. anyway I already used to it and resign to fate. 1 Link to post Share on other sites More sharing options...
Shs123 Neutral Newbie November 3, 2016 Share November 3, 2016 Even after so many years the tmj didnt recover?? My was caused by doing braces at A Line Dental. I started having headaches and dizziness but didnt associate with braces. And then my jaw start cracking and popping when i open my mouth and when eating. N the left side started to become tight and i need to exert pressure to open my mouth. Also i can c my teetg alignment getting more and more slanted with each adjustment. I even start to have buzzing sound in my ear for 24/7. But everytime i see the A line dental Dr Tan he keep telling me will go away. The last straw is when my jaw starts trembling. Even then he told me its nothing but i ask him to maybe remove the braces or something. Which he did BUT i have no bite. My upper and lower teeth don come into contact properly and i cant eat properly. Zzzz.. Spending thousands for this and i dunno need spend how many more to rectify it. Thinking of gg to the specialist and so finding reviews.. so its useless? Link to post Share on other sites More sharing options...
Johnwalk 1st Gear May 18, 2017 Author Share May 18, 2017 Even after so many years the tmj didnt recover?? My was caused by doing braces at A Line Dental. I started having headaches and dizziness but didnt associate with braces. And then my jaw start cracking and popping when i open my mouth and when eating. N the left side started to become tight and i need to exert pressure to open my mouth. Also i can c my teetg alignment getting more and more slanted with each adjustment. I even start to have buzzing sound in my ear for 24/7. But everytime i see the A line dental Dr Tan he keep telling me will go away. The last straw is when my jaw starts trembling. Even then he told me its nothing but i ask him to maybe remove the braces or something. Which he did BUT i have no bite. My upper and lower teeth don come into contact properly and i cant eat properly. Zzzz.. Spending thousands for this and i dunno need spend how many more to rectify it. Thinking of gg to the specialist and so finding reviews.. so its useless? The reason for your TMJ is the procedure of the braces require you to open your mouth so wide for a long time. I can very sure this triggered it. For me , this TMJ come on and off but I can still open my mouth wide just that it will click and hurt. I found something on the internet that C1 and C2 on your neck if not balance will cause this TMJ. I got adjusted as in neck cracking by a Chinese doctor, it seem to release the pain but I am not sure its C1 or C2 she cracked. Link to post Share on other sites More sharing options...
genesix32 Neutral Newbie April 21, 2022 Share April 21, 2022 I used to yawn without any control in the past which cause my jaw's "joint disc" to be dislocated and gradually over the years my muscle got more and more tight that I was desperate to find medical treatment. I stumbled on a chinese article on TMJ by a doctor from Zhao He Qing TCM Clinic I went to quan qi dao / normal tcm and their accupuncture did nothing, but this guy he zua my jaw joint I immediately feel the tension releasing, then got the machine send electric pulse ($40 per session) After a year of treatment, still have clicky jaw but no more muscle tension Anyone got recommendation for TMJ specialist? I really want to get rid of the clicking jaw ↡ Advertisement Link to post Share on other sites More sharing options...
