Kurty Supercharged September 23, 2013 Share September 23, 2013 Is it advisable to mix 2 brand of tire? like front, brand a. Rear, brand b. ↡ Advertisement Link to post Share on other sites More sharing options...
Kurty Supercharged September 23, 2013 Share September 23, 2013 Is it advisable to mix 2 brand of tire? like front, brand a. Rear, brand b. Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 23, 2013 Share September 23, 2013 Is it advisable to mix 2 brand of tire? like front, brand a. Rear, brand b. no....better to have same traction on four tyres. But if driven like a grandma, guess its okay Link to post Share on other sites More sharing options...
Jman888 Moderator September 23, 2013 Share September 23, 2013 i just changed two front 3 weeks ago when the old two (but still can last another 10K km) swap to the back. Is it advisable to mix 2 brand of tire? like front, brand a. Rear, brand b. Link to post Share on other sites More sharing options...
Kurty Supercharged September 23, 2013 Share September 23, 2013 no....better to have same traction on four tyres. But if driven like a grandma, guess its okay then LL got to change all.. 3 tires are ok, but slightly old. 2010 1 is botak... so how har? hamburger, which one i should go for? stick back to 205/50/17? or a stupid design by westlake SA05, 215/45/17.. or up to westlake SV308, 215/55/17 i just changed two front 3 weeks ago when the old two (but still can last another 10K km) swap to the back. if i stick back to 205/50/17, i can do that. the 3rd tyre, can use as spare. save money.. but i just feel for a 2.0.. running on 205.. is like running on a rubber band.. very thin... Link to post Share on other sites More sharing options...
TVT Supercharged September 24, 2013 Share September 24, 2013 Is it advisable to mix 2 brand of tire? like front, brand a. Rear, brand b. You can mix 2 brands in one car. But the same brand should be in the same axle. I have done that before, and travel up North also with such mixture tyres. No problems at all. Link to post Share on other sites More sharing options...
TVT Supercharged September 24, 2013 Share September 24, 2013 then LL got to change all.. 3 tires are ok, but slightly old. 2010 1 is botak... Is your spare tyre a space saver? If not, maybe you can use that spare to replace the botak one, provided that spare is in good condition. Link to post Share on other sites More sharing options...
Kurty Supercharged September 24, 2013 Share September 24, 2013 You can mix 2 brands in one car. But the same brand should be in the same axle. I have done that before, and travel up North also with such mixture tyres. No problems at all. what do you mean by same axle? i don't understand.. normally i change, is all 4.. like what i did for my savvy.. I'm running on KU31 on it now. Is your spare tyre a space saver? If not, maybe you can use that spare to replace the botak one, provided that spare is in good condition. don't understand too.. anyway the spare tyre, is a 16'... perdana stock is 16.. I'm using 205/50/17 for now.. actually wanted to go for 18' but big project.. need to replace 4 lug to 5 lug.. may have to change disc and brake.. I'm changing the rear to brembo rotor with ferodo brakes.. wanted to change to 2 or 4 pot in front but due to my stupid rim, cannot fit.. hence, just change to markX bigger rotor. I know, this are spare money. already selected my venue, date, justice, now waiting for the diamond ring only Link to post Share on other sites More sharing options...
TVT Supercharged September 24, 2013 Share September 24, 2013 what do you mean by same axle? i don't understand.. anyway the spare tyre, is a 16'... perdana stock is 16.. I'm using 205/50/17 for now.. actually wanted to go for 18' but big project.. need to replace 4 lug to 5 lug.. may have to change disc and brake.. Same axle means left and right side the same tyres brand/model. Eg. Front left and right should be brand X, and back left and right should be brand Y. Of course change all 4 tyres altogether is the best. But sometimes we don't get even wear out of tyres so not economical to change all 4 at the same time. Since your spare is different to your rims, then can't be used. You have to buy new tyres, no choice. Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 24, 2013 Share September 24, 2013 Err....what is the original stock size for perdana 16" again? Link to post Share on other sites More sharing options...
Kklee 6th Gear September 24, 2013 Share September 24, 2013 (edited) Here's my checklist on tyres, a) as new as possible ( check date code ) b) stored away from heat or direct sunlight c) stored stacked on their sides but not too high d) firmer sidewalls - for soft suspension e) if changing 2 tyres, they go to the rear for better traction f) date of manufacture + useful life of tyres < 3 or 4 years g) change tyres every 2 years, regardless of thread condition ( rubber hardening ) Edited September 24, 2013 by Kklee Link to post Share on other sites More sharing options...
Kurty Supercharged September 24, 2013 Share September 24, 2013 (edited) Same axle means left and right side the same tyres brand/model. Eg. Front left and right should be brand X, and back left and right should be brand Y. Of course change all 4 tyres altogether is the best. But sometimes we don't get even wear out of tyres so not economical to change all 4 at the same time. Since your spare is different to your rims, then can't be used. You have to buy new tyres, no choice. even different designs also ok? didn't know you know so much about rubber.. Err....what is the original stock size for perdana 16" again? 205/55/16. this weekend, i also try to measure again, see if i can go for 45 profile.. use this as a reference: http://tyrequeen.com/product/tyre-catalog/....html?limit=all i'm getting this Edited September 24, 2013 by Kurty Link to post Share on other sites More sharing options...
Skymax 5th Gear September 24, 2013 Share September 24, 2013 It is comparatively ok to have front pair brand x rear pair brand y provided the grip level is cpmparable. Dont play with comfort tyres mix with semi slick tyres or equivalent or that will upset your overall traction and causes imbalance in handling quality. Best mix eg csc5 with Eagle A2 for.example. Not like Kh31 with R888. Link to post Share on other sites More sharing options...
Jman888 Moderator September 24, 2013 Share September 24, 2013 Tyre Queen only sell tyre? have to pay for installation separately? Link to post Share on other sites More sharing options...
TVT Supercharged September 24, 2013 Share September 24, 2013 (edited) even different designs also ok? didn't know you know so much about rubber.. Must be same design lah...same brand same design/pattern. Don't mix same brand but with difference design/pattern !!! Eg. that time I had 2x GY Eagle NCT 5 on front. Then 2x Yoko Espac on rear. No lah, I only know a bit about rubber nia, and the info all from reading MCF or chatting up with mech lor..... Edited September 24, 2013 by TVT Link to post Share on other sites More sharing options...
TVT Supercharged September 24, 2013 Share September 24, 2013 use this as a reference: http://tyrequeen.com/product/tyre-catalog/....html?limit=all i'm getting this This Westlake is from China or Canada ??? Link to post Share on other sites More sharing options...
TVT Supercharged September 24, 2013 Share September 24, 2013 (edited) Deleted Edited September 24, 2013 by TVT Link to post Share on other sites More sharing options...
Kurty Supercharged September 24, 2013 Share September 24, 2013 Tyre Queen only sell tyre? have to pay for installation separately? yup, it's ok for me. i only need the rubber. Must be same design lah...same brand same design/pattern. Don't mix same brand but with difference design/pattern !!! Eg. that time I had 2x GY Eagle NCT 5 on front. Then 2x Yoko Espac on rear. No lah, I only know a bit about rubber nia, and the info all from reading MCF or chatting up with mech lor..... so troublesome.. just stick to the same model then. is it doable if front is 215/45/17 while rear is 225 or 235, profile like 55 or 50 but 17. This Westlake is from China or Canada ??? Made in China ↡ Advertisement Link to post Share on other sites More sharing options...
This is Why You Should NOT Fit OE Tires To Your Car!
What tires for SUV?
What tires for SUV?
cut on the sidewall of my tire
Tread Depth
Tread Depth
Dunlop SP Sport LEMANS LM705
Used Truck / tractor tires.
How close to wear indicators before changing tires?
Checking notifications
