Popok 1st Gear September 18, 2013 Share September 18, 2013 Was driving and suddenly I couldn't engage 5th gear..gear stick when in, but rpm just dropped. I dropped to 4th gear and stopped and put to neutral. I hear loud tok tok sounds from engine bay also. I turned off and switched on again, tok tok sound persists. Now waiting tow truck, to be on safe side. Anyone encounter this before? I'm driving a manual swift sport. ↡ Advertisement Link to post Share on other sites More sharing options...
NightWind 4th Gear September 18, 2013 Share September 18, 2013 Er r u driving a vw...by any chance? Scirico? Link to post Share on other sites More sharing options...
Hotshot85 4th Gear September 18, 2013 Share September 18, 2013 Er r u driving a vw...by any chance? Scirico? He already said manual swift sport Link to post Share on other sites More sharing options...
NightWind 4th Gear September 18, 2013 Share September 18, 2013 oops sorry my tablet screen too small...i thought it was the VW 7G problem.... Link to post Share on other sites More sharing options...
Watwheels Supersonic September 18, 2013 Share September 18, 2013 The clutch upz lorry is it? Link to post Share on other sites More sharing options...
Popok 1st Gear September 18, 2013 Author Share September 18, 2013 The clutch upz lorry is it? Can't be..just change clutch 3-4months back.. before i left the car, i started, i tried engaging 1,2,3,4 - all ok..i engaged 5th, now stuck. couldnt go back neutral. switched off car and just left it at workshop. Link to post Share on other sites More sharing options...
Skunk Clutched September 18, 2013 Share September 18, 2013 Synchromesh spoil, maybe Link to post Share on other sites More sharing options...
Jamomatt 2nd Gear September 18, 2013 Share September 18, 2013 Synchromesh spoil, maybe Most likely. Link to post Share on other sites More sharing options...
Popok 1st Gear September 18, 2013 Author Share September 18, 2013 now that sounds expensive... :( Link to post Share on other sites More sharing options...
Djdp Clutched September 18, 2013 Share September 18, 2013 Probably Release bearing Link to post Share on other sites More sharing options...
Popok 1st Gear September 18, 2013 Author Share September 18, 2013 Probably Release bearing what exactly is release bearing? where is this located? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear September 19, 2013 Share September 19, 2013 what exactly is release bearing? where is this located? release bearing also known as clutch release bearing. its replace together with your clutch plate and clutch cover. Not sure this bearing was it installed properly or your workshop did not replace this part. Link to post Share on other sites More sharing options...
Watwheels Supersonic September 19, 2013 Share September 19, 2013 If the synchromesh cable snapped it shouldn't be making tok tok tok... sounds. Something else in the clutch assembly could have caused the cable to snap such that the gear lever is stuck in a position and making that noise. Link to post Share on other sites More sharing options...
Popok 1st Gear September 19, 2013 Author Share September 19, 2013 hmm mechanic says clutch assembly seems fine, the sound is from gearbox..ooooh my.. ↡ Advertisement Link to post Share on other sites More sharing options...
Whole car sound proof
Sound Proofing the car
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
