Fivegear Clutched September 21, 2013 Share September 21, 2013 Hello, Some advise please. My Civic FD aircon just now suddenly stop blowing cold air but has wind. I have to switch off the aircon for a while and turned it back on before there was cold wind again. This has had happened the second time liao. Anyone has the problem before? What likely is the problem. Sigh, car coming to 7 years liao, slowly this spoil that spoil but COE never crashes. No money to buy new car leh. ↡ Advertisement Link to post Share on other sites More sharing options...
Ruzmidah 2nd Gear September 21, 2013 Share September 21, 2013 My honda city has similar problem. But it blows hot air when in a jam or stationary. After moving for a while, the aircon kicks in and all is well again. Found out that the magnetic clutch is spoilt. I had it repaired (paid $100) and now its fine.... For ur case, its either a similar problem (as apparently honda cars have a somewhat problematic clutch) or maybe ur aircon fuse konked out... Link to post Share on other sites More sharing options...
Pms 3rd Gear September 21, 2013 Share September 21, 2013 Try change aircon fuse first, the cheapest option and often overlook by owner and often hidden by workshop. The compressor did run when you switch on the aircon. Second, maybe gas running low. So need to top up, second cheapest option. Third, workshop sop answer will be "compressor spoilt liao". Link to post Share on other sites More sharing options...
Fivegear Clutched September 21, 2013 Author Share September 21, 2013 Bro, got reliable workshop to recommend or not? Or should i just bring to Kah Motors to have a check? Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear September 21, 2013 Share September 21, 2013 Bro, got reliable workshop to recommend or not? Or should i just bring to Kah Motors to have a check? Tomika or Mark-Cool. most likely the magnetic clutch is failing. a common problem of Civic FD. Link to post Share on other sites More sharing options...
Fivegear Clutched September 21, 2013 Author Share September 21, 2013 Hey Bro, if really due to magnetic clutch, how much is the damage to repair or change roughly? Link to post Share on other sites More sharing options...
Spinelli_ck 6th Gear September 21, 2013 Share September 21, 2013 Hey Bro, if really due to magnetic clutch, how much is the damage to repair or change roughly? someone did mention it cost a hundred bucks. a ballpark figure. do get a second or third opinion before you commit. Link to post Share on other sites More sharing options...
Kmchew Neutral Newbie September 21, 2013 Share September 21, 2013 My Stream had exactly the same problem when I was stucked in the jam at custom last week. Aircon came back after clearing custom and problem has not recurred since. Going to get Kah motor to check n replace whatever is necessary since car is still under warranty Link to post Share on other sites More sharing options...
Coconut1 Neutral Newbie September 22, 2013 Share September 22, 2013 Hello, Some advise please. My Civic FD aircon just now suddenly stop blowing cold air but has wind. I have to switch off the aircon for a while and turned it back on before there was cold wind again. This has had happened the second time liao. Anyone has the problem before? What likely is the problem. Sigh, car coming to 7 years liao, slowly this spoil that spoil but COE never crashes. No money to buy new car leh. My 6 years old Civic had exactly the same problem. Went to shell workshop many times changed several things (aircon fan, gas) but couldn't solve problem. Went to Kah motors twice before they found out it was the aircon clutch (engage/disengage) was loose after wear and tear and failed to engage. Cost close to $1000 for that last episode of repair and it took 1 full working day. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic September 22, 2013 Share September 22, 2013 Hey Bro, if really due to magnetic clutch, how much is the damage to repair or change roughly? That time my friend changed the magnetic clutch for his Vios at Kim Hoe for $220. On a Sunday somemore. You can go there to try now. http://www.sgcarmart.com/directory/merchant.php?MID=12631 Link to post Share on other sites More sharing options...
Forte3737 5th Gear September 22, 2013 Share September 22, 2013 Bro, got reliable workshop to recommend or not? Or should i just bring to Kah Motors to have a check? checks are not cheap in kah motors Link to post Share on other sites More sharing options...
Fit44 Clutched September 22, 2013 Share September 22, 2013 My wife's 05 jazz Aircon will blow hot air every time it reaches speed of 110km/h. Is it normal? Link to post Share on other sites More sharing options...
Watwheels Supersonic September 22, 2013 Share September 22, 2013 That time my friend changed the magnetic clutch for his Vios at Kim Hoe for $220. On a Sunday somemore. You can go there to try now. http://www.sgcarmart.com/directory/merchant.php?MID=12631 I do not recommend that shop to do aircon. Repair punctured tire on a Sunday still ok but not aircon. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic September 22, 2013 Share September 22, 2013 I do not recommend that shop to do aircon. Repair punctured tire on a Sunday still ok but not aircon. I did have my doubts when my friend wanted to send there but in the end, they did a good job. They managed to get the magnetic clutch on a Sunday. Link to post Share on other sites More sharing options...
Renegade777 5th Gear September 22, 2013 Share September 22, 2013 (edited) Hello, Some advise please. My Civic FD aircon just now suddenly stop blowing cold air but has wind. I have to switch off the aircon for a while and turned it back on before there was cold wind again. This has had happened the second time liao. Anyone has the problem before? What likely is the problem. Sigh, car coming to 7 years liao, slowly this spoil that spoil but COE never crashes. No money to buy new car leh. If I am not wrong, this is quite common in Honda cars. The aircon like sometimes work sometime don't. Usually, it is the magnetic clutch that is giving issue and that just some cleaning will do the trick. Cost around $40 to $50/-. You may want look to into this before jumping into other conclusion or even think of getting new magnetic clutch. Edited September 22, 2013 by Renegade777 Link to post Share on other sites More sharing options...
Celicar Turbocharged September 22, 2013 Share September 22, 2013 If I am not wrong, this is quite common in Honda cars. The aircon like sometimes work sometime don't. Usually, it is the magnetic clutch that is giving issue and that just some cleaning will do the trick. Cost around $40 to $50/-. You may want look to into this before jumping into other conclusion or even think of getting new magnetic clutch. Didn't know that magnetic clutch can just clean. Thought must change the whole assembly. Link to post Share on other sites More sharing options...
Shanhz 3rd Gear September 24, 2013 Share September 24, 2013 civic, crv, stream i think all got same aircon problem. i fixed mine at kim for $200+ Link to post Share on other sites More sharing options...
Mysportwish 1st Gear September 24, 2013 Share September 24, 2013 I tink I also have similar issue with wish le... was thinking of needing to change compressor ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Car air-con
Car air-con
Home Aircon
Home Aircon
Everything about ice creams
