Ry0suk1 1st Gear September 26, 2013 Share September 26, 2013 bring to workshop ask them, increase yr idling RPM set to 800-1k.. this happen to my car before.. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 26, 2013 Share September 26, 2013 Not sure if my situation is similar to yours. Previously, I have a problem with vibrations when aircon cuts in. If drive without aircon, no issue. When aircon cuts in, the rpm will drop to 500 and the headlamps will dim. Vibrations comes in due to rpm is too low. This continues until one day I decided to do an aircon flush (changing of aircon lubricant). Mechanic found that the aircon blower motor is faulty. After that is changed, now car is normal with minimal vibrations. But headlamps do not dim and rpm do not drop to 500. It maintained at 600+ when aircon cuts in. Likely yr AC blower motor had a shortcircuit. Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 26, 2013 Share September 26, 2013 thanks bro the mechanic n workshop is highly recommended and respected. maybe our fengshui not matching. shld take second opinion - any ws to recommended near ubi area. your helps is highly appreciated! I dun hv ant ws to recommend in Ubi area. Mine was at Yishun Indl Pk.A. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear September 26, 2013 Share September 26, 2013 bring to workshop ask them, increase yr idling RPM set to 800-1k.. this happen to my car before.. Hello Bro. Depend on what the make...like mine 600 to 650 increase to 800 burn more fuel lah. Link to post Share on other sites More sharing options...
Terenceong Neutral Newbie September 29, 2013 Share September 29, 2013 Hi guys, sorry to side track. my car today starts to vibrate when I start and during stops but ok when driving.. The vibration is pretty strong.. Anyone can help? 1 of my fren said maybe is the coil couldn't get regular electricity flow because when he blast the Aircon, the vibration stops.. My driving a 2005 bmw 520. Thanks in advance! Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 4, 2013 Share October 4, 2013 Hi guys, sorry to side track. my car today starts to vibrate when I start and during stops but ok when driving.. The vibration is pretty strong.. Anyone can help? 1 of my fren said maybe is the coil couldn't get regular electricity flow because when he blast the Aircon, the vibration stops.. My driving a 2005 bmw 520. Thanks in advance! Check yr engine mountings first. 1 Link to post Share on other sites More sharing options...
D4rkFly3r Neutral Newbie October 8, 2013 Author Share October 8, 2013 (edited) Hi guys, sorry to side track. my car today starts to vibrate when I start and during stops but ok when driving.. The vibration is pretty strong.. Anyone can help? 1 of my fren said maybe is the coil couldn't get regular electricity flow because when he blast the Aircon, the vibration stops.. My driving a 2005 bmw 520. Thanks in advance! Likely is your engine mountings if you havent changed it yet. Edited October 8, 2013 by D4rkFly3r Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie October 12, 2013 Share October 12, 2013 Hi guys, I just change my engine oil, air oil filter and spark plug at ws... After changing, engine while idle or accelerate not hard enuf wld vibrate... went back to ws was told for carbetor engine, need to rev more at gear 1 n 2 to remove the black smoke...after that shld be ok Any bros know chun or not? Mech say no cause for concern... Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 12, 2013 Share October 12, 2013 Hi guys, I just change my engine oil, air oil filter and spark plug at ws... After changing, engine while idle or accelerate not hard enuf wld vibrate... went back to ws was told for carbetor engine, need to rev more at gear 1 n 2 to remove the black smoke...after that shld be ok Any bros know chun or not? Mech say no cause for concern... If b4 yr car dun vibrate b4 service n after service it vibrate, yr lousy ws did something wrong. Maybe yr plugs wrong type or the gap is wrong. Or the b@stard mech adjust yr idle or air/fuel mix too lean. I wun trust going to that ws again. Maybe ty sabo yr car so ty hv more biz from u. Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie October 12, 2013 Share October 12, 2013 Tks. Plug shld be right.. cos I got a previous sample when I go buy... Just chk my engine oil level... suspect its due to over top slightly. .. any idea if this will cause engine to act this way? If b4 yr car dun vibrate b4 service n after service it vibrate, yr lousy ws did something wrong. Maybe yr plugs wrong type or the gap is wrong. Or the b@stard mech adjust yr idle or air/fuel mix too lean. I wun trust going to that ws again. Maybe ty sabo yr car so ty hv more biz from u. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear October 13, 2013 Share October 13, 2013 Tks. Plug shld be right.. cos I got a previous sample when I go buy... Just chk my engine oil level... suspect its due to over top slightly. .. any idea if this will cause engine to act this way? Wrong plug used will effect vibration but EO overfill will not affect only the power very sloggish. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 13, 2013 Share October 13, 2013 Tks. Plug shld be right.. cos I got a previous sample when I go buy... Just chk my engine oil level... suspect its due to over top slightly. .. any idea if this will cause engine to act this way? If correct plug but too narrow gap might cause poor idling but better red line performance. EO slightly overfill sud not b a problem. But I prefer to underfill very slightly below the "F" mark(abt 3/4 full). Chk yr plug leads if connected properly n if ty r old n cracked n leaking current. Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie October 14, 2013 Share October 14, 2013 Tks guys.. Doing trial error nw.. I off aircon drive, car was ok.. in fact powerful... On aircon start vibrate liao... Any idea if change spark plug, car need to do tuning also? Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 14, 2013 Share October 14, 2013 Tks guys.. Doing trial error nw.. I off aircon drive, car was ok.. in fact powerful... On aircon start vibrate liao... Any idea if change spark plug, car need to do tuning also? Chk if yr engine idle speed drop when u on the AC? Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 14, 2013 Share October 14, 2013 Tks guys.. Doing trial error nw.. I off aircon drive, car was ok.. in fact powerful... On aircon start vibrate liao... Any idea if change spark plug, car need to do tuning also? U mention yr car is using carburettor. What car is it, how old n mileage? Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie October 14, 2013 Share October 14, 2013 Its a 25yo w124.. U mention yr car is using carburettor. What car is it, how old n mileage? Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 14, 2013 Share October 14, 2013 Its a 25yo w124.. Oh OK then. So does yr rpm drop at idle when u on the AC ??? Link to post Share on other sites More sharing options...
winson_stalin Neutral Newbie October 15, 2013 Share October 15, 2013 Yup.. w/o aircon about 900 rpm.. With aircon drop slightly to 700? Just wondering if the range is normal? Oh OK then. So does yr rpm drop at idle when u on the AC ??? ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
HDB season parking renewal problem
Singapore Problem Gambling
