  • Search this thread
  • Reply to this topic
63 replies to this topic | 56 praises
#1
Posted 11 October 2013 - 10:14 PM
Kurty
  • THREAD STARTER
  • Premium member
    Kurty
    NOS-ed
    Author Image
    10,035
Hi,
I have a slight situation..
I just change my tires.. 215/50/17.
Stock was at 205/55/16..
I know I Should go for 215/45/17 but due to comfort.. I just bit the bullet..
Now suffering hitting the fender when I go over uneven road or bumps..
However It's only right side.. left is totally fine..
Front is less than 1 finger.
Rear is around 2 finger..
Using a sport spring and stock suspension..
What Should I do?
changing Tyre is out of the question..
Should I change back to stock spring or upgrade to adjustable?
bluey Tiko Ranger
I have a pen, I have an apple..
#2
Posted 11 October 2013 - 10:46 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    85,062
its not your springs, nor your tyre profile and some will even tell you to roll your fenders.... [sleeping]
the problem lies with your rims offset. Its too positive looking how it flush with your fenders.
QUOTE
do to others what you want others to do to you......
#3
Posted 11 October 2013 - 10:49 PM
Kurty
  • THREAD STARTER
  • Premium member
    Kurty
    NOS-ed
    Author Image
    10,035
It's 28...offset
bluey Tiko Ranger
#4
Posted 11 October 2013 - 11:01 PM
TVT
  • Premium member
    TVT
    NOS-ed
    Author Image
    12,641
Hi,
What Should I do?
Mine also like that leh...only the front right (left is OK). Front about 4-5 fingers gap. Rear not sure but higher, but if loaded with passengers it'll also "sink" downwards. Go thru uneven road or humps can hear (the front right) hitting the fenders. So what I do? Just slow down at uneven road or humps lor...
#5
Posted 11 October 2013 - 11:07 PM
Strat
  • Premium member
    Strat
    6th Gear
    Author Image
    3,104
Change back to stock springs
#6
Posted 11 October 2013 - 11:16 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    85,062
It's 28...offset
no wonder.
only way is change rim if you cant stand stock height.
Please check whats the stock rim offset. It may be ET45-50
QUOTE
#7
Posted 12 October 2013 - 03:26 AM
Prostcode
  • Premium member
    Prostcode
    4th Gear
    Author Image
    804
my advise:
1) roll fender ($60 a pair)
2) open camber
if not, get adjustable coilovers.
1992 Honda Civic Si (EG5)
1996 Honda Civic SiR (EK4)
2007 Subaru Impreza WRX (GDA)
#8
Posted 12 October 2013 - 08:00 AM
Kurty
  • THREAD STARTER
  • Premium member
    Kurty
    NOS-ed
    Author Image
    10,035
What is roll fender?
and open camber about?
bluey Tiko Ranger
#9
Posted 12 October 2013 - 09:04 AM
Ckchong8
  • Premium member
    Ckchong8
    4th Gear
    Author Image
    635
Hi,
What Should I do?
1 finger gap too narrow, the cheaper way is to add spring stiffener or roll the fender to widen the broadness for the wheel to seat in.
#10
Posted 12 October 2013 - 01:58 PM
Ooosh
  • Ooosh
    4th Gear
    Author Image
    884
You can either put a spring stiffener so the rubber in between the spring will stop the wheels from hitting the fender
Another way is to change to a good set of coilovers (ISC, HKS etc) so the suspension does not bottom out.
Used to be on ISC coilovers on my car and finger width between fender and wheels is only one finger but no cases of hitting fender even on uneven roads.
Aftermarket springs with stock suspension is a very bad combination because the aftermarket springs is shorter, it lowers the car and this stresses the stock suspension because it is made to travel in a longer rebound rate. - my 2 cents.
#11
Posted 12 October 2013 - 09:51 PM
Kurty
  • THREAD STARTER
  • Premium member
    Kurty
    NOS-ed
    Author Image
    10,035
Yeah, good point..
But due to the dire situation, I have to find quick remedy..
This morning while in port Dickson, I went to panel beating, hoping to roll the fender but too bad, It's already rolled.. and don't helps..
I also tried to install spring cushion but don't help much..
End up, I buy new tires. Now 215/45/17, now front 1 finger.
Rear 4 fingers.
No problem even at high speed
bluey Tiko Ranger
#12
Posted 12 October 2013 - 10:22 PM
Pisces69
  • Premium member
    Pisces69
    2Fast2Furious
    Author Image
    55,392
Yeah, good point..
Rear 4 fingers.
Thats what happens when u itchy n start changing this n that on yr "new" car.
  Dun play around wh yr camber. It wil affect yr handling n car might skid.
Roll Fender is easy. Go construction site n borrow a sledge hammer. Use it to whack the fender out a bit so it dun touch the tire anymore.
#13
Posted 12 October 2013 - 10:45 PM
TVT
  • Premium member
    TVT
    NOS-ed
    Author Image
    12,641
Rear 4 fingers.
I tot you just change tires not long ago?
#14
Posted 12 October 2013 - 10:53 PM
TVT
  • Premium member
    TVT
    NOS-ed
    Author Image
    12,641
Huh, that's not roll fenders! That is whacking fenders! [laugh] If whack like that the car body shape all out liao....
#15
Posted 12 October 2013 - 11:08 PM
Pisces69
  • Premium member
    Pisces69
    2Fast2Furious
    Author Image
    55,392
He got plenty of $$$ so throwing it away on his
"new" car.
Change  then wrong so change again. Then too noisy, change again. Then too bumpy, change again, etc etc etc.
Sometimes car not properly repaired after kenna accident so whacking might make it look better n more balanced.
#16
Posted 13 October 2013 - 12:46 AM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    85,062
like I said, the root of your cause is the rim not the tyre.
QUOTE
#17
Posted 13 October 2013 - 08:06 AM
Kurty
  • THREAD STARTER
  • Premium member
    Kurty
    NOS-ed
    Author Image
    10,035
Yeah, notti and ignorant..plus dumb
Well, what to do, learn from painful lesson..
Yeah, the real catalyst is the rim, the offset too little for me..
No choice, both wife and myself like the rim..
Anyway problem already solved.. whacking high and low
Edited by Kurty, 13 October 2013 - 08:07 AM.
bluey Tiko Ranger
#18
Posted 14 October 2013 - 02:42 PM
AlanZ
  • AlanZ
    2nd Gear
    Author Image
    187
The rim offset is the main reason. Not the tire profile.
#19
Posted 06 November 2013 - 12:38 PM
Skymax
  • Premium member
    Skymax
    5th Gear
    Author Image
    1,918
For the hella flush look you need to do your homework. Wait till you see the hella flush gang. Crazy offset!
I actually also eyeing one IKR et30 maybe got problem, so end up with another desifn at et35.
Some of my ride make even go to et20. Hellaflush!
Suck»Squeeze»Bang»Blow»»Piss!
#20
Posted 06 November 2013 - 02:57 PM
Stratovarius
  • Premium member
    Stratovarius
    6th Gear
    Author Image
    3,938
Matching rim offset and tyre profile is a form of art esp you want that flush look. My current rims with 195 profile tyres is perfect, but when i changed to 205 tyres, one of the rear side will rub the fender edge. I'm looking at new rims with less offset so as to compensate the wider tyres.A good excuse to change rims!
Edited by Stratovarius, 06 November 2013 - 02:58 PM.
Back to Performance and Tuning  ·  Aftermarket Top Reply to this topic
NuteQ Shock Absorber
NuteQ Shock Absorber  |  Rating   Submit Review
Reviewed by Potter333  |  Neutral Newbie
Good quality absorber
Improve handling and better driving experience when turning or gg over the hump. Overall quite happy with the replacement
KYB Excel-G
KYB Excel-G  |  Rating   Submit Review
Reviewed by SiamJitPee  |  Neutral Newbie
Drive Comfortably
This is a no-frills product. It not only offers more control for my ride but also enables me to handle my car as good as a new, if not better. Significantly noticeable reduced road impact upon installation, what's more.. The pricing is great!
Related Product Guide search on sgCarMart.com : Fender Rolling, Suspension, Absorber
Quick Reply
