Karbonphyber 1st Gear April 23, 2014 Share April 23, 2014 (edited) I see what you mean now. I hope i'm able to explain this clearly. In summary, camber only solves 1 issue. It solves clearance at a standstill (static). When a car is loaded, that is another problem which cannot be solved fully using camber. Will explain why:Negative camber allows the rim to tilt inwards - that we know for sure. That's short and sweet! The other thing to consider is suspension geometry which is independent of camber/toe/whatever. It determines how the rim moves up and down. Imagine your elbow being bolted/affixed/stuck to the table you're on right now. If you try to move your hand, it can only move left or right in an arc. Am i clear so far? Relating this to your car: Your hand is where the rim is mounted. Regardless of camber, the rim will still move up and down depending on the amount of load WITH that restricted amount of movement. If the top of the rim doesn't touch the nut/bolt, the middle section may hit it eventually - with sufficient loading. To solve this: 0) Raise the height of the car, assuming you're on coilovers? 1) Reduce tyre profile; also reduces the cars overall ground clearance 2) Increase the offset of the rim aka buy a new one 3) Disregard and scrub it away forever! 4) Widebody after that :) Its hard to get a picture in that area. But i will try. Meanwhile, let me explain and see if you can picture it. Before cambering, whole tire is outside of the body. After cambering, only the top half of the tyre is inside the body. Bottom half is still outside. By right, after cambering tire rubbing fender is not going to happen anymore even with three passenger at the back but there is this bolt that secure the rear bumper to the fender. When car is lowered with the load, the bolt got closer to the tire, thus causing the tire to rub on the bolt when going upslope and uneven roads. i found this picture, http://img.photobucket.com/albums/v87/danxcore/Dis_zps0c099bbd.png Edited April 23, 2014 by Karbonphyber ↡ Advertisement Link to post Share on other sites More sharing options...
Jiangendi Neutral Newbie April 23, 2014 Share April 23, 2014 Yes I understand what you explained. Thank you for the effort. Im not on coilover. Still saving up for one. I was thinking a harder ride might be able to solve the issue. Anyway, that wont be happening soon. Reduce tire profile means selling my two months old tires. LOL. Nankang 225/45 17'' If i were to sell the tyres and try with a lower tire profile tire, I think it makes more sense to sell it off with the rims to someone who is able to comprehend this offset on their ride. Not going to play with such big offset anymore. If i were to persist, reducing tyre profile is an option. Anyway, the handling is worse than stock rim. Don't even talk about this big topic of handling, it just means turning the steering is harder than before. And my FC is like 8.5km/litre. Devastating. Thanks so much again! Shall do some thinking on my own. Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear April 23, 2014 Share April 23, 2014 What was the original size of the rim/tyre on the car? Was it 14/15" before?No dramas. anything just ask :) Yes I understand what you explained. Thank you for the effort. Im not on coilover. Still saving up for one. I was thinking a harder ride might be able to solve the issue. Anyway, that wont be happening soon. Reduce tire profile means selling my two months old tires. LOL. Nankang 225/45 17'' If i were to sell the tyres and try with a lower tire profile tire, I think it makes more sense to sell it off with the rims to someone who is able to comprehend this offset on their ride. Not going to play with such big offset anymore. If i were to persist, reducing tyre profile is an option. Anyway, the handling is worse than stock rim. Don't even talk about this big topic of handling, it just means turning the steering is harder than before. And my FC is like 8.5km/litre. Devastating. Thanks so much again! Shall do some thinking on my own. Link to post Share on other sites More sharing options...
Jiangendi Neutral Newbie April 23, 2014 Share April 23, 2014 (edited) Stock is 16". Wheels is a difficult thing to understand. actually its not the size or the 225 causing this problem, isnt it? Its the offset of the rim right? i am using this http://www.xxrwheels.com/xxr_527.shtml Edited April 23, 2014 by Jiangendi Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear April 23, 2014 Share April 23, 2014 XXRs are beautiful. we use them on track in oz. stretched to the max!These will come in more aggressive (in relation to FWD offsets) offsets and cause issues if used in a FWD in appropriately. High chances it's offset causing this issue which is why i brought up changing rims to get a more suitable offset rim if that's the case. Stock is 16". Wheels is a difficult thing to understand. actually its not the size or the 225 causing this problem, isnt it? Its the offset of the rim right? i am using this http://www.xxrwheels.com/xxr_527.shtml Link to post Share on other sites More sharing options...
Jiangendi Neutral Newbie April 24, 2014 Share April 24, 2014 Yes, finally can reply. My next reply can only be done at 2314H. Oh wow. You are really active in the racing scene. Impressive! Anyway, I have posted online to sell the rims and tyres. Have decided to change. Now the problem is what rim. What should i be looking for? Am i supposed to watch out for the maximum width of the rim? So that the rim is flush inside the fender. How can i know the maximum offset i can do on my car? THANKS Link to post Share on other sites More sharing options...
Kurty Supercharged April 24, 2014 Author Share April 24, 2014 aiyo, you should just change the tire with me. i'm 215/45/17, but my rim offset is 20, 8.5jj, your 225/45/17, gonna be sexy for mine. Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear April 24, 2014 Share April 24, 2014 Can always come and find me. i'll do some math for you and you can then see what kinda rims will fit. karbonphyber@g------- mail.com Yes, finally can reply. My next reply can only be done at 2314H. Oh wow. You are really active in the racing scene. Impressive! Anyway, I have posted online to sell the rims and tyres. Have decided to change. Now the problem is what rim. What should i be looking for? Am i supposed to watch out for the maximum width of the rim? So that the rim is flush inside the fender. How can i know the maximum offset i can do on my car? THANKS Link to post Share on other sites More sharing options...
Jiangendi Neutral Newbie April 25, 2014 Share April 25, 2014 wow thanks. how to calculate then? email you? Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear April 25, 2014 Share April 25, 2014 wow thanks. how to calculate then? email you? eh, email me to meet up and then I can do the calculation for you :) Link to post Share on other sites More sharing options...
Strudel- 1st Gear May 11, 2014 Share May 11, 2014 In Singapore for holiday ah eh, email me to meet up and then I can do the calculation for you :) Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear May 11, 2014 Share May 11, 2014 In Singapore for holiday ah could say that :) Link to post Share on other sites More sharing options...
Strudel- 1st Gear May 11, 2014 Share May 11, 2014 Lucky man! I might be going too next month! could say that :) Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear May 12, 2014 Share May 12, 2014 Lucky man! I might be going too next month! where are you now? LOL Link to post Share on other sites More sharing options...
Strudel- 1st Gear May 12, 2014 Share May 12, 2014 Still in Brisbane lo where are you now? LOL Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear May 12, 2014 Share May 12, 2014 Still in Brisbane lo therefore the R33 in your avatar. nobody in singapore should have an R33 avatar. lol hows life? i'm back for a bit so i'm bringing back my racing knowledge in my brain for any singaporean that actually cares about their car. always keen to help a brother out. :) Link to post Share on other sites More sharing options...
Strudel- 1st Gear May 12, 2014 Share May 12, 2014 Hahaha. Good man. If everyone share like you this world will be a better place. Cant wait to go back next month for makan. A lot of people here with aggressive offset lso rmove the inner guards. therefore the R33 in your avatar. nobody in singapore should have an R33 avatar. lol hows life? i'm back for a bit so i'm bringing back my racing knowledge in my brain for any singaporean that actually cares about their car. always keen to help a brother out. :) Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear May 12, 2014 Share May 12, 2014 Hahaha. Good man. If everyone share like you this world will be a better place. Cant wait to go back next month for makan. A lot of people here with aggressive offset lso rmove the inner guards. well, gimme a call then. go out for makan. true. i sliced and diced mine up to accommodate my 17x9.5 -20s ↡ Advertisement Link to post Share on other sites More sharing options...
Formula 1 Wheels Look Way Different for 2022. Here's Why. . .
DIY Curbed Wheel Fix - Was It Worth It?
BBS wheels reportedly files for bankruptcy in Germany
The optional wheels for the Mac Pro cost almost S$600
Old man with Hammer subdued
New Mid Size Sedan All Comes with Bigger Rims/Wheels?
BBS....RI-A Rims.
BBS....RI-A Rims.
Forged brand rims... anyone know where this brand is from?
