Strudel- 1st Gear May 12, 2014 Share May 12, 2014 Right.... Will let you know again. -20?! well, gimme a call then. go out for makan. true. i sliced and diced mine up to accommodate my 17x9.5 -20s ↡ Advertisement Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear May 19, 2014 Share May 19, 2014 Right.... Will let you know again. -20?! haha yes. -20. no typo there :) Link to post Share on other sites More sharing options...
ElisaGrace February 24, 2016 Share February 24, 2016 The best option is to visit an accessory shop and ask them for spring buffer for sale. You also ask them whether it can cure the touching problem. You must find a good quality one. If still the problem persists visit professional mechanic. Link to post Share on other sites More sharing options...
Vratenza Supersonic February 24, 2016 Share February 24, 2016 The best option is to visit an accessory shop and ask them for spring buffer for sale. You also ask them whether it can cure the touching problem. You must find a good quality one. If still the problem persists visit professional mechanic. Wow.....1.5yrs tread revived. The question poser probably worn out the problem tire on the fender already. Link to post Share on other sites More sharing options...
Columbian78 6th Gear October 31, 2017 Share October 31, 2017 (edited) Borrow this thread. I am thinking to change my tire profile from 225/45/17 to 225/50/17 --> increase the sidewall profile by 1 size. Reason is to make the car more comfortable. The tire i am targeting (f1a3) only come in this 2 sizes, otherwise I might go for 215/50/17. Car is currently lowered to 2 fingers gap on coils. No rubbing issues. Rims are aftermarket but at stock offset. Previously on stock suspension I had used 215/50/17 and no issues. My worry is tire hitting. My feel is that the rear tires should be safe from hitting. I worry more of the front hitting when turning. Is my concern valid? Any comments? If it hit, I am prepared to increase the car height by another finger. Not sure would this help? Edited October 31, 2017 by Columbian78 Link to post Share on other sites More sharing options...
Enye Hypersonic October 31, 2017 Share October 31, 2017 Borrow this thread. I am thinking to change my tire profile from 225/45/17 to 225/50/17 --> increase the sidewall profile by 1 size. Reason is to make the car more comfortable. The tire i am targeting (f1a3) only come in this 2 sizes, otherwise I might go for 215/50/17. Car is currently lowered to 2 fingers gap on coils. No rubbing issues. Rims are aftermarket but at stock offset. Previously on stock suspension I had used 215/50/17 and no issues. My worry is tire hitting. My feel is that the rear tires should be safe from hitting. I worry more of the front hitting when turning. Is my concern valid? Any comments? If it hit, I am prepared to increase the car height by another finger. Not sure would this help? how much more comfortable just with the minor sidewall profile change? you probably won't feel much of a difference in comfort but deviating more and more from stock potentially causing more issues Link to post Share on other sites More sharing options...
Tommisan 4th Gear October 31, 2017 Share October 31, 2017 45% of 215mm = 96.75mm 50% of 215mm =107.5mm 10mm more, check during turning. If there is rubbing, increase car height by one more finger as mentioned. Link to post Share on other sites More sharing options...
Vratenza Supersonic October 31, 2017 Share October 31, 2017 more complicated than simply increasing the rolling diameter. with the 10mm increase in rolling radius, there is sidewall bulge to consider and how much bulge is dependent on the tyre you are targeting. Some tyre models have stiffer sidewall (less bulge) and some have softer sidewall (more bulge). this combined increased rolling radius with sidewall bulge can potentially rub in 3 main areas: the fender on the outer side, the inner side of the wheel well and lastly the spring/coilover on the inner side. Link to post Share on other sites More sharing options...
vashachiroku 1st Gear November 2, 2017 Share November 2, 2017 If you want to tuck the tire under the fender you'll have to remove any splash guard and then roll the fender. Link to post Share on other sites More sharing options...
Noraa Neutral Newbie November 6, 2017 Share November 6, 2017 Hi All, I'm currently driving a 1.5A sunny on drift racing coilovers. Using 205/45/16 Bridgestone MY05 front tyres and Kumho Ecsta PS31 rear tyres. Am considering changing to 205/50/16 for better comfort as on coilvers is already very bumpy hence thinking if upgrading to 205/50/16 will be better. Can any experienced bro advice? Many thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Formula 1 Wheels Look Way Different for 2022. Here's Why. . .
DIY Curbed Wheel Fix - Was It Worth It?
BBS wheels reportedly files for bankruptcy in Germany
The optional wheels for the Mac Pro cost almost S$600
Old man with Hammer subdued
New Mid Size Sedan All Comes with Bigger Rims/Wheels?
BBS....RI-A Rims.
BBS....RI-A Rims.
Forged brand rims... anyone know where this brand is from?
