Simplybay Clutched October 13, 2013 Share October 13, 2013 Simplebay, after you sort out the bugs, I found something that might interest you.... :) How does 290hp and 355Nm sound to you? how was the torque curve? can text me if not convenient to mention it. anyway any recommendation for coolant, doing a complete drain on my next servicing. ↡ Advertisement Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear October 13, 2013 Share October 13, 2013 how was the torque curve? can text me if not convenient to mention it. anyway any recommendation for coolant, doing a complete drain on my next servicing. For your coolant, do a complete flush, change out your water pump and your piping as well. use the normal coolant that you're supposed to use. I like to use Millers coolant enhancer. does not leave precipitates or residues. http://www.millersoils.co.uk/automotive/tds-automotive.asp?prodsegmentID=193§or=Motorsport Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear October 13, 2013 Share October 13, 2013 For Simplebay https://www.youtube.com/watch?v=IxedcaYZquw Link to post Share on other sites More sharing options...
Desmojon 1st Gear October 14, 2013 Share October 14, 2013 Better go get it checked. I had the same message that went away after restart, so I thought nothing of it. My Bella rewarded me with a trip up the tow truck about a month later. I notice my gearbox is leaking oil again. Gonna get it fixed real soon. Yes. Now at AS checking. This morning the system does not allow me to start the car even. Tried a few times then manage to fire her up. I quickly come AS. Weird thing is half way to AS the gearbox revert to normal. Maybe Bella is not happy I did so many non-Alfa days Link to post Share on other sites More sharing options...
Simplybay Clutched October 14, 2013 Share October 14, 2013 For your coolant, do a complete flush, change out your water pump and your piping as well. use the normal coolant that you're supposed to use. I like to use Millers coolant enhancer. does not leave precipitates or residues. http://www.millersoils.co.uk/automotive/tds-automotive.asp?prodsegmentID=193§or=Motorsport pipping hard to find in aftermarket parts Miller coolant enhancer need to mix 1 part to 50 parts of water ratio, how many bottle i need sia Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic October 14, 2013 Share October 14, 2013 Yes. Now at AS checking. This morning the system does not allow me to start the car even. Tried a few times then manage to fire her up. I quickly come AS. Weird thing is half way to AS the gearbox revert to normal. Maybe Bella is not happy I did so many non-Alfa days Ok pls update what was the issue. Thx bro Link to post Share on other sites More sharing options...
Simplybay Clutched October 14, 2013 Share October 14, 2013 For Simplebay https://www.youtube.com/watch?v=IxedcaYZquw aiyah, this one need to send in to their workshop right? Link to post Share on other sites More sharing options...
Theredstar 2nd Gear October 14, 2013 Share October 14, 2013 huh? how to use metal key to start car? zzz. im lost there's a little lobang at the side to insert the metal part eh? Link to post Share on other sites More sharing options...
Thingy 1st Gear October 14, 2013 Share October 14, 2013 Wear and tear I understand. My mileage is around 95K ... the workshop was telling me people change around 50 - 60,000 KM, got one extreme case is change at 30,000. So I guess mine is reasonable, I was planning to do a major maintenance to change all the worn out parts one shot when I hit 100,000 KM. 95km and you haven't change your clutch before? Not bad leh... My lemon friend changed clutch at 30k++.... ANother one change clutch at 70k++ ? Link to post Share on other sites More sharing options...
Desmojon 1st Gear October 14, 2013 Share October 14, 2013 Ok pls update what was the issue. Thx bro Got a call back from AS. Gear sensor gone. Same problem as Echo. Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear October 14, 2013 Share October 14, 2013 Got a call back from AS. Gear sensor gone. Same problem as Echo. What time are you collecting it? Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear October 14, 2013 Share October 14, 2013 aiyah, this one need to send in to their workshop right? depends on how much of it you want. back box, cams and tune. manifold is up to you, but that would release the most though. Link to post Share on other sites More sharing options...
Hyperboxer 1st Gear October 14, 2013 Share October 14, 2013 Newbie here. Just collected my 2010 159 Q2 and having problem to pair with the bluetooth. Is there any special "method" to get it working? Oso, tot of installing a USB cable if Bluetooth not working. Any recommendations? Link to post Share on other sites More sharing options...
Theoldjaffa Hypersonic October 14, 2013 Share October 14, 2013 Got a call back from AS. Gear sensor gone. Same problem as Echo. :( How old is ur car and what's ur mileage? How much is the repair cost? Link to post Share on other sites More sharing options...
Travistayjh Clutched October 14, 2013 Share October 14, 2013 (edited) sorry saw the video its for 3.2 =) Edited October 14, 2013 by Travistayjh Link to post Share on other sites More sharing options...
Desmojon 1st Gear October 14, 2013 Share October 14, 2013 :( How old is ur car and what's ur mileage? How much is the repair cost? 60k plus mileage. $337 for repair. Made me skip lunch. Link to post Share on other sites More sharing options...
Theredstar 2nd Gear October 14, 2013 Share October 14, 2013 Ok Been sniffing in all the poison and wondering if there's anything I can do to improve my driving experience on the cheap And got reminded of the 'brilliant start' by turning off ASR/VDC Been reading up on turning it off Seems like got different camps on it Anyone here can put in layman term why we shld or shld not off it pls? Thx Link to post Share on other sites More sharing options...
Saabretooth 2nd Gear October 14, 2013 Share October 14, 2013 (edited) Ok Been sniffing in all the poison and wondering if there's anything I can do to improve my driving experience on the cheap And got reminded of the 'brilliant start' by turning off ASR/VDC Been reading up on turning it off Seems like got different camps on it Anyone here can put in layman term why we shld or shld not off it pls? Thx Go for defensive driving lessons....etc you will improve your driving experience by gazillion miles.... Its a mod you can carry over to any car. Edited October 14, 2013 by Saabretooth ↡ Advertisement Link to post Share on other sites More sharing options...
Soft drinks also wanna tax?
Nissan QashQai 2014 Part 2
2022 Alfa Romeo Tonale (965)
Audi A4/A5 Sportback owners thread
