Mikelcy1963 1st Gear October 17, 2013 Share October 17, 2013 Hi, I did a drain and fill thrice (at 60k, 70k and 76k) even though manual says its good for 100k miles (lifetime). Reason is slight sluggishness during gear shifts at 60k and during change fluid is milky dark brown. Even during the 3rd change at 76k, saw that the fluid is still milky darkbrown (though the sluggishness disappeared since the 1st change) Mechanic suggest a transmission flush through the fluid cooler lines (he has done it for the older 4 speed model but not this 6 speed). I was a bit surprised coz when I did my first change, was told that this transmission cannot be flush. This mechanic says the Cruze cannot be flushed (same transmission) but he *thinks* the Epica can as the cooler lines are different. What's the risk if I go ahead and attempt to flush as the milky look does not seems to be getting better ? Will I end up with a bigger problem (the net has conflicting advice to flush or not to flush) Or should I just be patient and continue to drain and fill at every 10k ? Am I throwing away my money ? (The whole transmission including the cooler uses about 10L and each drain and fill can only change 5L which part of the old oil will always be there though getting diluted by the new oil.) ↡ Advertisement Link to post Share on other sites More sharing options...
Knoobie Supercharged October 17, 2013 Share October 17, 2013 Maybe you can try asking in Chevrolet forum at www.teamchevysg.com I don't think there will be problem with it if you can do flushing from the cooler. Only problem is, is there a dipstick in place for your gearbox to ensure the amount of ATF was replaced? Link to post Share on other sites More sharing options...
Mikelcy1963 1st Gear October 17, 2013 Author Share October 17, 2013 Thanks for the advice. I forgot about teamchevysg as very irritated by their strict login/password requirements haha. And no, there is no dipstick. If I understand correctly, the amount to fill is based on the volumetric specification of this transmission system (transmission system + cooler) Even the last 3 drain and fill (5L) is from the service info available (which the workshop) Link to post Share on other sites More sharing options...
Furrynadz 5th Gear October 18, 2013 Share October 18, 2013 Hi, I did a drain and fill thrice (at 60k, 70k and 76k) even though manual says its good for 100k miles (lifetime). Reason is slight sluggishness during gear shifts at 60k and during change fluid is milky dark brown. Even during the 3rd change at 76k, saw that the fluid is still milky darkbrown (though the sluggishness disappeared since the 1st change) Mechanic suggest a transmission flush through the fluid cooler lines (he has done it for the older 4 speed model but not this 6 speed). I was a bit surprised coz when I did my first change, was told that this transmission cannot be flush. This mechanic says the Cruze cannot be flushed (same transmission) but he *thinks* the Epica can as the cooler lines are different. What's the risk if I go ahead and attempt to flush as the milky look does not seems to be getting better ? Will I end up with a bigger problem (the net has conflicting advice to flush or not to flush) Or should I just be patient and continue to drain and fill at every 10k ? Am I throwing away my money ? (The whole transmission including the cooler uses about 10L and each drain and fill can only change 5L which part of the old oil will always be there though getting diluted by the new oil.) milky is coolant contamination already, assuming you see milky correct as for the mechanic....ditch him...ur car is not a guinea pig go back alphine Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 17, 2013 Share November 17, 2013 Thanks for the advice. I forgot about teamchevysg as very irritated by their strict login/password requirements haha. And no, there is no dipstick. If I understand correctly, the amount to fill is based on the volumetric specification of this transmission system (transmission system + cooler) Even the last 3 drain and fill (5L) is from the service info available (which the workshop) If yr autobox dun hv a dipstick, where u pour in the new ATF when u fill? ↡ Advertisement Link to post Share on other sites More sharing options...
NameWee complaining of Double standard.
Mother of all Avian Influenza * (H*N*)
Poverty level in Singapore and the world, how $$$ much do you need?
Acceleration -- CVT vs auto
Clutch for Volvo V40 T4 2013 Price?
Volkswagen Announces Recall for DSG Transmission
Toyota Harrier Auto transmission problem
