  • Search this thread
  • Reply to this topic
120 replies to this topic | 132 praises
#1
Posted 23 October 2013 - 09:42 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,533
Hi,
W.R.T the photo attached, is the track still ok? Thought the side a bit botak already. Been rolling for slightly more than 40k already. It's GR-90
2DB4D604-AAB0-41F7-B945-FA7B5A73BC10-225
7E12F38B-4C83-40C1-BE83-99B6F3A32E2F-225
D2C9702B-3A80-42E3-8EC2-9F1A6A181258-225
#2
Posted 23 October 2013 - 10:08 AM
Pms
  • Premium member
    Pms
    4th Gear
    Author Image
    519
whats that? -ve 2 degree camber plus 0.5 degree toe in?
Yes you need to change.
Edited by Pms, 23 October 2013 - 10:14 AM.
#3
Posted 23 October 2013 - 10:23 AM
Ckchong8
  • Premium member
    Ckchong8
    4th Gear
    Author Image
    633
Hi,
Seems like your tire pressure deflated too much. Need to change liao.
#4
Posted 23 October 2013 - 10:58 AM
Furrynadz
  • Premium member
    Furrynadz
    Author Image
    8,362
side worn liao
underinflated
try up pressure by 30kpa at pump
#5
Posted 23 October 2013 - 11:46 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,533
side worn liao
underinflated
hmmm... maybe, because I have not pump the tire after each rotation at 10k..... always looks ok, not deflated... but actually it is..
#6
Posted 23 October 2013 - 11:51 AM
Blackyv
  • Premium member
    Blackyv
    2Fast2Furious
    Author Image
    27,364
[sweatdrop]
#7
Posted 23 October 2013 - 11:55 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,533
[sweatdrop]
But if no leakage, need to pump mei?
#8
Posted 23 October 2013 - 12:00 PM
Blackyv
  • Premium member
    Blackyv
    2Fast2Furious
    Author Image
    27,364
[sweatdrop] [sweatdrop] [sweatdrop]
#9
Posted 23 October 2013 - 12:23 PM
TVT
  • Premium member
    TVT
    NOS-ed
    Author Image
    12,620
Hi,
Its not OK, better change it.
How do you know there's no leakage when you didn't pump it? You can't based on looks or "kick tire nethod" to know if the tire had lose air.
Overtime, the tire will lose air, especially if you do not drive often, or only drive a short distance eveyday.
#10
Posted 23 October 2013 - 12:54 PM
Knoobie
  • Premium member
    Knoobie
    Supercharged
    Author Image
    5,830
if you don't change, high chance to become another victim at ECP near MBS there...
so botak liao... hazardous leh!!
Doesn't mean you drive a faster car, you can travel at 70kph on a clear lane 1 with a train of cars behind you...
that is what lane 2 is for..
#11
Posted 23 October 2013 - 01:47 PM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    45,440
You only pump airt into the tyre every 10K??  Am I understanding you correctly?
Power la!
The side of the tyres are worn out, please change la.
#12
Posted 23 October 2013 - 01:50 PM
Jman888
  • Jman888
    2Fast2Furious
    Author Image
    107,146
all 4 tyres? maybe can change the front two to new tyre and keep the better two old tyre for another 10K (if yours is fwd).
骑白马的不一定是王子,可能是唐僧;带翅膀的也不一定是天使,有时候是鸟人。
#13
Posted 23 October 2013 - 02:10 PM
Locknload
  • Premium member
    Locknload
    5th Gear
    Author Image
    1,046
Don't the shop pump the tyres after rotation as SOP or you told them no need?
Buadongdong praised this
#14
Posted 23 October 2013 - 02:39 PM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,620
is time to replace your tyre (ASAP) please
see carefully the bald part already got some colour changed.
very soon you will see the white white  thing got to change immediately
clocked 40K [thumbsup]
#15
Posted 23 October 2013 - 05:11 PM
Joajas
  • Premium member
    Joajas
    2nd Gear
    Author Image
    185
Get those tires changed, its quite dangerous at this stage of wear and raining season is already starting. You also need to check your pressure at the very least once every two weeks, else if you are like me lazy to check, then just pump air every week at the petrol kiosk nearby.
Your wear pattern is very typical of an under inflated tire.
Cheers, drive safe.
Fcw75 praised this
#16
Posted 23 October 2013 - 06:40 PM
Beregond
  • Beregond
    NOS-ed
    Author Image
    12,719
Hi,
Yes u need to get your tyre change, but seriously i believe any decent tyre shop can give u a more pro advice then most of the bro and sis here. just visit your regular tyre shop :P
#17
Posted 23 October 2013 - 11:49 PM
Furrynadz
  • Premium member
    Furrynadz
    Author Image
    8,362
#18
Posted 23 October 2013 - 11:54 PM
Wishxsr
  • Premium member
    Wishxsr
    3rd Gear
    Author Image
    479
Botak liao, dun change, wait till it burst ar.
#19
Posted 24 October 2013 - 07:50 PM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,533
ok ok thanks all!!   [drivingcar]
#20
Posted 25 October 2013 - 10:57 AM
Bluepica
  • THREAD STARTER
  • Bluepica
    5th Gear
    Author Image
    1,533
I just pumped the tire, and it's hunger for air. [sweatdrop]  dropped to only 20psi only [shocked]
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: need, change, tire
