Columbian78 6th Gear November 7, 2013 Share November 7, 2013 (edited) Starting this topic to help me choose new tyres. I will also share my experiences with tyres I had used in the past. Car: Honda jazz 1.3 Existing tyres: Some BF Goodrich tyres 195/50/15, 5 mths old These are very noisy tyres, performance is ok. But I need quiet comfortable tyres and I drive very non-aggressively. Tyres I had used before, all 195/50/15 or 195/55/15 size: Bridgestone GR80 and GR90: Meets my comfort requirements and performance no issue. Expensive, and I prefer to try tyres I had not used before. Hankook v12evo: Performance ok, very noisy Goodyear efficient grip: Good comfort tyres, but it suffered from cracks after about 1 year. My conclusion is that the cracks were caused by some tyres foam spray that I used which contains sillicon. Some articles say do not use sillicon on rubber tyres as they can cause drying and cracking. See my thread http://www.mycarforum.com/topic/2689385-need-advice-tyre-has-cracks/ I am thinking of using 195/60/15 or even 195/65/15 tyres. The "thicker" tyres might give more comfort, is this advisable? Remember that I am non-aggressive driver so the wet/dry performance and cornering (sidewall strength) is less critical. You can guess from the way I reviewed my previous tyres above. Comfort and quietness is everything. Tyres which I have shortlisted: Toyo T1R Continental CCC5, CPC5 What is the difference between these 2? Michellin XM2 Please let me know your opinions, thanks. Edited November 7, 2013 by Columbian78 ↡ Advertisement Link to post Share on other sites More sharing options...
Glyuen 3rd Gear November 7, 2013 Share November 7, 2013 (edited) Forget about T1R. CCC5 made in msia. Questionable quality. CPC5 is good! Michelin XM2 equally good. U can consider Michelin Energy Saver+ Used T1R and XM1 before. Currently on CPC5 as Michelins are more pricey. If you can sacrifice abit of grip in the wet and drive within safety limits, can consider Yokohama dB series. Edited November 7, 2013 by Glyuen 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic November 7, 2013 Share November 7, 2013 (edited) You want really quiet comfortable tyres, go for Yokohama Advan dB, made in Japan. Can get from this shop, the boss Sally is a nice lady. http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=65422 Edited November 7, 2013 by Fcw75 2 Link to post Share on other sites More sharing options...
Sabian Turbocharged November 7, 2013 Share November 7, 2013 Dunlop Blue Response. 1 Link to post Share on other sites More sharing options...
Ahgong Supercharged November 8, 2013 Share November 8, 2013 Forget about T1R. CCC5 made in msia. Questionable quality. CPC5 is good! Michelin XM2 equally good. U can consider Michelin Energy Saver+ Used T1R and XM1 before. Currently on CPC5 as Michelins are more pricey. If you can sacrifice abit of grip in the wet and drive within safety limits, can consider Yokohama dB series. hmm... what is the cons for T1R? can share your experience? Link to post Share on other sites More sharing options...
Rncw 5th Gear November 8, 2013 Share November 8, 2013 can consider PS3 too.... Link to post Share on other sites More sharing options...
Jman888 Moderator November 8, 2013 Share November 8, 2013 Tyres which I have shortlisted: Toyo T1R Continental CCC5, CPC5 What is the difference between these 2? Michellin XM2 Please let me know your opinions, thanks. how can Toyo T1R be a comfort tyre? Link to post Share on other sites More sharing options...
Columbian78 6th Gear November 8, 2013 Author Share November 8, 2013 The reason why I am looking at T1R is because it is quite cheap and made in japan. Less than $100. Plus a colleague has it and say it is decent. I tried his car which is also a jazz and thought the noise was better than mine existing setup. how can Toyo T1R be a comfort tyre? Does anybody have experience upping from 195/50/15 to 195/60/15 or 195/65/15 tyres? On a jazz especially. Does this improves the comfort and noise? Link to post Share on other sites More sharing options...
Jman888 Moderator November 8, 2013 Share November 8, 2013 The reason why I am looking at T1R is because it is quite cheap and made in japan. Less than $100. Plus a colleague has it and say it is decent. I tried his car which is also a jazz and thought the noise was better than mine existing setup. Does anybody have experience upping from 195/50/15 to 195/60/15 or 195/65/15 tyres? On a jazz especially. Does this improves the comfort and noise? for comfort and less noise, you can try Toyo C1S, i dun think it is that expensive. http://www.tyrereviews.co.uk/Tyre/Toyo/Proxes-C1S.htm Link to post Share on other sites More sharing options...
Joe6057 1st Gear November 8, 2013 Share November 8, 2013 T1R Tyre is more to sporty than comfort range. They worn out much faster as its compound is relativity soft. My last set of T1R didn't last me more than 2 years & it get noisy after about 1 year usage. However, it is very good in wet compare to the rest. My 2 cents. Link to post Share on other sites More sharing options...
Ahgong Supercharged November 8, 2013 Share November 8, 2013 T1R Tyre is more to sporty than comfort range. They worn out much faster as its compound is relativity soft. My last set of T1R didn't last me more than 2 years & it get noisy after about 1 year usage. However, it is very good in wet compare to the rest. My 2 cents. dun mind asking ah... within that 2 years, how many klick are we tokking about? Link to post Share on other sites More sharing options...
Joe6057 1st Gear November 8, 2013 Share November 8, 2013 dun mind asking ah... within that 2 years, how many klick are we tokking about? Klick??? Link to post Share on other sites More sharing options...
Iiiusion 2nd Gear November 8, 2013 Share November 8, 2013 (edited) I'm going to change to advan db next round. Reasonable price and much better than the old db series which was quite lousy in the wet. Currently using gdyear efficient grip, has a soft side wall - burst when striked kerb once. Edited November 8, 2013 by Iiiusion Link to post Share on other sites More sharing options...
Knoobie Supercharged November 8, 2013 Share November 8, 2013 can consider PS3 too.... Whats the diff between PS3 or PSS? One is comfort the other one is sports? Link to post Share on other sites More sharing options...
Mindbox33 1st Gear November 8, 2013 Share November 8, 2013 PS3 or XM2 one of the most quiet tyres... comfort quite based on individual butt feel...if ur suspension gone...best comfort tyres also no use... Link to post Share on other sites More sharing options...
Glyuen 3rd Gear November 8, 2013 Share November 8, 2013 (edited) hmm... what is the cons for T1R? can share your experience? Pros is good grip esp when wet. Tyre sidewall is quite soft so quite comfortable compared to eagle f1. but TS want comfort/quiet tyres... this doesnt quite fit it. if TS is sporty driver then i would recommend to consider T1R and not the Yokos. T1R lasted only about 40k km. My michelin XM1 lasted 60k. Michelins are quite good all round. except for price. Yokos are infamous for their wet performance. Edited November 8, 2013 by Glyuen Link to post Share on other sites More sharing options...
7seater Clutched November 8, 2013 Share November 8, 2013 maybe you can try Kumho KH31. I feel is quiet. Reasonable grip even in rain. Link to post Share on other sites More sharing options...
Ahgong Supercharged November 8, 2013 Share November 8, 2013 Pros is good grip esp when wet. Tyre sidewall is quite soft so quite comfortable compared to eagle f1. but TS want comfort/quiet tyres... this doesnt quite fit it. if TS is sporty driver then i would recommend to consider T1R and not the Yokos. T1R lasted only about 40k km. My michelin XM1 lasted 60k. Michelins are quite good all round. except for price. Yokos are infamous for their wet performance. 40k is a good enuff amount of mileage for me. so my decision to switch to it is good. Thanks for the confirmation ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
