Shox87 4th Gear November 18, 2013 Share November 18, 2013 looks good. wonder if the price is good too. haha ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Throttle2 Supersonic November 18, 2013 Share November 18, 2013 JD Power only survey consumer satisfaction, quality and dependability. They never survey consumer lust. People buy Lexus not because they lust after Lexus, but because Lexus gives them fewer problems. If you cannot tell the difference, I can safely guess that you married your wife only because she guai guai sit down there listen to you talk, she can bear you children, she can produce milk for your children, and she can cook, clean and do housework. Right? [thumbsup] Wah, you beginning to outdo me as MCF enemy leh... Heeeheeeheee 1 Link to post Share on other sites More sharing options...
Anlee045 Neutral Newbie November 19, 2013 Share November 19, 2013 Looks like CLA. Mercedes is following BMW/Audi with similar design features in different models. 2 Link to post Share on other sites More sharing options...
Carmour 4th Gear December 16, 2013 Author Share December 16, 2013 Mercedes-Benz has finally taken the wraps off the new C-Class, following a multitude of leaks and fully revealing spy photos. The C-Class is no longer Mercedes-Benz's entry-level sedan offering as this role has been at attributed to the CLA. As a consequence, the German marque had to distance the C-Class from the A-Class-based sedan and as a result the W205 generation has grown in size since it is 95mm longer (at 4686mm) and 40mm (at 1810mm) wider than its predecessor, while height stands at 1442mm. 80mm of the added length is in the wheelbase which now stands at 2840mm and the cargo capacity has been increased to 480 liters. From a design point of view it doesn't bring anything new to the table compared to its bigger E-Class facelift and all-new S-Class brothers yet it does look significantly more premium than the outgoing model. It features a long hood and shorter overhangs along with a narrower glasshouse and more flowing lines. Overall, the 2014 C-Class looks more modern and will likely attract additional younger customers without having a negative effect on the usual C-Class clients. Back in October we saw the interior cabin which looks considerably more luxurious thanks to the use of more premium materials and a wraparound dashboard with three circular air vents. There are less buttons on the dashboard as many of them have been replaced by a free-standing screen sitting on top of the dashboard which can be accessed via a rotary controller offered as standard. There's an optional touchpad which has just about the same functionality that you get on a smartphone. The 2014 Mercedes-Benz C-Class rides on the modular MRA rear-wheel drive architecture and is up to 100 kg (220 lbs) lighter than the outgoing model. As a result of this significant diet, fuel consumption has been reduced by 20 percent without affecting performance. The vehicle also has a lower center of gravity which should result in a sportier handling experience. It will be the first vehicle in this segment to be offered with air suspension in the form of an optional self-leveling AIRMATIC which is electronically controlled on both axles and features continuous variable damping. The standard steel suspension comes with a selective damping system offered in three modes: comfort, comfort with sportier character and a sports suspension which lowers the car by 15mm. Upon launch it will be offered with three engines, starting with the C 220 BlueTEC packing a 2.2-liter 4-cylinder diesel rated at 170 HP (125 kW) and 400 Nm (295 lb-ft) of torque. It will do 0-62 mph (0-100 km/h) in 8.1 seconds and will have a fuel consumption of just 4 liters / 100 km (58.8 mpg US or 70.6 mpg UK) with CO2 emissions of 103 g/km. Next is the C 180 model with a 1.6-liter gasoline engine delivering 156 HP (115 kW) and 250 Nm (184 lb-ft) which will be enough for a 0-62 mph run in 8.2 seconds. Fuel consumption will stand at 5 liters / 100 km (47 mpg US or 56.4 mpg UK) with corresponding CO2 emissions of 116 g/km. There will also be a more powerful C 200 model with a 2.0-liter outputting 184 HP (135 kW) and 300 Nm (221 lb-ft) of torque. The engine will grant the car with a 0-62 mph run in 7.5 seconds and a fuel consumption of 5.3 liters / 100 km (44 mpg US or 53.2 mpg UK), while CO2 emissions will be of 123 g/km. Shortly after the new C-Class will go on sale, Mercedes-Benz will introduce a 1.6-liter diesel that will be available with 115 HP (85 kW) / 280 Nm (206 lb-ft) and 136 HP (100 kW) / 320 Nm (236 lb-ft). In addition, the car will also be offered with a 2.2-liter diesel with 115 HP (85 kW), 204 HP (150 kW) and also with 170 HP (125 kW) in the BlueEFFICIENCY Edition. Other engines on the way are five 4-cylinder gasoline motors with output ranging from 156 HP (115 kW) to 238 HP (175 kW). In addition, there will be a C 300 BlueTEC HYBRID encompassing a 4-cylinder diesel with 204 HP (150 kW) working together with a 27 HP (20 kW) electric motor which will provide the car with a fuel consumption of just 3.9 liters / 100 km (60.3 mpg US or 72.4 mpg UK). Depending on engine choice, the 2014 Mercedes-Benz C-Class will feature a newly developed 6-speed manual gearbox or a 7G-TRONIC PLUS seven-speed automatic transmission. Optionally available will be the firm's 4MATIC all-wheel drive setup and various safety systems such as Active Parking Assist, Adaptive Highbeam Assist Plus and Traffic Sign Assist with Wrong-Way Alert. Already available on order, the new C-Class starts at 33,558 EUR in Germany for the C 180 model. Opt for the C 200 model and you will have to pay 36,414 EUR while the C 220 BlueTEC is priced at 38,675 EUR. 3 Link to post Share on other sites More sharing options...
Friendstar Supercharged December 16, 2013 Share December 16, 2013 I didn't know your product knowledge is so weak. Check JD Power. Well well... 1 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic December 16, 2013 Share December 16, 2013 this one C class and S class so identical? how to differentiate them? length? 1 Link to post Share on other sites More sharing options...
Alheych 6th Gear December 16, 2013 Share December 16, 2013 this one C class and S class so identical? how to differentiate them? length? it's a family design language thing... for sibling models to be similar to each other. last time W202 and W124 also look alike, and W203 and W220 had similar profiles as well. at least i still can tell them apart. not like looking at the front end of an Audi. really dunno A3, A4, A5, or A6 coming. 2 Link to post Share on other sites More sharing options...
slickshifters 2nd Gear December 17, 2013 Share December 17, 2013 am i the only one that think the rear is not pretty? the rear is way too short compared to the the bonnet. not balanced imo. 3 Link to post Share on other sites More sharing options...
Solar Turbocharged December 17, 2013 Share December 17, 2013 (edited) but yes, the rear is sexy edit: see this youtube vid instead... much better! http://www.youtube.com/watch?v=FpzXOY05Zxk#t=0 Edited December 17, 2013 by Solar 2 Link to post Share on other sites More sharing options...
Vidz 6th Gear December 17, 2013 Share December 17, 2013 the new C-Class starts at 33,558 EUR in Germany for the C 180 model. Opt for the C 200 model and you will have to pay 36,414 EUR while the C 220 BlueTEC is priced at 38,675 EUR. by the time it come to our little island it will prob hit $200k. can buy 3 [:|] 2 Link to post Share on other sites More sharing options...
Soya Supersonic December 17, 2013 Share December 17, 2013 Oooooohhhh......i like the Elegance version - baby S-Class. 3 Link to post Share on other sites More sharing options...
Bomby929 1st Gear December 17, 2013 Share December 17, 2013 (edited) am i the only one that think the rear is not pretty? the rear is way too short compared to the the bonnet. not balanced imo. Any longer its a E liao... but overall.. quite like the design. Edited December 17, 2013 by Bomby929 1 Link to post Share on other sites More sharing options...
Linusloh Clutched December 17, 2013 Share December 17, 2013 V V nice design Looks like a baby S class, the one with the star on the bonnet I personally think it's nicer than the new 3 series, which I still think it's v handsome and athletic. Way to go Mercs! Shame on the design of the Japs though...(with the exception of Mazda) 3 Link to post Share on other sites More sharing options...
TRD 2nd Gear December 17, 2013 Share December 17, 2013 look like the mini s class! nicee 3 Link to post Share on other sites More sharing options...
Twich 3rd Gear December 18, 2013 Share December 18, 2013 V V nice design Looks like a baby S class, the one with the star on the bonnet I personally think it's nicer than the new 3 series, which I still think it's v handsome and athletic. Way to go Mercs! Shame on the design of the Japs though...(with the exception of Mazda) Give me a break. Just came back from Gold Coast. There are so many 4×4 on the road. Especially, the Toyota Land Cruzer. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 18, 2013 Share December 18, 2013 Looks good. But i like the current C class also. Won't drive one. so nevermind 2 Link to post Share on other sites More sharing options...
Linusloh Clutched December 19, 2013 Share December 19, 2013 Give me a break. Just came back from Gold Coast. There are so many 4×4 on the road. Especially, the Toyota Land Cruzer. Bro, cool la. Talking abt car design here la. Link to post Share on other sites More sharing options...
Speed_ong Clutched December 19, 2013 Share December 19, 2013 Nicest C-class so far ↡ Advertisement 3 Link to post Share on other sites More sharing options...
W212 owners, please check-in
Mercedes CLE
Mercedes CLE
Mercedes AMG GT Gen 2
2023/2024 6th Generation Mercedes E-Class (W214)
2014 Mercedes CLA
2014 Mercedes CLA
[Spyshots] 2022 2nd Generation Mercedes Benz GLC
