Popper 1st Gear November 19, 2013 Share November 19, 2013 Avante Owners Out There, Recently encountered knocking sound at steering wheel when turning left and right or when cross over hump. Any encountered this problem and how to get ie rectified? Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Kklim Supercharged November 19, 2013 Share November 19, 2013 It's some bushing that has worn out. Lots more info on Club Hyundai but the site has been inaccessible for weeks. Read there that it's much cheaper to repair in Johore. Or try the workshop at the Esso station in Lavender Rd. Link to post Share on other sites More sharing options...
Popper 1st Gear November 19, 2013 Author Share November 19, 2013 Ya...club Hyundai is down couldn't get any info from there. U happen to have any workshop to reco in Johore? Link to post Share on other sites More sharing options...
Soya Supersonic November 19, 2013 Share November 19, 2013 Avante Owners Out There, Recently encountered knocking sound at steering wheel when turning left and right or when cross over hump. Any encountered this problem and how to get ie rectified? Cheers Could be steering rack loose or tie rod bushings worn out. Link to post Share on other sites More sharing options...
Mindbox33 1st Gear November 19, 2013 Share November 19, 2013 is it when you doing full turn (either L or R), you will hear tok tok tok sound until u turn back to straight line then the sound stop? OR Is it when you even STATIONERY (no moving), u continuously tilt slightly L & R with your steering wheel & hear tak tak tak sound? And even sometimes when u drives, you can also hear tak tak sound even with little movement of the steering wheel? BUT STRANGELY THERE IS NO SOUND WHEN U DOING FULL TURN L OR R... I encounter both: If its is first one, then drive shaft is spoilt..wear n tear. change drive shaft will do. once u got tok tok tok sound...even changing the drive shaft CV joint cover also no use as damage is done. not expensive, ard 150 per pc to change, depending where u go. If its is 2nd one, then the rubber coupling inside our electronic steering motor has worn out (also due to wear n tear)... this is very troublesome. it cost 500+ which I pay to Synergy AH Kang to settle the problem. 6 hours work to replace the bloody small coupling due to dismantling the WHOLE steering rack to reach the steering motor. and after that, u need to settle the alignment & balancing. I pay another 50 to Kenny Alignment to align my front adjustable camber bolt... hope this helps. Link to post Share on other sites More sharing options...
Picanto 3rd Gear November 19, 2013 Share November 19, 2013 does the dashboard needs to be taken out? is it when you doing full turn (either L or R), you will hear tok tok tok sound until u turn back to straight line then the sound stop? OR Is it when you even STATIONERY (no moving), u continuously tilt slightly L & R with your steering wheel & hear tak tak tak sound? And even sometimes when u drives, you can also hear tak tak sound even with little movement of the steering wheel? BUT STRANGELY THERE IS NO SOUND WHEN U DOING FULL TURN L OR R... I encounter both: If its is first one, then drive shaft is spoilt..wear n tear. change drive shaft will do. once u got tok tok tok sound...even changing the drive shaft CV joint cover also no use as damage is done. not expensive, ard 150 per pc to change, depending where u go. If its is 2nd one, then the rubber coupling inside our electronic steering motor has worn out (also due to wear n tear)... this is very troublesome. it cost 500+ which I pay to Synergy AH Kang to settle the problem. 6 hours work to replace the bloody small coupling due to dismantling the WHOLE steering rack to reach the steering motor. and after that, u need to settle the alignment & balancing. I pay another 50 to Kenny Alignment to align my front adjustable camber bolt... hope this helps. Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear November 19, 2013 Share November 19, 2013 Hi Picanto, It doesn't look like it should require the removal of the dashboard. All that work should be done on mechanical components directly affecting steering. That means, all the bits in between the two front wheels. Hope that puts your mind at ease. Link to post Share on other sites More sharing options...
GLZT 6th Gear November 19, 2013 Share November 19, 2013 Its common problem for avante. I encounter this on my previous avante. Got it fix at autosavers kaki bukit for 300+ I heard a lot of ppl paid 1k for it at AD. Link to post Share on other sites More sharing options...
Karbonphyber 1st Gear November 19, 2013 Share November 19, 2013 What needed to be fixed/replaced ? Link to post Share on other sites More sharing options...
Weitiong88 Neutral Newbie November 22, 2013 Share November 22, 2013 I facing this problem too. Was told was the steering wheel motor spoil. Cost around 3.8k to change. Any lobang for the motor? Link to post Share on other sites More sharing options...
Andrew-Chai Neutral Newbie November 25, 2013 Share November 25, 2013 Dear bro, I am encounter tis problem, and went to Hyundai dealer as saying that the electronic motor problem then need to change whole thing because that is whole set, cost ringgit Malaysia 7k plus, I would like seek who had good workshop to recommend as I need to double check the problem.thanks Link to post Share on other sites More sharing options...
Ryanngan Neutral Newbie November 26, 2013 Share November 26, 2013 Avante Owners Out There, Recently encountered knocking sound at steering wheel when turning left and right or when cross over hump. Any encountered this problem and how to get ie rectified? Cheers I had the similar problem.. as what i understand, the batch of Avante from 2006 - 2010 have this problem. I got it rectified at Harmony Motor @ AMK Autopoint.. They replaced the steering shaft coupling.. damage $300. Did wheel alignment at Stamford Tyres for $50. Link to post Share on other sites More sharing options...
Weitiong88 Neutral Newbie November 26, 2013 Share November 26, 2013 Dear bro, I am encounter tis problem, and went to Hyundai dealer as saying that the electronic motor problem then need to change whole thing because that is whole set, cost ringgit Malaysia 7k plus, I would like seek who had good workshop to recommend as I need to double check the problem.thanks Hi, I just got my steering wheel fix yesterday at Autosaver Kaki Bukit. Cost me $250 plus. At first was told at other workshop that the motor spoil and required to change whole motor at $3.8k. I do a research online and found Autosaver can change part of the motor component which is a small gear that created this problem. Now my car is back to normal. You can try. Link to post Share on other sites More sharing options...
Popper 1st Gear December 3, 2013 Author Share December 3, 2013 Thanx all for the useful info. I got it fixed yesterday. Same as what most of us encountered, it's the black little coupling bushing inside the electric motor that is worn out. Mine is like powder form when being replaced. Got mine fixed at $300+ but it took ard 3-4 hrs to get it done due to dismantling of the whole steering rack. Link to post Share on other sites More sharing options...
Help1 1st Gear December 3, 2013 Share December 3, 2013 my SIL has just got it replaced 2 mths back at komoco, not 1k. much much cheaper (less than $300). got 1 workshop in sin ming try to ketok her by quoting 3k. go to komoco n get a quote b4 committing. no harm in doing it Link to post Share on other sites More sharing options...
Hygro Clutched December 5, 2013 Share December 5, 2013 go back komoco fix it, its 300+ but at least its from dealer, got warranty if anything happens. treat it as a peace of mind then having problem next time.For servicing i would still recommend go outside do lol. Link to post Share on other sites More sharing options...
Tpdoodle Neutral Newbie December 5, 2013 Share December 5, 2013 Guys Can help with this strange Steering problem on a Toyota? During a slight bend on the road, I turn right slightly, but when I try to turn the wheel back, it feels like the wheel has been locked in a groove and can't turn back (left) unless I use more strength. For eg, i want to turn left 5 degrees but the moment i turn 1 degree, i get stuck and I need to use more strength to overcome the 'jam' and as a result i have to turn 10 degrees left. I know this isn't the best explanation but I don't know how else to describe it.Any bros who has experienced this please help! some additional info: 1) Toyota Electric Powered Steering2) This is more apparent when travelling at slightly higher speeds of 50km/h and above 3) the steering feels light but normal when the speed is <20km/h 4) this happens randomly, maybe 30% of all lane-change/bends Thanks! Link to post Share on other sites More sharing options...
valdez January 10, 2014 Share January 10, 2014 ... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Feedback
Feedback
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
Steering leather wrapping
