Celicar Turbocharged January 11, 2014 Share January 11, 2014 Of all things you post ”...”, wtf? ... ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 11, 2014 Share January 11, 2014 Of all things you post ”...”, wtf? because speechless mah... Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 23, 2015 Share May 23, 2015 is it when you doing full turn (either L or R), you will hear tok tok tok sound until u turn back to straight line then the sound stop? OR Is it when you even STATIONERY (no moving), u continuously tilt slightly L & R with your steering wheel & hear tak tak tak sound? And even sometimes when u drives, you can also hear tak tak sound even with little movement of the steering wheel? BUT STRANGELY THERE IS NO SOUND WHEN U DOING FULL TURN L OR R... I encounter both: If its is first one, then drive shaft is spoilt..wear n tear. change drive shaft will do. once u got tok tok tok sound...even changing the drive shaft CV joint cover also no use as damage is done. not expensive, ard 150 per pc to change, depending where u go. If its is 2nd one, then the rubber coupling inside our electronic steering motor has worn out (also due to wear n tear)... this is very troublesome. it cost 500+ which I pay to Synergy AH Kang to settle the problem. 6 hours work to replace the bloody small coupling due to dismantling the WHOLE steering rack to reach the steering motor. and after that, u need to settle the alignment & balancing. I pay another 50 to Kenny Alignment to align my front adjustable camber bolt... hope this helps. And now, after 7years, the second scenario as described happen to my ride... It's like got free play when turning the steering a little bit left and right.... Like the wheel going to dislodge... Actually is it still safe to drive ? Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 23, 2015 Share May 23, 2015 is it when you doing full turn (either L or R), you will hear tok tok tok sound until u turn back to straight line then the sound stop? OR Is it when you even STATIONERY (no moving), u continuously tilt slightly L & R with your steering wheel & hear tak tak tak sound? And even sometimes when u drives, you can also hear tak tak sound even with little movement of the steering wheel? BUT STRANGELY THERE IS NO SOUND WHEN U DOING FULL TURN L OR R... I encounter both: If its is first one, then drive shaft is spoilt..wear n tear. change drive shaft will do. once u got tok tok tok sound...even changing the drive shaft CV joint cover also no use as damage is done. not expensive, ard 150 per pc to change, depending where u go. If its is 2nd one, then the rubber coupling inside our electronic steering motor has worn out (also due to wear n tear)... this is very troublesome. it cost 500+ which I pay to Synergy AH Kang to settle the problem. 6 hours work to replace the bloody small coupling due to dismantling the WHOLE steering rack to reach the steering motor. and after that, u need to settle the alignment & balancing. I pay another 50 to Kenny Alignment to align my front adjustable camber bolt... hope this helps. Is this the rubber coupling mentioned here? Link to post Share on other sites More sharing options...
jakekoh619 Clutched May 24, 2015 Share May 24, 2015 I just got a 2009 Avante S and wondering if these is a defect which can be rectified? 1.Steering wheel receiving kickbacks on full left 2.Car alarm doesn't go off at all? - or anyway to test it proper? Link to post Share on other sites More sharing options...
Tonytanpk Neutral Newbie June 2, 2015 Share June 2, 2015 im having the knocking sound problem also. anyone can recommend trusted work shop and reasonable price. thanks. whatapps me 98317850. Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 2, 2015 Share June 2, 2015 Ok... My car EPS gone case.. Now I'm like driving a truck! U turning, parking is darn terrible, almost sprain my wrist. Another 3 years to go, spending few $k to replace a new power steering unit seems a bit waste... Anywhere to find scrap car to buy the second hand spare parts? Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 4, 2015 Share June 4, 2015 Ok... My car EPS gone case.. Now I'm like driving a truck! U turning, parking is darn terrible, almost sprain my wrist. Another 3 years to go, spending few $k to replace a new power steering unit seems a bit waste... Anywhere to find scrap car to buy the second hand spare parts? Adding on to what happened, I brought back the car to Msia to change the absorber since I'm visiting there on a long weekend. Fix the steering wheel freeplay problem too. After collecting the car and drove for a day, the EPS lights up and the power steering cut off... I have to use all my might to turn the car off road to restart the car. The power steering revived but not for too long, it cut off again. Brought back to workshop. They do all the rewiring and check everything again because afraid that any connection might loosen after the replacement of the rubber coupling. power steering back in working condition. The next day, in the evening after a whole day of driving, the EPS lights up again and power steering cut off again. It was night time, but thank God that mechanic still OT in workshop. Sent back to workshop, he did a scan but couldn't detect any fault. Reset the EPS and reload software. Power steering back to normal operation again. All these happened in Ipoh. Early next morning, I left Ipoh for KL. Everything work fine. when about to leave KL for SG, the EPS lights up again and power steering cut off, even after a few attempts to restart the engine. Till now, the car have no PS and I really need all my might to make a parking. I dare not attempt any parallel parking because it's really really not easy to manoeuvre the car at all. Will be sending to workshop here to check again... last resort go back to Komoco that will cost a few $Ks to change the whole steering column and EPS unit Link to post Share on other sites More sharing options...
Fanazmi Neutral Newbie September 12, 2015 Share September 12, 2015 Hi All, I have had the EPS light on for months, but my steering is still light (the power steering still works). Went to a few workshops and did a scan, error code was steering alignment out. Unable to reset the EPS. The light will go off for a few minutes, but will come back on. Was recommended to change the whole EPS unit at about $2K plus. Anyone can share their experience on this issue? Thanks in advance. From, Fanazmi Link to post Share on other sites More sharing options...
Privacy 5th Gear September 16, 2017 Share September 16, 2017 Hi All, I have had the EPS light on for months, but my steering is still light (the power steering still works). Went to a few workshops and did a scan, error code was steering alignment out. Unable to reset the EPS. The light will go off for a few minutes, but will come back on. Was recommended to change the whole EPS unit at about $2K plus. Anyone can share their experience on this issue? Thanks in advance. From, Fanazmi any update? sold the car? Link to post Share on other sites More sharing options...
Doppel Turbocharged September 16, 2017 Share September 16, 2017 Don't think you'd get a reply, his last login was almost two years ago in October 2015. Link to post Share on other sites More sharing options...
Privacy 5th Gear September 17, 2017 Share September 17, 2017 lol.. anyway not buying this model... juz curious.. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
