Spken1976 1st Gear November 26, 2013 Share November 26, 2013 Hi bros, anyone can recommend workshop that repair radiator cheap? My radiator water leaking from the top. Need to change it asap. And how much does it cost for the repair? I'm driving 2007 Nissan Latio model. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
tanbk 4th Gear November 26, 2013 Share November 26, 2013 (edited) Alan's United Auto Address : Blk 7 Sin Ming Industrial Estate Sector C #01-76 S(575642) Opening Hours : 9am - 7pm (Mon - Fri) 9am - 5pm (Sat) Closed on Sun & PHs Phone : 64538686 http://www.sgcarmart.com/directory/merchant.php?MID=10049 Edited November 26, 2013 by tanbk Link to post Share on other sites More sharing options...
Spken1976 1st Gear November 26, 2013 Author Share November 26, 2013 Alan's United Auto Address : Blk 7 Sin Ming Industrial Estate Sector C #01-76 S(575642) Opening Hours : 9am - 7pm (Mon - Fri) 9am - 5pm (Sat) Closed on Sun & PHs Phone : 64538686 http://www.sgcarmart.com/directory/merchant.php?MID=10049 Thks. Any idea how much does it cost? Link to post Share on other sites More sharing options...
Celicar Turbocharged November 26, 2013 Share November 26, 2013 If you driving till 2017, then get a new one Dang Ki. Buy from stockist and get workshop to fix. Sorry I not driving Nissan so dunno which stockist for Nissan. Link to post Share on other sites More sharing options...
Jansonchua 2nd Gear November 26, 2013 Share November 26, 2013 Hi bros, anyone can recommend workshop that repair radiator cheap? My radiator water leaking from the top. Need to change it asap. And how much does it cost for the repair? I'm driving 2007 Nissan Latio model. Thanks. Radiators don't come cheap... I believe a new one will cost you around 700+ and OEM around 300+... I am not sure if Nissan have OEM parts and whether is it compatible. The top of my radiator was also leaking but was soldered back and secured by a cable tie. I not sure who did the repair as it was already in the state when I bought it but so far no problem. If possible to repair then don't change. Stockists might not have radiator in stock as well so might need to wait in some cases. If you decide to buy from stockists and change in Bolehland, can PM me. You can try to find nissan stockists at Queens street (somewhere near hotel royal @ queens or Iluma shopping centre)... there is a housing block there with a few stockists on ground floor. Link to post Share on other sites More sharing options...
Spken1976 1st Gear November 26, 2013 Author Share November 26, 2013 [name=Jansonchua" post="5046118" timestamp="1385465460] Radiators don't come cheap... I believe a new one will cost you around 700+ and OEM around 300+... I am not sure if Nissan have OEM parts and whether is it compatible. The top of my radiator was also leaking but was soldered back and secured by a cable tie. I not sure who did the repair as it was already in the state when I bought it but so far no problem. If possible to repair then don't change. Stockists might not have radiator in stock as well so might need to wait in some cases. If you decide to buy from stockists and change in Bolehland, can PM me. You can try to find nissan stockists at Queens street (somewhere near hotel royal @ queens or Iluma shopping centre)... there is a housing block there with a few stockists on ground floor. Hi thks for your advice. Think have to go straight to workshop as the top is leaking quite badly. Unable to travel to stocklist sourcing for radiator. But heard Nissan Latio radiator top is made of plastic, so hope I vould change that part only. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 26, 2013 Share November 26, 2013 If you driving till 2017, then get a new one Dang Ki. Buy from stockist and get workshop to fix. Sorry I not driving Nissan so dunno which stockist for Nissan. If its just a minor leak, I wud prefer to get it properly repaired. Replacment might b a cheepo low quality radiator which wil give more problems later. Also it wil cost more than a repair. Now many China made rads on the market. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 26, 2013 Share November 26, 2013 [name=Jansonchua" post="5046118" timestamp="1385465460] Hi thks for your advice. Think have to go straight to workshop as the top is leaking quite badly. Unable to travel to stocklist sourcing for radiator. But heard Nissan Latio radiator top is made of plastic, so hope I vould change that part only. For many years radiators core is made of plastic. Nothing new. Only the top n bottom is metal. Usually the join wil leak n ty just remove, clean n replace back with new clips. I had mine repaired in JB last year. After repair its as good as new. Cost abt <RM200. Better repair the original rad properly than to change cos the replacement rad might not b as good quality n u wil hv more problems later. Link to post Share on other sites More sharing options...
Spken1976 1st Gear November 27, 2013 Author Share November 27, 2013 For many years radiators core is made of plastic. Nothing new. Only the top n bottom is metal. Usually the join wil leak n ty just remove, clean n replace back with new clips. I had mine repaired in JB last year. After repair its as good as new. Cost abt <RM200. Better repair the original rad properly than to change cos the replacement rad might not b as good quality n u wil hv more problems later. Hi at the workshop now. Lucky just change the top cover only. Total damage $100 plus. Link to post Share on other sites More sharing options...
tanbk 4th Gear November 27, 2013 Share November 27, 2013 Hi at the workshop now. Lucky just change the top cover only. Total damage $100 plus. Bro, so which workshop you went to? Link to post Share on other sites More sharing options...
Spken1976 1st Gear November 27, 2013 Author Share November 27, 2013 Bro, so which workshop you went to? Hi Tek Soon Motors at Kaki Bukit Autobay #01-93. Total damage $189.$120 - Radiator cover $60 - labour $9 - coolant. Link to post Share on other sites More sharing options...
Pisces69 6th Gear November 27, 2013 Share November 27, 2013 Hi at the workshop now. Lucky just change the top cover only. Total damage $100 plus. Glad to hear u solved yr problem. $100 plus is abt right for fixing top of rad. Make sure u put in the correct type n amt of coolant. Run for next few days check for leak every day just in case. ↡ Advertisement Link to post Share on other sites More sharing options...
Green fingers anyone?
Car repair and maintenance
