Charmaine12 3rd Gear January 13, 2014 Share January 13, 2014 CPC 5 MICHELIN ENERGY SAVER PLUS YOKO V551 Goodyear efficient grip ↡ Advertisement Link to post Share on other sites More sharing options...
Kawasaki January 13, 2014 Share January 13, 2014 Continental CC5 Link to post Share on other sites More sharing options...
Lydiachristopher 3rd Gear January 13, 2014 Share January 13, 2014 Best comfort and low noise is V551, i change after week usage, rainy day was terrifying. Good for auntie and uncle drive slow and smooth, for young man, not suitable at all. Link to post Share on other sites More sharing options...
Beregond Supersonic January 13, 2014 Share January 13, 2014 CPC 5 MICHELIN ENERGY SAVER PLUS YOKO V551 Goodyear efficient grip michelin u try go for primacy 3, their latest flagship. efficientgrip is soft, but u might get turn off by the wooby sidewall. yoko 551 is quiet, but as usual, raining days very bad u can consider dunlop ve302 and toyo c1s , both tread pattern very simplar to gr90 and both make in japan. but price much cheaper. :) Link to post Share on other sites More sharing options...
Alan9711 Neutral Newbie January 13, 2014 Share January 13, 2014 I just changed to continental CPC2 at stamford as recommended.. So far so good Link to post Share on other sites More sharing options...
Maskedrider 4th Gear January 13, 2014 Share January 13, 2014 Dunlop V302 My second time change to same brand /model Quiet and comfort , no regret Link to post Share on other sites More sharing options...
Deckbuild 6th Gear January 14, 2014 Share January 14, 2014 Continental CC5, comfy and damn quiet. Link to post Share on other sites More sharing options...
Baal Supersonic January 14, 2014 Share January 14, 2014 FireStone TZ700 ? Seems ok so far. Wet not bad also. But I'm an uncle driver. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear January 14, 2014 Share January 14, 2014 CPC 5 MICHELIN ENERGY SAVER PLUS YOKO V551 Goodyear efficient grip of the lot here get michelin cpc5 wear fast yoko 551...u prepare a lot of $ for insurance excess or pvt settlement efficientgrip soft sidewall and not worth the money Link to post Share on other sites More sharing options...
Dalenico 1st Gear January 14, 2014 Share January 14, 2014 FireStone TZ700 ? Seems ok so far. Wet not bad also. But I'm an uncle driver. Used the Firestone TZ700 for about a month, quite affordable. Find it overall ok but braking distance is a little worse than KU31. Sidewall is also harder. As for noise, well, relatively quiet but there is a soft drone constantly from 40kmh onwards. Not loud but can tell it is the wind generated as the tyres roll.... Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear January 14, 2014 Author Share January 14, 2014 Just to ask how come ppl dont like soft wall, I tot softwall absorb more bumps Link to post Share on other sites More sharing options...
Baal Supersonic January 14, 2014 Share January 14, 2014 (edited) Used the Firestone TZ700 for about a month, quite affordable. Find it overall ok but braking distance is a little worse than KU31. Sidewall is also harder. As for noise, well, relatively quiet but there is a soft drone constantly from 40kmh onwards. Not loud but can tell it is the wind generated as the tyres roll.... Drone could be from the 4 drainage lines? My is 175/65, hence didnt notice it was hard. But saw a GLX with 195/55, & it was those flat surface hard sidewall type. Likewise when i saw a 205/55 on a wish. Unsure on this but yes, first few weeks notice didnt stop too well but improved along the way. Not sure if its due to my foot adapting. Edited January 14, 2014 by Baal Link to post Share on other sites More sharing options...
Furrynadz 5th Gear January 14, 2014 Share January 14, 2014 Just to ask how come ppl dont like soft wall, I tot softwall absorb more bumps too soft is not good, especialy if u need to swerve or ebrake, or hard cornering is soft is good might as well use 4 marshmallows Link to post Share on other sites More sharing options...
Dalenico 1st Gear January 14, 2014 Share January 14, 2014 Drone could be from the 4 drainage lines? My is 175/65, hence didnt notice it was hard. But saw a GLX with 195/55, & it was those flat surface hard sidewall type. Likewise when i saw a 205/55 on a wish. Unsure on this but yes, first few weeks notice didnt stop too well but improved along the way. Not sure if its due to my foot adapting. =============================================== I used it over a month plus, almost 2k now..the soft hollow drone is something I noticed right after I changed out my KU31 which sounded like bad wheel bearing...Yes, you are right..the drainage lines are quite wide and deep and maybe emitting the drone..did you notice that as well? Not loud but could notice it..it doesn't get louder as you speed though. Braking is acceptable. Wet handling is not bad but I did not push hard. Mine is 235/45/R18..got it at 180 dollars. Link to post Share on other sites More sharing options...
Baal Supersonic January 14, 2014 Share January 14, 2014 (edited) droning, did not really notice as my ride doesnt have good sound insulation for starters.....hence if there was droning, probably just mixed in together with other wind/wheel arch noises. The deep wide drain lines were the 1st thing I noticed from eye power. Guess should be great against hydroplaning. My 175/65 - 14 was $95/piece. budget budget. Edited January 14, 2014 by Baal Link to post Share on other sites More sharing options...
Dalenico 1st Gear January 14, 2014 Share January 14, 2014 droning, did not really notice as my ride doesnt have good sound insulation for starters.....hence if there was droning, probably just mixed in together with other wind/wheel arch noises. The deep wide drain lines were the 1st thing I noticed from eye power. Guess should be great against hydroplaning. My 175/65 - 14 was $95/piece. budget budget. Yeap, I always aim for budget tyres as well...as unforeseen circumstances like puncture and my ride is quite proned to uneven wear..so I do change tires between 25k to 35k...hence no point buying premium performance tyres. My car sound insulation is also no good...worse, I am on coilovers... Link to post Share on other sites More sharing options...
Wt_know Supersonic January 14, 2014 Share January 14, 2014 (edited) if you want quiet and comfy ... exclude all "performance" tyre performance vs quiet and comfy is mutually exclusive any non performance tyres are quiet and comfy. then, depends on pricing and size and of course brand that you like (have confident) Edited January 14, 2014 by Wt_know Link to post Share on other sites More sharing options...
Pisces69 6th Gear January 14, 2014 Share January 14, 2014 Just to ask how come ppl dont like soft wall, I tot softwall absorb more bumps Cos most of the kaki posting here r from F1. Yeap, I always aim for budget tyres as well...as unforeseen circumstances like puncture and my ride is quite proned to uneven wear..so I do change tires between 25k to 35k...hence no point buying premium performance tyres. My car sound insulation is also no good...worse, I am on coilovers... Hmmmmmmm.........................Seems quite unususal. Yr car on coilovers n u use a budget low grip tire? ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre puncture
Tyre puncture
Yokohama Advan Apex V601
