CWC Clectrical Engineering Service - Electrician
LifePro_Tips
CWC Electrical Engineering Service ("CWC") is a government-licensed electrical firm that has over 20 years experience in professional electrical installation, maintenance and repair work.
Our expertises also include fixing power failure, power tripping, electrical engineering works, electrical testing, blackout, new wiring, short circuit, rewiring and electrical extension. All electrical work must be undertaken or carried out by a licensed electrical worker. Such electrical work includes new wiring, rewiring and extensions which have to be tested before the supply is turned on. Power failure is certain, if the electrical work is not handled by a licensed electrician. When consumer needs any electrical work to be done at his premises, he is advised to check that the electrician whom he intends to engage to undertake or perform the electrical work has a valid electrical worker licence issued by the Energy Market Authority (EMA).To ensure quality result for major projects, CWC licensed electricians conducts comprehensive site survey and audit before commencement of electrical work to ensure adherence to authority requirement to Singapore Standard CP5 1998 (ICS 29.020), Code of Practice for Electrical Installations.
CWC electricians designs, installs, repairs, maintains, operates, inspects and test electrical / supply installations where the operating voltage of such installation does not exceed 1000 volts and the approved load of such electrical installation does not exceed 45 kVA.As CWC electricians are licensed by EMA/BCA/IDA, you can have a great peace of mind, knowing that CWC electricians provide safe and professional electrical services.
CWC Electricial Engineering Service
8 Burn Road #08-02/03 Trivex Singapore 369977
Phone: 9858 7555
Website: www.cwc.com.sg
Guest
