Evillusion Supersonic April 10, 2014 Share April 10, 2014 I guess its cheaper to do massacre...so sad.not only cheaper but no truth will get leaked out! nobody will be the wiser! ↡ Advertisement Link to post Share on other sites More sharing options...
Karoon Turbocharged April 10, 2014 Share April 10, 2014 just speculating, if someone wants the plane to crash, 3 weeks (where they pin point the location) is about enough time for them to clean up all the debris or conversely, enough time to park the evidence Link to post Share on other sites More sharing options...
Dankoo 4th Gear April 10, 2014 Share April 10, 2014 nope. water is just another fluid. just like air. plane design is aerodynamic. if it goes 90 degrees down, it has a chance of sinking in a whole piece. Hitting water at high speed is not the same. Surface tension will cause it to be almost like concrete. Although airplane is aerodynamically designed, they have a velocity limit before parts start to tear from the stress. This report may give some light, especially scenario1 1. A STEEP DIVE: If the plane ran out of fuel at its normal cruising altitude and the pilots were incapacitated, the autopilot would stop working and the aircraft could dip into an increasingly steep and rapid dive, aviation experts said. Under this scenario, the plane could hit the water nose-first and close to perpendicular with the surface. The wings and tail would be torn away and the fuselage could reach a depth of 30 meters or 40 meters within seconds, then sink without resurfacing. Wing pieces and other heavy debris would descend soon afterward. Whether buoyant debris from the passenger cabin -- things like foam seat cushions, seatback tables and plastic drinking water bottles -- would bob up to the surface would depend on whether the fuselage ruptured on impact, and how bad the damage was. "It may have gone in almost complete somehow, and not left much on the surface," said Jason Middleton, an aviation professor at Australia's University of New South Wales. Any floating debris left would be in a relatively contained area, but would begin drifting apart. Most would eventually become waterlogged and sink, though items such as foam seat cushions could float almost indefinitely, Middleton said. http://www.syracuse.com/news/index.ssf/2014/04/4_possible_ways_malaysia_fligh.html Link to post Share on other sites More sharing options...
Porker Turbocharged April 10, 2014 Share April 10, 2014 nope. water is just another fluid. just like air. plane design is aerodynamic. if it goes 90 degrees down, it has a chance of sinking in a whole piece. Not true. The surface tension of water is tremendous especially when you hit it at high speed. Link to post Share on other sites More sharing options...
Babyt 4th Gear April 10, 2014 Share April 10, 2014 would the plane landed slowly on the seawater n then sink entirely in 1 piece? 1 Link to post Share on other sites More sharing options...
Yeshe Turbocharged April 10, 2014 Share April 10, 2014 Not true. The surface tension of water is tremendous especially when you hit it at high speed. like jumping into the water belly first? Ouch Link to post Share on other sites More sharing options...
Kangadrool Supersonic April 10, 2014 Share April 10, 2014 If you ride motorcycle..... The rain drops hitting you at speed is already bad enough. Don't talk about airframe hitting waters at great speed. Link to post Share on other sites More sharing options...
2BDriver Hypersonic April 10, 2014 Share April 10, 2014 (edited) would the plane landed slowly on the seawater n then sink entirely in 1 piece? Jet plane is air tight and it also known as air ship in olden days, if there is a opening for water getting in, it will sink but objects and passenger inside are also able to sweep into the sea where search team can find them. Edited April 10, 2014 by Fongmy Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged April 11, 2014 Share April 11, 2014 would the plane landed slowly on the seawater n then sink entirely in 1 piece? Sink in 1 complete piece is no easy feat … Then again, I'm no aviation expert … Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic April 11, 2014 Share April 11, 2014 Sink in 1 complete piece is no easy feat … Then again, I'm no aviation expert … I thought you just bought 2 birds to studied it .... Link to post Share on other sites More sharing options...
Jman888 Moderator April 11, 2014 Share April 11, 2014 I thought you just bought 2 birds to studied it .... you mean he drown the poor birds? Link to post Share on other sites More sharing options...
Chowyunfatt Turbocharged April 11, 2014 Share April 11, 2014 I thought you just bought 2 birds to studied it .... KNN…Buy 2 birds can become aviation expert … You got take your Meds today or not? you mean he drown the poor birds? Not drown lar ... But must bath & apply soap … Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic April 11, 2014 Share April 11, 2014 KNN…Buy 2 birds can become aviation expert … You got take your Meds today or not? You never study their flight angles when they (birds) do the landing to bathe..... Same theory mar ...... or maybe not ... you mean he drown the poor birds? His 'bird' only explore bushy cave ..... The birdies he bought explore the cage .. Link to post Share on other sites More sharing options...
Evillusion Supersonic April 11, 2014 Share April 11, 2014 You never study their flight angles when they (birds) do the landing to bathe..... Same theory mar ...... or maybe not ... His 'bird' only explore bushy cave ..... The birdies he bought explore the cage .. when i bathe my bird i make sure its fully covered in soap then i stroke gently! Right or wrong har? 1 Link to post Share on other sites More sharing options...
The_Bear Turbocharged April 11, 2014 Share April 11, 2014 when i bathe my bird i make sure its fully covered in soap then i stroke gently! Right or wrong har? As long as you stroke yours and I stroke mine, no major issue. 2 Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic April 11, 2014 Share April 11, 2014 when i bathe my bird i make sure its fully covered in soap then i stroke gently! Right or wrong har? Very wrong ...... :angry: You should use "Oil of Ulan" to get a better textures ..... 2 Link to post Share on other sites More sharing options...
Jman888 Moderator April 11, 2014 Share April 11, 2014 when i bathe my bird i make sure its fully covered in soap then i stroke gently! Right or wrong har? nothing wrong as long as the soap dun get into the eyes, its farking painful. 2 Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic April 11, 2014 Share April 11, 2014 nothing wrong as long as the soap dun get into the eyes, its farking painful. if you feel pain in the 'eye' after soap apply to the stroke, bro, you got infections ... ↡ Advertisement Link to post Share on other sites More sharing options...
Singaporean woman goes missing in Spain, family appeals for information
Airline starts weighing passengers at the gate
Perodua Bezza
Perodua Bezza
MAS unveils commemorative S$10 coin to mark Lee Kuan Yew's 100th birth anniversary
MAS to allow online nomination of insurance beneficiaries
Taxi goes to Cat E.....impact on Cat A?
New stations, line extensions planned for Singapore’s MRT
