Rastaman01 2nd Gear March 8, 2014 Share March 8, 2014 Hi all....am looking to play music from my samsung phone and to transmit to my car radio through the radio frequency..... looking for any device that allows me to transmit my phone songs played to a radio frequency... my car head unit is stock and has no input ports... ↡ Advertisement Link to post Share on other sites More sharing options...
Vid Hypersonic March 8, 2014 Share March 8, 2014 Hi all....am looking to play music from my samsung phone and to transmit to my car radio through the radio frequency..... looking for any device that allows me to transmit my phone songs played to a radio frequency... my car head unit is stock and has no input ports... Get a FM transmitter. Easily found on aliexpress or dx.com. Very cheap only but sound quality may not be the best. Link to post Share on other sites More sharing options...
Spanly 5th Gear April 6, 2017 Share April 6, 2017 My car audio system finally kaput Started off few mths back with all input being jammed; meaning i'm stuck to the preset radio station & I can't switch station, adjust vol, go to cd mode etc.. Mine is those factory fitted type so is more troublesome... checked with a car audio shop & said replacing a new audio set & including some modification to fit the console will come close to $1k. Asked my workshop who help to check the cost of bringing in original audio set from Ford also worked out to almost the same $1k amount. Reluctant to spend the 1k as the car is only left with 2 yrs & likely will be changing & not renewing COE. So decide to leave with the only radio channel available. However, yesterday after getting my alternator replaced, the radio also failed liao... So sian to drive in silence this morning Apart from having to resort to listening through my phone FM radio, any cheaper suggestion?? My car has an auxiliary input but not sure if can still use as i can't switch to this mode since the audio control is already dead. TIA! Link to post Share on other sites More sharing options...
Nicolas33 Neutral Newbie April 10, 2017 Share April 10, 2017 Yeah, also think that FM transmitter can help you in this case. Thanks! Link to post Share on other sites More sharing options...
Qaz20 3rd Gear April 11, 2017 Share April 11, 2017 My car audio system finally kaput Started off few mths back with all input being jammed; meaning i'm stuck to the preset radio station & I can't switch station, adjust vol, go to cd mode etc.. Mine is those factory fitted type so is more troublesome... checked with a car audio shop & said replacing a new audio set & including some modification to fit the console will come close to $1k. Asked my workshop who help to check the cost of bringing in original audio set from Ford also worked out to almost the same $1k amount. Reluctant to spend the 1k as the car is only left with 2 yrs & likely will be changing & not renewing COE. So decide to leave with the only radio channel available. However, yesterday after getting my alternator replaced, the radio also failed liao... So sian to drive in silence this morning Apart from having to resort to listening through my phone FM radio, any cheaper suggestion?? My car has an auxiliary input but not sure if can still use as i can't switch to this mode since the audio control is already dead. TIA! Bro, install a separate headunit.. Just ignore the original. Link to post Share on other sites More sharing options...
Unfair 3rd Gear April 11, 2017 Share April 11, 2017 My car audio system finally kaput Started off few mths back with all input being jammed; meaning i'm stuck to the preset radio station & I can't switch station, adjust vol, go to cd mode etc.. Mine is those factory fitted type so is more troublesome... checked with a car audio shop & said replacing a new audio set & including some modification to fit the console will come close to $1k. Asked my workshop who help to check the cost of bringing in original audio set from Ford also worked out to almost the same $1k amount. Reluctant to spend the 1k as the car is only left with 2 yrs & likely will be changing & not renewing COE. So decide to leave with the only radio channel available. However, yesterday after getting my alternator replaced, the radio also failed liao... So sian to drive in silence this morning Apart from having to resort to listening through my phone FM radio, any cheaper suggestion?? My car has an auxiliary input but not sure if can still use as i can't switch to this mode since the audio control is already dead. TIA! I assume your existing headunit is 2 din and you are just interested in Radio, so a bracket costs 100 or less, a 2nd hand head unit can be gotten for 200 ? Can also consider 1 din and get the shop to fabricate a cover or flip cover to hide the extra space ? Probably go look for 2nd hand brackets first from scrapping Fords. 1 Link to post Share on other sites More sharing options...
Spanly 5th Gear April 11, 2017 Share April 11, 2017 I assume your existing headunit is 2 din and you are just interested in Radio, so a bracket costs 100 or less, a 2nd hand head unit can be gotten for 200 ? Can also consider 1 din and get the shop to fabricate a cover or flip cover to hide the extra space ? Probably go look for 2nd hand brackets first from scrapping Fords. Yes, radio would do just fine. My current look like that (taken some mths back; now don't even have radio liao). The fabrication & bracket would probably cost.. don't mind if all in including the radio can get around 200. Any recommendation? Link to post Share on other sites More sharing options...
Sktan10 5th Gear April 11, 2017 Share April 11, 2017 Hi all....am looking to play music from my samsung phone and to transmit to my car radio through the radio frequency..... looking for any device that allows me to transmit my phone songs played to a radio frequency... my car head unit is stock and has no input ports... Try these. Cheap & good. http://list.qoo10.sg/item/CAR-MP3-FM-RADIO-MODULATOR-TRANSMITTER-WIRELESS-MUSIC-PLAYER/425875456 Link to post Share on other sites More sharing options...
Unfair 3rd Gear April 11, 2017 Share April 11, 2017 Yes, radio would do just fine. My current look like that (taken some mths back; now don't even have radio liao). The fabrication & bracket would probably cost.. don't mind if all in including the radio can get around 200. Any recommendation? If you dont mind the look can always remove the existing Headunit, simply attach a 1 din headunit about <$100 and use industrial double side tape to mount in the recess area ? Thats what a lot of lorries do to save time/money. Link to post Share on other sites More sharing options...
Cypher 4th Gear April 11, 2017 Share April 11, 2017 Yes, radio would do just fine. My current look like that (taken some mths back; now don't even have radio liao). The fabrication & bracket would probably cost.. don't mind if all in including the radio can get around 200. Any recommendation? For S$200/RM600 budget can try go JB and do..need to find workshop though.. Link to post Share on other sites More sharing options...
Unfair 3rd Gear April 11, 2017 Share April 11, 2017 Wow. i see on lazada got headunits quite cheap.http://www.lazada.sg/bolehdeals-1010bt-bluetooth-car-audio-stereo-fmusbsdmp3-player1din-24v-intl-14959713.html?gclid=CjwKEAjw_bHHBRD4qbKukMiVgU0SJADr08ZZJxBG8hOTmqk1WSJdsug9PEbz7GeNFMk-_Exbht-22BoCV7jw_wcB&s_kwcid=AL!4281!3!147397946336!!!g!!&utm_source=google&utm_medium=sem_non_brand&utm_campaign=669965911&utm_content=BO954OTAA8WMZLSGAMZ-17783874&utm_term=36078506313_c_aud-279560016429:pla-260689821060&adjust_tracker=t2v78t_5n20iw&adjust_campaign=669965911&adjust_adgroup=36078506313&adjust_creative=_&adjust_label={%22ClientID%22:%22441-004-5453%22}&adjust_tracker_limit=100000&ef_id=WLkj8gAAAKTnuzjp:20170411080828:s Link to post Share on other sites More sharing options...
Qaz20 3rd Gear April 15, 2017 Share April 15, 2017 (edited) I had a 2nd headunit in my glove compartment. Edited April 15, 2017 by Qaz20 Link to post Share on other sites More sharing options...
Budgetice 3rd Gear April 16, 2017 Share April 16, 2017 Yes, radio would do just fine. My current look like that (taken some mths back; now don't even have radio liao). The fabrication & bracket would probably cost.. don't mind if all in including the radio can get around 200. Any recommendation? Ford fiesta need to buy canbus leh, not only do bracket.. go connects2 website and find your suitable mounting and canbus Link to post Share on other sites More sharing options...
Spanly 5th Gear April 16, 2017 Share April 16, 2017 Ford fiesta need to buy canbus leh, not only do bracket.. go connects2 website and find your suitable mounting and canbus Thanks for the advice... Really troublesome sia... well guess that's the trouble to go thru by not driving a typical Jap/Korean make [:p]Most can just easily swap out & replaced the faulty headunit. No regret though as my Fiesta has been a joy to drive all these years I've given up & have just brought a bluetooth speaker with FM radio for use since likely be changing my ride within this year. Link to post Share on other sites More sharing options...
Budgetice 3rd Gear April 18, 2017 Share April 18, 2017 Thanks for the advice... Really troublesome sia... well guess that's the trouble to go thru by not driving a typical Jap/Korean make [:p]Most can just easily swap out & replaced the faulty headunit. No regret though as my Fiesta has been a joy to drive all these years I've given up & have just brought a bluetooth speaker with FM radio for use since likely be changing my ride within this year. Yeah.. ford is addictive Link to post Share on other sites More sharing options...
justalex Neutral Newbie November 16, 2017 Share November 16, 2017 The solution may not be that hard. You could buy a high quality car radio.If you don't want a big one, they also have mini one, cheap and convenient.My advice is not to use your phone to listen to the music.Now a car Mp3 player is not so expensive. Good advice. I also think so. I wouldn't be buying chip HU but even not expensive one will be definitely better than FM transmitter. ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
