tylerlee August 24, 2016 Share August 24, 2016 You must contact to Locksmith in Miami for emergency services as they are excellent professionals. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
BanCoe Hypersonic August 24, 2016 Share August 24, 2016 You must contact to Locksmith in Miami for emergency services as they are excellent professionals. Huh??? after how many days they come ?? they fly 1st class, business class or cattle class If like that cheaper to ram head or sledgehammer the gate or door and get a new one cheaper locally (frame included too) 1 Link to post Share on other sites More sharing options...
Mcf777 Turbocharged August 24, 2016 Share August 24, 2016 Huh??? after how many days they come ?? they fly 1st class, business class or cattle class If like that cheaper to ram head or sledgehammer the gate or door and get a new one cheaper locally (frame included too) Miami Car Forum Link to post Share on other sites More sharing options...
Kb27 Supersonic August 24, 2016 Share August 24, 2016 Locksmith makes big bucks in USA. Need to spam half way around the world. Link to post Share on other sites More sharing options...
BanCoe Hypersonic August 24, 2016 Share August 24, 2016 Miami Car Forum I only know Miami VICE, many here are familiar with Miami Vice than Miami Forum 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic January 17, 2017 Share January 17, 2017 Let me see if there is negative points in MCF... Locksmith are always willing to aid your home security.But before hiring any locksmith for installing locks in your home check whether your locksmith have experience in handling locking systems.Do confirm those things before hiring any Locksmith in your area. Link to post Share on other sites More sharing options...
Albeniz Turbocharged March 25, 2017 Share March 25, 2017 Has anyone called a locksmith to open the letterbox and replace with a new lock before? Link to post Share on other sites More sharing options...
Columbian78 6th Gear September 19, 2017 Share September 19, 2017 Letterbox lock is quite easy to change ownself cos the size is quite standard. I did it myself. Just last weekend, the lock on one of my bedroom doors failed suddenly (with the door closed). Luckily no one was inside the room when it happened. Something to do with the mechanism that pulls the stopper so that door can open when you turn the knob. This is the worst kind of failure as you cannot open the door regardless of which side you are in and having key does not help. I called one of the 24h locksmith whom had pasted stickers outside my door and had it changed for $40 plus $50 for emergency open service. After that I felt stress thinking about the other door locks also failing. I have a 2 year old toddler. A very bad case would be I am locked in the bathroom while tod is outside, no one else at home and I have no phone to call for help. Has anyone called a locksmith to open the letterbox and replace with a new lock before? Link to post Share on other sites More sharing options...
inlinesix Supersonic November 20, 2018 Share November 20, 2018 @radx Link to post Share on other sites More sharing options...
Solar Turbocharged October 28, 2020 Share October 28, 2020 Just found that the safe has run out of battery and somehow the spare key can't open it (or I forgotten the sequence). Also found that the safe I bought from is via a reseller. They can't do anything. Any suggestion whether the locksmith can open, or my options? Link to post Share on other sites More sharing options...
Jman888 Moderator October 28, 2020 Share October 28, 2020 24 minutes ago, Solar said: Just found that the safe has run out of battery and somehow the spare key can't open it (or I forgotten the sequence). Also found that the safe I bought from is via a reseller. They can't do anything. Any suggestion whether the locksmith can open, or my options? battery is inside the safe? Link to post Share on other sites More sharing options...
Solar Turbocharged October 28, 2020 Share October 28, 2020 1 hour ago, Jman888 said: battery is inside the safe? Yes it's inside. I have the key, but can't open. I think it requires some combination and sequence but have lost the manual. Link to post Share on other sites More sharing options...
Jman888 Moderator October 28, 2020 Share October 28, 2020 5 minutes ago, Solar said: Yes it's inside. I have the key, but can't open. I think it requires some combination and sequence but have lost the manual. strange design to have it inside, lucky mine is outside and i make it a habit to put $50 in the safe every month so that it gets to operate regularly, and get the warning of low batt before it died. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 28, 2020 Share October 28, 2020 Is it a cheap safe? Blow torch to cut open. Got try searching Youtube first or not? Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 28, 2020 Share October 28, 2020 3 hours ago, Solar said: Yes it's inside. I have the key, but can't open. I think it requires some combination and sequence but have lost the manual. Had same predicament like you. Screw driver, chisel and a hammer to pry it open. Now it's still a safe but without any lock. Not safe for now. 1 2 Link to post Share on other sites More sharing options...
13177 Supersonic October 28, 2020 Share October 28, 2020 3 hours ago, Jman888 said: strange design to have it inside, lucky mine is outside and i make it a habit to put $50 in the safe every month so that it gets to operate regularly, and get the warning of low batt before it died. All have safe in your house de? Got so many valuable stuff to put ah? Lol. Link to post Share on other sites More sharing options...
Tkseah Supercharged October 28, 2020 Share October 28, 2020 Me use the traditional key + dial type of safe.. no battery.. hopefully I dun forget the combination.. haha.. Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic October 29, 2020 Share October 29, 2020 23 hours ago, Jman888 said: strange design to have it inside, lucky mine is outside and i make it a habit to put $50 in the safe every month so that it gets to operate regularly, and get the warning of low batt before it died. So stingy, $50/- niah ..... Put in $1000/- in a stack of $50/- notes... After 5 years (60 months = $60k), can take out and pay for down payment of a new car.... So every 5 years, change car ... ↡ Advertisement 5 Link to post Share on other sites More sharing options...
National Service in Singapore
Bad service from Top93, ubi
How to feedback on hospital service?
House painting
House painting
Maintenance Tips For Beginners/First Time Car Owners
Recommendation for locksmith
