Donut Supercharged March 11, 2014 Share March 11, 2014 http://sg.news.yahoo.com/5-signs-might-something-wrong-car-114202229.html You don't always need to visit the workshop to find out if there is something wrong with your car. Just pay attention to the signs. The cars of today aren’t the unreliable, poorly built, rust buckets their ancestors were. In terms of reliability, service life and safety standards, the cars of today are light years ahead of the humdrum econoboxes they were derived from. But because of these reasons, many believe that spotting problems with modern cars is something best left to the professionals. Though this is true when it comes to engine and gearbox performance, other issues don’t require a degree in Mechanical Engineering to figure out something is wrong. Here are five signs that there is something's gone wrong: Sign 1: Difficulty in turning the steering wheelHas it become increasing difficult to turn the steering wheel? There could be a number of reasons why this happens. The first could be due to having under inflated tyres. Pump them to recommended levels and you should notice a difference. If your tyres aren’t the problem than it might be more serious than initially expected. It could be that there isn’t enough power steering fluid (this only applies for hydraulic power steering systems) in the system or that there might be a leak somewhere. If it just requires topping up, take a crack at it but if you aren't confident, take your vehicle to the mechanic. Sign 2: Difficulty in starting the engineIf it feels as though your engine is struggling to turn over, you might have a weak battery. Neglecting to get it checked can result in a fully flat battery, meaning your stranded. Tips to jump start a car can be found here. How long it takes the engine to turn over depends on how much of charge is left in the battery. If you hear the usual cranking noise but the engine doesn’t want to fire up, the problem could be due to a failed fuel pump.Sign 3: Blue smoke from the exhaustOccasionally, once you've started up the engine, get someone to sit in the driver’s seat and rev it a few times while you watch the exhaust tip for smoke. If you see faint blue smoke coming out, that’s bad news. This is a clear indication that your engine is burning engine oil. Engine oil is used to lubricate moving parts within the engine such as the pistons. It is never used in the combustion process. Its only when it manages to seep through the sidewalls of the pistons does it come into contact with the air fuel mixture and burns along with it. That’s why you see blue smoke. Mending it is going to be expensive but needs to be done. Sign 4: braking power has decreasedThere could be a number of reasons but there are two that you most know about. The first, it could be due to worn brake pads. Over time, through continuous use, brake pads loose their thickness. The more worn they become, the further the brake pedal needs to travel towards the floor. The second reason could be due to a leak in the hydraulic brake system. In either case, it’s a serious matter that needs to be tended to immediately. Sign 5: headlights aren’t as bright as they used to beThe simplest explanation for this is that your headlights need polishing. If that’s not it, then it’s a more serious problem. It could be that your alternator has failed and your vehicle’s electrical systems are relying on the battery to keep them alive. Because the alternator isn’t working, the battery isn’t being recharged. The more you drive the car, the weaker the battery becomes till eventually everything dies on you. More from Motor Trader on Yahoo! Autos can be found here. But for more news, reviews and features visit the Motor Trader website atwww.motortrader.com.my. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Ahgong Supercharged March 11, 2014 Share March 11, 2014 interesting. but most of the tips above can be fixed, mechanically. thank goodness for that~! 1 Link to post Share on other sites More sharing options...
Banz86 5th Gear March 11, 2014 Share March 11, 2014 With my car nearing 5 years of age, I've encountered the 1, 2, 5 above. 1. Steering pump faulty. Have went back to the dealership and have it replaced for free.. (Had to take a bus for my anniversary ) 2. Hard to start the engine, gone after replacing car batt 3. Same as number 2. Quite simple and true on the top.. 1 Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged March 11, 2014 Share March 11, 2014 If this happens, your car is definitely failing... 1 Link to post Share on other sites More sharing options...
13177 Supersonic March 11, 2014 Share March 11, 2014 This information is timely for many car owners now, since the majority of cars on the road now is at least 6-9 year old! 1 Link to post Share on other sites More sharing options...
Jimmylim 4th Gear March 11, 2014 Share March 11, 2014 This information is timely for many car owners now, since the majority of cars on the road now is at least 6-9 year old! not old what... cars are built to last more than that. only here coz of COE, >5 years old, like feeling driving scrapyard cars. 2 Link to post Share on other sites More sharing options...
13177 Supersonic March 11, 2014 Share March 11, 2014 not old what... cars are built to last more than that. only here coz of COE, >5 years old, like feeling driving scrapyard cars. I know cars built to last more than 10 years or beyond. But if you refering to cars here, then it is consider 'old' car if you drive beyond 5 years, and if you drive until 10 years than consider very 'old' car. Link to post Share on other sites More sharing options...
Volvobrick Supersonic March 11, 2014 Share March 11, 2014 If this happens, your car is definitely failing... This fault Mechanics cannot solve ... need sai kong! 1 Link to post Share on other sites More sharing options...
Cheesepiekia 5th Gear March 13, 2014 Share March 13, 2014 If this happens, your car is definitely failing... 1 Link to post Share on other sites More sharing options...
Nicholas 5th Gear March 13, 2014 Share March 13, 2014 If this happens, your car is definitely failing... Lol, it's like a game bug. 1 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 16, 2014 Share March 16, 2014 http://sg.news.yahoo.com/5-signs-might-something-wrong-car-114202229.html You don't always need to visit the workshop to find out if there is something wrong with your car. Just pay attention to the signs. The cars of today arent the unreliable, poorly built, rust buckets their ancestors were. In terms of reliability, service life and safety standards, the cars of today are light years ahead of the humdrum econoboxes they were derived from. But because of these reasons, many believe that spotting problems with modern cars is something best left to the professionals. Though this is true when it comes to engine and gearbox performance, other issues dont require a degree in Mechanical Engineering to figure out something is wrong. Here are five signs that there is something's gone wrong: Sign 1: Difficulty in turning the steering wheel Has it become increasing difficult to turn the steering wheel? There could be a number of reasons why this happens. The first could be due to having under inflated tyres. Pump them to recommended levels and you should notice a difference. If your tyres arent the problem than it might be more serious than initially expected. It could be that there isnt enough power steering fluid (this only applies for hydraulic power steering systems) in the system or that there might be a leak somewhere. If it just requires topping up, take a crack at it but if you aren't confident, take your vehicle to the mechanic. Sign 2: Difficulty in starting the engine If it feels as though your engine is struggling to turn over, you might have a weak battery. Neglecting to get it checked can result in a fully flat battery, meaning your stranded. Tips to jump start a car can be found here. How long it takes the engine to turn over depends on how much of charge is left in the battery. If you hear the usual cranking noise but the engine doesnt want to fire up, the problem could be due to a failed fuel pump. Sign 3: Blue smoke from the exhaust Occasionally, once you've started up the engine, get someone to sit in the drivers seat and rev it a few times while you watch the exhaust tip for smoke. If you see faint blue smoke coming out, thats bad news. This is a clear indication that your engine is burning engine oil. Engine oil is used to lubricate moving parts within the engine such as the pistons. It is never used in the combustion process. Its only when it manages to seep through the sidewalls of the pistons does it come into contact with the air fuel mixture and burns along with it. Thats why you see blue smoke. Mending it is going to be expensive but needs to be done. Sign 4: braking power has decreased There could be a number of reasons but there are two that you most know about. The first, it could be due to worn brake pads. Over time, through continuous use, brake pads loose their thickness. The more worn they become, the further the brake pedal needs to travel towards the floor. The second reason could be due to a leak in the hydraulic brake system. In either case, its a serious matter that needs to be tended to immediately. Sign 5: headlights arent as bright as they used to be The simplest explanation for this is that your headlights need polishing. If thats not it, then its a more serious problem. It could be that your alternator has failed and your vehicles electrical systems are relying on the battery to keep them alive. Because the alternator isnt working, the battery isnt being recharged. The more you drive the car, the weaker the battery becomes till eventually everything dies on you. More from Motor Trader on Yahoo! Autos can be found here. But for more news, reviews and features visit the Motor Trader website atwww.motortrader.com.my. Knn my 6 year old car showing none of the signs... Cannot change car yet.. Sop sop.. 1 Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 16, 2014 Share March 16, 2014 These so call tips/signs are meant for ladies driver... It's like common sense to most driver.... 1 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged March 16, 2014 Share March 16, 2014 These so call tips/signs are meant for ladies driver... It's like common sense to most driver....most lady drivers don't even know how to open the bonnet or know that it's required to pump air into types... Link to post Share on other sites More sharing options...
Blackyv Turbocharged March 16, 2014 Share March 16, 2014 most lady drivers don't even know how to open the bonnet or know that it's required to pump air into types... That's why such article only good for ladies driver... Link to post Share on other sites More sharing options...
Watwheels Supersonic March 16, 2014 Share March 16, 2014 (edited) Question is how many drivers actually know what is wrong with their cars? Or actually know where the problem originated from. I have once overheard a conversation in the lift. Dude A: "Oh, my car is in the workshop. I'm on my way to collect it." Dude B: "What happened?" Dude A: " Er...the steering was shaking violently when I drove this morning." Dude B: "Oh, ok." If you ask me I also dunno what's wrong with his car coz it's not my car. if my car I will know. It's the mechanic who will do the repairs anyways. So if your car is failing, the mechanic will tell you. And he will be the one who is able to know whether it's worth doing the extensive repair. But looking at the COE now, confirm worth it. LoL... Edited March 16, 2014 by Watwheels 1 Link to post Share on other sites More sharing options...
Folkien Neutral Newbie March 21, 2014 Share March 21, 2014 Sorry hi-jack this thread...can't find a way to start a new topic. Been experiencing rumbling noises from the dashboard. Kinda sounds like a broken fan. Its there only when the car is warm, and whether the air con is on or off. (it gets louder when the compressor kicks in though) When I go over speed strips of rough roads, the rumbling/rattling will get louder. https://www.youtube.com/watch?v=3vww6_CcNhE Maybe need to turn the volume up or use earphones. Somehow my phone can't really capture the sound. Will try to take another one tonight. Driving a swift sport. Anyone got similar problems? Or any thoughts? Thanks! 1 Link to post Share on other sites More sharing options...
LYC 3rd Gear May 4, 2014 Share May 4, 2014 Am driving a 9 yr old civic, though it's not showing any of the signs above but it has other issues. 1. Whenever it rains, some water will enter the spare tyre well. 2. After that my headlights and interior lights will start flickering. But when it's during dry weather or the car is not subjected to any rain, these symptoms will not show. Any advise for this? Link to post Share on other sites More sharing options...
lausai88 Hypersonic May 4, 2014 Share May 4, 2014 Am driving a 9 yr old civic, though it's not showing any of the signs above but it has other issues. 1. Whenever it rains, some water will enter the spare tyre well. 2. After that my headlights and interior lights will start flickering. But when it's during dry weather or the car is not subjected to any rain, these symptoms will not show. Any advise for this? I guess: 1. car boot leaking 2. wiring get wet and partial short circuit causing light to flicker if above is true, item 2 is serious... short circuit may cause fire. ↡ Advertisement Link to post Share on other sites More sharing options...
TV shows to recommend
Car shows
Car shows
Road signs and markings
SingPost fined record $300,000 for failing to meet delivery
China's Huawei signs deal to develop 5G in Russia
Auto-tranny breakdown: Any warning signs ?
Wearnes signs Letter of Intent with Ducati Singapore
Tell Tale Signs Before Disaster Struck
