Spken1976 1st Gear March 21, 2014 Author Share March 21, 2014 If i never remb wrongly is less than 400. Ok thks. ↡ Advertisement Link to post Share on other sites More sharing options...
Sei_fei_loh 1st Gear March 21, 2014 Share March 21, 2014 (edited) Hi bros, need your help. My car vibrate quite badly when switching to the drive mode. It's worsen when picking up. What might be the cause? Any mobile mechanic recommend? Thanks.If your car is like sounding choked while idling and feels like underpower and its not the engine mount giving way, check the ignition coil or plug cables. My aunt's latio changed it twice! Hope it helps Edited March 21, 2014 by Sei_fei_loh Link to post Share on other sites More sharing options...
Legan 1st Gear March 22, 2014 Share March 22, 2014 If your car is like sounding choked while idling and feels like underpower and its not the engine mount giving way, check the ignition coil or plug cables. My aunt's latio changed it twice! Hope it helps How to check if coil is spoilt? Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 22, 2014 Share March 22, 2014 How to check if coil is spoilt? This simple spark tester will do the work. Link to post Share on other sites More sharing options...
Ptc77 Neutral Newbie March 22, 2014 Share March 22, 2014 If step gas, slow acceleration. Cannot go beyond 70, likelihood coil on one of spark plug misfire. Roughly $250 per coil to change. Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 22, 2014 Author Share March 22, 2014 Hi bro, done my repair. Diagnosed mis firing coils. Changed 2 coils $252. Diagnose test $35. Labour charge $60. Total damage: $347. Link to post Share on other sites More sharing options...
Sei_fei_loh 1st Gear March 24, 2014 Share March 24, 2014 Hi bro, done my repair. Diagnosed mis firing coils. Changed 2 coils $252. Diagnose test $35. Labour charge $60. Total damage: $347. Apologies for the late reply. Good to hear things are back to normal. Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 24, 2014 Author Share March 24, 2014 Apologies for the late reply. Good to hear things are back to normal. It's OK. After changing the coil, feel like more powerful. Luckily didn't go Tan Chong quote me more than a thousand dollar. Like I'm a carrot to him. Link to post Share on other sites More sharing options...
Kezg1 5th Gear March 24, 2014 Share March 24, 2014 It's OK. After changing the coil, feel like more powerful. Luckily didn't go Tan Chong quote me more than a thousand dollar. Like I'm a carrot to him. This is how AD charges not that they like to chop carrots....even autosaver will charge you probably 30% cheaper only... but we always have alternative workshops Link to post Share on other sites More sharing options...
CHLO Neutral Newbie March 24, 2014 Share March 24, 2014 Can advice which workshop you go? My Mazda 5 also got vibration and underpower issue after replaced the starting motor, went back to the WS they said it's engine mounting problem. Just wonder how can this suddenly happen right after the Motor replacement. Tks! Link to post Share on other sites More sharing options...
Volvobrick Supersonic March 24, 2014 Share March 24, 2014 The symptom for misfiring/coil damage should then be "knocking" rather than just "vibrate". It is a very sever vibration and there is big lack of power. I kena twice recently, first time went AD and cost me a bomb, including 100 plus just to "diagnose". (I am sure they knew exactly what the problem was!) Second time same symptom I took out the coil one by one and used a spare spark plug to check the spark. The one without spark would be the one to be replaced! Can advice which workshop you go? My Mazda 5 also got vibration and underpower issue after replaced the starting motor, went back to the WS they said it's engine mounting problem. Just wonder how can this suddenly happen right after the Motor replacement. Tks! Under power should have nothing to do with the starter motor or engine mount.... Link to post Share on other sites More sharing options...
CHLO Neutral Newbie March 24, 2014 Share March 24, 2014 Tks, replace the starting motor was because unable to start then, checking battery still 85% so they diagnosed it's starting motor fail. All the vibration and underpower only come after that starting motor replaced. Is it possible they failed to install back any parts properly during the replacement? Link to post Share on other sites More sharing options...
Spken1976 1st Gear March 25, 2014 Author Share March 25, 2014 Can advice which workshop you go? My Mazda 5 also got vibration and underpower issue after replaced the starting motor, went back to the WS they said it's engine mounting problem. Just wonder how can this suddenly happen right after the Motor replacement. Tks!Hi I went to Tek Soon Motor Repair at Autobay Kaki Bukit #01-93. Price quite reasonable. 1 Link to post Share on other sites More sharing options...
Volvobrick Supersonic March 25, 2014 Share March 25, 2014 Tks, replace the starting motor was because unable to start then, checking battery still 85% so they diagnosed it's starting motor fail. All the vibration and underpower only come after that starting motor replaced. Is it possible they failed to install back any parts properly during the replacement? Possible that they dislodge the coil cable/coil by accident.... Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 26, 2014 Share March 26, 2014 Don't know what went wrong also. But there is some tire burnt smell also. Bringing to workshop tomorrow. Will be going to Tek Soon Motor at Autobay. Any comments? Burnt smell??? Check the colour of your ATF. Is it reddish n fresh or brown n looks dirty? Maybe u need to flush or do a few drain n fill new ATF to get it all smooth again. Don't know what went wrong also. But there is some tire burnt smell also. Bringing to workshop tomorrow. Will be going to Tek Soon Motor at Autobay. Any comments? Oh tire burnt smell. Maybe yr brakes r binding n sticking. Maybe just need to adjust or already need to replace brake pads n adjust properly. My latio seem a lot problems. Sometimes yr car a lot of problems maybe its time to look for a better n more honest workshop. Oh ok. Last year happen once before. I had changed the coil and spark plugs. Cost me $400. But don't know why so fast happen again. Btw est how much to change the rubber thingy on the engine mount? Thanks. Try to get recommendations from frens who dun hv problems with their cars n try their ws n see if it improves. Sometimes ws is cheating customers . Very common problem. Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 26, 2014 Share March 26, 2014 (edited) If step gas, slow acceleration. Cannot go beyond 70, likelihood coil on one of spark plug misfire. Roughly $250 per coil to change. Quite easy to check. Car warmed up n idle. U find idle quite rough? Just remove one spark plug cable at a time n see if the rough idle gets worse. If it remains same then that is the faulty plug cable/coil pack. Or maybe its just the plug faulty. Maybe just a new set of plugs might b a cheap fix to the problem. Edited March 26, 2014 by Pisces69 Link to post Share on other sites More sharing options...
Pisces69 6th Gear March 26, 2014 Share March 26, 2014 This is how AD charges not that they like to chop carrots....even autosaver will charge you probably 30% cheaper only... but we always have alternative workshops For me I buy the original or OEM parts myself n get my ws to fix only. Very transparent my parts n labour costs. Plus I can control the quality of the parts used in my car. All good quality and not some cheepo low quality Made in China parts. Can advice which workshop you go? My Mazda 5 also got vibration and underpower issue after replaced the starting motor, went back to the WS they said it's engine mounting problem. Just wonder how can this suddenly happen right after the Motor replacement. Tks! Its time for u to start looking for a better n more honest WS. Tks, replace the starting motor was because unable to start then, checking battery still 85% so they diagnosed it's starting motor fail. All the vibration and underpower only come after that starting motor replaced. Is it possible they failed to install back any parts properly during the replacement? Mechanics or boss see u as a ripe carrot ready to b chopped. Look for a new ws unless u want this problems to keep getting worse cos a dishonest ws wil always b a dishonest ws. Link to post Share on other sites More sharing options...
Yymail22 2nd Gear July 27, 2014 Share July 27, 2014 It's OK. After changing the coil, feel like more powerful. Luckily didn't go Tan Chong quote me more than a thousand dollar. Like I'm a carrot to him. I look up this forum to find Spken1976's problem pretty similar to mine. I sent my kid to weekend class today. When l started my 2006 Sylphy to leave the school, the engine vibrated at idling. The RPM was stable at 700 as usual. I thought it was intermitent fuel supply or that one of the cylinders is not firing. I can hear at the exhaust pipe puffing noise. It's like those old VW van revving rhythm. When I drove off, the power was lacking. I pulled up at a small lane, opened the bonnet. As in Spken1976's case, there was a rubber-like burning smell. While I will send to the workshop after Hari Raya to diagnose if it was the fault of the coil, what does the burning smell come from? Did Spken1976 manage to find out eventually? Thanks. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
Nissan QashQai 2014 Part 2
Nissan Teana Experience
2023 Tan Chong Car Challenge
