Ahbao999 1st Gear May 4, 2014 Share May 4, 2014 Hi guys, Need some advise from you all. I am staying in 5 rooms flat installed with system 3 aircon. Did not fix a unit in living room Now I would like to have aircon in my living room. Wanna check if HDB will approve 2 compressor in one HDB unit. possible to apply? another option will be portable aircon which is not a wise choice. last option, buy new system 4..... waste money cos my sys3 used 3years only. kindly give comment, advise. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Rastaman01 2nd Gear May 4, 2014 Share May 4, 2014 2 compressor is not issue i guess...mybarea punghol manybhouse with 2 compressor....but the only theing is that they need to do major wiring and drilling holes.... my house also i got stupidly conned by my ID...he said my house cant do hall as the wiring too far and waste money.... ... i first time house owner n reno so just follow... after move in see my neighbour mostbhave... now been asking around many say can but they say they have to do external trunking that run across ceiling and a bit of patch work needed as need drill holes... so contmplating as selling the house in 2 years time.... Link to post Share on other sites More sharing options...
Gary88 1st Gear May 4, 2014 Share May 4, 2014 my hdb neighbour 2 compressor also Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 4, 2014 Share May 4, 2014 you can refer to here for guidelines http://www.hdb.gov.sg/fi10/fi10324p.nsf/w/HomeRenoGuidelinesAirCon?OpenDocument Link to post Share on other sites More sharing options...
Little_prince Supersonic May 4, 2014 Share May 4, 2014 Hi guys, Need some advise from you all. I am staying in 5 rooms flat installed with system 3 aircon. Did not fix a unit in living room Now I would like to have aircon in my living room. Wanna check if HDB will approve 2 compressor in one HDB unit. possible to apply? another option will be portable aircon which is not a wise choice. last option, buy new system 4..... waste money cos my sys3 used 3years only. kindly give comment, advise. Thanks actually better to have separate unit. the system 4 may noy be enough btu to cool the living room. getting a separate system 2 just for the living room is best 1 Link to post Share on other sites More sharing options...
Ahbao999 1st Gear May 5, 2014 Author Share May 5, 2014 Thanks everyone for the reply. yes little prince, understand that sys4 will affect performance if all on in the same time. so best to have seperate unit. but hopefully 2 compressor can be approved. cos my HDB is those old generation which uses mounted bracket to hold the compressor. Link to post Share on other sites More sharing options...
Ahbao999 1st Gear May 5, 2014 Author Share May 5, 2014 Guidelines Governing the Installation The running current of air-conditioner should be restricted by 20amps DP isolator or 15amps power point Maximum of 2 split-type air-conditioner condensing units are allowed to be installed [ Note: The maximum weight allowed is 110 kg per wall panel be installed on the external wall or air-conditioner ledge] For wall mounted air-conditioner condensing units, each wall panel is allowed to mount only 1 air-conditioner condensing unit My current compressor is wall mounted outside my masterbed room and now intend to have one more mount outside my living room so should be ok? I have email HDB but yet to receive any reply. Link to post Share on other sites More sharing options...
TVT Supercharged May 5, 2014 Share May 5, 2014 actually better to have separate unit. the system 4 may noy be enough btu to cool the living room. getting a separate system 2 just for the living room is best Yes, agreed. My current compressor is wall mounted outside my masterbed room and now intend to have one more mount outside my living room so should be ok? I have email HDB but yet to receive any reply. I believe you can ask your aircon contractor (the shop you order the new compressor aircon from) to settle this part. They are specialist in this line, and should know what can be done, or cannot be done within the HDB rules. After all, if they can't do it, they can't do your business anyway.... Link to post Share on other sites More sharing options...
Lala81 Hypersonic May 5, 2014 Share May 5, 2014 just calculate how many BTU u need per room. In general its 50-55 BTU/sq feet. U can use sqm to sq feet converter in google. I use an inverter system 1 for my MBR. System 3 for living room + other 2 rooms. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged May 5, 2014 Share May 5, 2014 Guidelines Governing the Installation The running current of air-conditioner should be restricted by 20amps DP isolator or 15amps power point Maximum of 2 split-type air-conditioner condensing units are allowed to be installed [ Note: The maximum weight allowed is 110 kg per wall panel be installed on the external wall or air-conditioner ledge] For wall mounted air-conditioner condensing units, each wall panel is allowed to mount only 1 air-conditioner condensing unit My current compressor is wall mounted outside my masterbed room and now intend to have one more mount outside my living room so should be ok? I have email HDB but yet to receive any reply. mine also have 2 compressor.. 1 outside masterbed room... also old unit Link to post Share on other sites More sharing options...
Ahbao999 1st Gear May 5, 2014 Author Share May 5, 2014 THANKS FOR THE ADVISE. Then in this case should be able to install. Daily usage only apply to masterbed room, another 2 common room very seldom use. ↡ Advertisement Link to post Share on other sites More sharing options...
Car air-con
Car air-con
Home Aircon
Home Aircon
Looking for Job in automotive sector, need advise
