When Alternator is spoilt, what will be affected?
Super7
Turbocharged
Recently my car's aircon is not working properly ie cold for a short while every time I start using the car and then it goes off, no cold air.
Last nite, ABS and battery warning lights came on and soon power steering was gone. Horn no sound.
Fortunately i reached the workshop and left it outside the main door as it was already 10pm. The engine wouldnt crank when i tried restart it to park closer to the side.
This morning WS called me up telling me alternator spoilt.
How does alternator affect ABS, Power Steering when it's spoilt?
Thank you for your advice.
From experience, you'll see a lot of warning lights on your dashboard, and if you continue driving the engine will simply shut down.
  • Praise 3
Hypersonic
Alternator is like a electrical generator for your car. When it failed, the car don't have electrical supply.
  • Praise 2
Most systems in yr car need electrical power to work.
No elect all wil fail once the battery is drained. Most systems get power from the alternator when car is running.
When alternator spoil, once the battery is drained all wil fail.
  • Praise 2
Turbocharged
I can vouched for this.
I stop at the traffic junction and engine went dead without me know.
only realised it when the light turns green and there is zero power to move the car.
hv to call for tow-bed truck to send to ws.
don't be mistaken, im not driving " the people car" [lipsrsealed]
Wah you damn tyco.
Lucky it reached ws then failed else you need to pay the towing fee.
Supersonic
When battery warning lights comes up, it's the charging system that is the problem, not the battery.
Without the alternator charging the battery and supplying all the electrical loads, the battery is left to supply all the loads.
Depending on the size and capacity of the battery, you might have only about one hour of usage, after which everything starts to go haywire and ultimately, engine will stall.
  • Praise 4
Turbocharged
Thank you to all bros who have given advice / comments!! [thumbsup] [thumbsup]
It's really fortunate i could reach the ws without stalling halfway and had to call tow truck service. [sweatdrop] [sweatdrop]
The power steering went off first before the battery light came on (ie battery weak / near kosong) together with ABS light. I would have thought as soon as the alternator is not functioning well there should be a warning light way before other parts are affected, so that the driver could get it checked / fixed asap. I recall it took less than 5 minutes from the time the battery light came on to complete shut down!! Not enough advance warning.
Hopefully there's after market sensor etc to give more advance warning of alternator mulfunction (imagine halfway on the NSHW when it fails!!) [sweatdrop] [sweatdrop]
Supercharged
Wah, this is scary.
Yah, imagine in the middle of a Malaysia road trip the alternator fails, jialat man!
So you drove to the WS w/o any power steering (harder to turn the wheel)?
So roughly what's the damage to your alternator ? Change new one ?
But I tot there are some devices (used by battery mechanics) to check the alternator's "health"? Maybe before a road trip, or every few months, we can go to a WS to get it checked ? Would that help ? [confused]
Usually if yr alternator is weak, sud b like elect charging not so good. Can see battery often not fully charged.
Also at night can see lights dimmer n horm dying.
Usually if alternator weak, the red warning light wil slowly come on at traffic light when engine at idle speed. Sometimes its very dim so daytime might not see it.
Wah, this is scary.
Mostly dun change a NEW alternator cos its damm expensive.
Mostly just get those re-con but from a reliable shop. Usually only the bearing n carbon brush wil spoil. Nothing else to spoil. These can b changed n its like new again.
Now alternator also have a circuit board to control the charging so if thats gone, then it needs to b replaced too. That a bit difficult.
Another alternative is to get a 2nd hand unit from scrap yards. just make sure its in good condition.
Edited by Pisces69
  • Praise 3
Supercharged
So bro Super7 - did you notice these warnings (lights dimmer, etc) as mentioned by bro P69 before your alternator finally broke down? [sweatdrop]
Or were you too distracted at the traffic light cos got chio xmm crossing the road ? [grin]
Supersonic
Does your car have electric or hydraulic power steering ?
Electric use the alternator/battery, hydraulic depends on a belt.
If hydraulic, belts could have broken or slipped off, and both alternator and power steering would be affected at the same time.
ABS should normally not be affected.
Some cars "battery light" on the dashboard does not light up even when the alternator fails. I think due to the wiring.
Best way is to connect a voltmeter. With engine running, it should always read around 14V.
If it suddenly drops to 12V, you would know the alternator konked immediately.
Turbocharged
I assume the when head lights are dim, i cant even tell the xmm is chio or not as i only drive the car at nite... [sweatdrop] [sweatdrop]
Turbocharged
Talking about voltmeter, i remember an after market plug-in gadget which show the state of charging etc (plug into cig lighter socket), have you used this instead of a proper voltmeter before, is it good?
Turbocharged
Wah, this is scary.
Good idea to borrow ws's device to check the alternator every now and then [thumbsup]
Tomorrow i will see the bill when i collect the car [sweatdrop] [sweatdrop]
Turbocharged
I think this is the case: didnt notice the dim warning light as when the failure happened it was still daylight, about 5pm [:(]
