Somebody 1st Gear August 16, 2014 Share August 16, 2014 Hi everyone, I'm facing some problems with my car. From P, when i shift to D, its often very stiff. And recently, when I shift to R, it doesn't even engage until 2-3 secs later. Not sure if its the transmission or the clutch having problems. Could ppl recommend me a garage that specializes in Transmissions/Clutches that can be trusted and won't chop me? haha! ↡ Advertisement Link to post Share on other sites More sharing options...
Marcostan 4th Gear August 16, 2014 Share August 16, 2014 Hi Brother, Same as my LS460, the problem is call gear slip, I just did my overhaul and the cost is only 1/3 of what the Lexus agent quoted me. The work is excellent, after overhaul the feeling is just like that time I collected from brand new. Ellipse Auto Transmission 21 Sin Ming Industrial Estate Sector A #01-40 Tel: 6456 0090 Visit the shop and discuss with them see what you need to do. I believed need to overhaul. Good Luck! 2 Link to post Share on other sites More sharing options...
Dieselord 2nd Gear November 14, 2014 Share November 14, 2014 (edited) OT abit.... if overfill auto oil (~2mm above Hot level in dipstick) during running.. will it cause damage? shld i drain it out? TIA... Edited November 14, 2014 by Dieselord Link to post Share on other sites More sharing options...
Meanmachine 6th Gear November 14, 2014 Share November 14, 2014 OT abit.... if overfill auto oil (~2mm above Hot level in dipstick) during running.. will it cause damage? shld i drain it out? TIA... Regards, to Auto transmission fluids oil change, you must drain all old fluids out and replace with new fluids, check your manual for the recommended fluids use, once it is fully drained, your mechanic will fill-up new 4litre of transmission fluid , do not over fill, it is unlike EO, overtime it can cause sludge built-up and residue over time, even if you order 4 litres of fluids and uses only 3Quarter, thy will still chage you 4 litres, u may keep the balance for future top-up. ( If it dark brown in colour or has a smelly a dour, time to change ) it can cause major gear box transmission havoc and the cost is much heavier. Recommended Auto transmission change every 30,000Km, dependent on your mileage. Link to post Share on other sites More sharing options...
Dieselord 2nd Gear November 14, 2014 Share November 14, 2014 thks for your advice... :) i chg mine during last servicing... just now go chk, find that it's slightly higher den "Hot upper limit"... it's still reddish brown color... i will ask ws to drain some out... it shld be slightly lower den "Hot upper limit", right?? (when running, in Park or Neutral mode) thks ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
MCF HangOut X Lexus – 9 May 2024, Lexus Boutique
Lexus Finally Figured Out The Three-Row SUV
The all new Lexus UX
2024 2nd Generation Lexus LM
Lexus Owners (To share driving experience and advise)
2023 Lexus RZ 450e
2023 Lexus RZ 450e
