Tanahseng Clutched September 10, 2014 Share September 10, 2014 Anyone can tell me? As per title, during slow speed accelerate is okay but hard acceleration, it seems like choking. Thanks friends. ↡ Advertisement Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear September 10, 2014 Share September 10, 2014 Anyone can tell me? As per title, during slow speed accelerate is okay but hard acceleration, it seems like choking. Thanks friends. describe your car. example: age, brand/model, servicing interval, driving pattern (city/highway), etc. Link to post Share on other sites More sharing options...
Tanahseng Clutched September 10, 2014 Author Share September 10, 2014 describe your car. example: age, brand/model, servicing interval, driving pattern (city/highway), etc. 8 years old CRV. Every 10k service once. City. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear September 10, 2014 Share September 10, 2014 8 years old CRV. Every 10k service once. City. i can think of carbon choking. your mileage is high? perhaps due for an overhaul. another suspect maybe foreign liquid like water inside your fuel tank, or somewhere. best is to check with your WS during your next servicing. Link to post Share on other sites More sharing options...
Tanahseng Clutched September 10, 2014 Author Share September 10, 2014 i can think of carbon choking. your mileage is high? perhaps due for an overhaul. another suspect maybe foreign liquid like water inside your fuel tank, or somewhere. best is to check with your WS during your next servicing. Thanks anyway. Yes i had not bring to WS yet. Thinking of getting some ideas here before going to WS. If not scared kenna sian by them. Not really have knowledge in cars. Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged September 10, 2014 Share September 10, 2014 (edited) Fuel pump or fuel filter going bad? Edited September 10, 2014 by Holdenutessv Link to post Share on other sites More sharing options...
Tanahseng Clutched September 10, 2014 Author Share September 10, 2014 Fuel pump or fuel filter going bad? I am not sure also. Seeking advice here Link to post Share on other sites More sharing options...
Furrynadz 5th Gear September 10, 2014 Share September 10, 2014 (edited) check fuel pump or ign coil/plug go pump 98 caltex and drive 100+ 4000rpm for 30 mins clear carbon Edited September 10, 2014 by Furrynadz Link to post Share on other sites More sharing options...
Volvobrick Supersonic September 10, 2014 Share September 10, 2014 Coughing? Violent vibrations/knocking? Check coils, will fail around 8 yrs (100plus K). seldom fuel filter as fuel in Singapore very clean. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged September 10, 2014 Share September 10, 2014 there could be thousand and 1 reason for such problem... 1) Fuel contaiminated with foreign liquid (eg water, i kena before, its like what u describe) 2) Fuel pump / fuel filter choke 3) Fuel injection choke 4) sparkplug faulty 5) O2 sensor, MAF mulfunction, causing A/F ratio to haywire ( i kena before, its like what u describe) thats all i can think of... Link to post Share on other sites More sharing options...
Pocus Turbocharged September 10, 2014 Share September 10, 2014 Could be maf sensor. Last time my car also same feeling for weeks then one day I whack pedal to metal and my car got a pop sound and suddenly like gain 20bhp and very fast! Drive damn shiok until I reach traffic light car died and never able to start again. In the end tow back to ws to replace the sensor. Link to post Share on other sites More sharing options...
Skymax 5th Gear September 11, 2014 Share September 11, 2014 Mine was spark plug faulty. Hard acceleration, hesitation to Chiong. Link to post Share on other sites More sharing options...
Zhngmycar 1st Gear September 13, 2014 Share September 13, 2014 check your spark plug. the judder would get worst. maybe just 1 of them burn.. Link to post Share on other sites More sharing options...
Guysmokey 1st Gear September 14, 2014 Share September 14, 2014 Go workshop and plug in the OBD reader. In my case its misfiring, meaning ignition coil gone. Do note that ignition coil can change individually, though most workshop will ask you to change all 4, since they are slowly breaking down. This is up to your budget. At the same time can consider changing spark plug, since the coils are already out. Its the same labor cost anyway (~$30 only) Link to post Share on other sites More sharing options...
Pisces69 6th Gear September 14, 2014 Share September 14, 2014 (edited) Thanks anyway. Yes i had not bring to WS yet. Thinking of getting some ideas here before going to WS. If not scared kenna sian by them. Not really have knowledge in cars. Last time older cars have old Distributor. If the timing is too retard, it wil jerk when accelerate. Now new cars use electronic Distributor all controlled by ECU. Now cud b........... Spark plugs worn (or wrong type of plugs) n not sparking well. Also Plug cables faulty. Bad spark. Fuel filter clogged. Fuel pump faulty. Injectors clogged. Not enough fuel going to cylinders. Air filter dirty. Not enough air to cylinders. Its either air, fuel or electrical problem. Also cud b wrong fuel. Too low RON Octane rating. U can DIY first. Like spray Carb Cleaner into throttle body to clear gunk accumulated along the fuel path. Or a bottle of additive add to petrol tank for a slow remedy. Or fuel contaminated. Check if any plug cables R loose. Maybe need to adjust the valve clearences. Timing belt jumped a notch or two. These r the main things I can think of now. Also try to do a "soft" reset of yr ECU by disconnecting the battery for a couple of hours then connect back for it to return to factory settings. Oh also maybe one of yr rubber vacuum hoses have a small leak n air is getting in to confuse the settings. Old rubber tends to become brittle n develop cracks. Edited September 14, 2014 by Pisces69 Link to post Share on other sites More sharing options...
MYSUV Neutral Newbie October 20, 2014 Share October 20, 2014 This is Sounds like something an ignition problem. it is exist more when it's humid out? If so, replace the its ignition wires, and distributor cap Link to post Share on other sites More sharing options...
Alvincsj 1st Gear December 19, 2014 Share December 19, 2014 Might want to check if there are any vacuum leak. That will mess up the AFR, resulting in choking as the rpm increases. At times, the idling will also be affected. Link to post Share on other sites More sharing options...
max15 June 1, 2015 Share June 1, 2015 go to workshop for check ↡ Advertisement Link to post Share on other sites More sharing options...
Kia Cerato Variant 2 persistent overheating issue
Any recommended workshop with reasonable labour charges?
P2096 Check engine light
Replacing fuel filter
Nissan Almera 2004 MT making whining sound
